Sharp 55R-WP4H 55" Rear Projection Television Logo
Posted on Sep 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Still issue with convergence after replacing ICs
I had the blinking view timer issue, my Sharp would turn off after 20 minutes of view time. I replaced both convergence ICs, and the TV is staying on (I left it on over 3 hours as a test). However, I'm not able to adjust the convergence - the red is way off. Would this still be a Convergence IC problem, or does sound more like an issue with a resistor somewhere?
Anonymous
Level 3:
  • Sharp Master 3,459 Answers
  • Posted on Apr 18, 2010
Anonymous
Sharp Master
Level 3:
Answers
3459
Questions
5
Helped
849114
Points
5558
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix hereStill issue with convergence after replacing ICs - bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
1helpful
Panasonic 51'' HDTV Model PT51HX42F - Turns off, light blinks 3 times, pauses, blinks 3 times again, etc.
the 3 blinks is caused by convergence failure indicating the Convergence ICs and resistors need replacement. You can get the convergence repair kit for your model at www.tvrepairworld.com the kit contains the ICs and resistors and also has the CD that shows how to do the repair.
3helpful
TV turns itself off after being on a few seconds, ...
Three time blink means tv got problem in convergence output circuit, replace convergence output ICs to solve the issue.
Thanks.
I have a 47" projection tv that comes on and then it goes right back off and the light code blinks 3 times
Replace convergence out ICs in A Board to fix this issue.
3 times blink shows convergence problem.
2answers
Why would the stnd by timer blink
They may be 'functioning" but not correctly, double pictures and 3 d effects are all due to a convergence problem. some 0f the capacitors are dying or even dead. Not all of them are kind enough to split or show burn. The chip that controls this function may also be going on the blink. BTW i hope you are wearing your lead apron while you are looking in the back
Please rate my help++++Thanks for using FIXYA
1helpful
Turns off seconds after I turn it on
If the red light on the front panel blinks after the unit shut off, the problem is most likely in the convergence ICs. They are 2 large ICs with large heat sinks.They are usually marked STK392 depending on the model. Replace these ICs and check also for any obvious discoloration or deformation of components around it It will cost you about $20. If it doesn't solve the issue and the projection lamp is been used for about 8,000 hours, replace the lamp. It will cost you $150-$200.
2helpful
Panasonic PT 47WX53G does not turn on
If the indicator blinks three times its the error for the convergence ICs and resistors. You can get the right repair kit for your model at the following link which contains the Two ICs the 6 feed resistors and detailed step by step instructions with pictures.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits
Hewhen lp
The convergence ICs need to be replaced. # blinks is the error code for the convergence. You will need two STK392-110 Convergence ICs you can get replacement ICs at the following link with free shipping and free instalation instructions with pictures.
2answers
Panasonic pt-47wx42f
Yes you can get replacement IC STK392-110 convergence ICs at the following link and they provide free instalation instructions with pictures. The Ics are located on the board on the left side attached to a large heatsink. You will need to replace both ICs heres the link.
2helpful
2answers
VIEW TIMER
Try unplugging the B+ to the convergence circuit and see if it will power up.. If so replace the convergence amps, two STK392-040 and check all the low ohm resistors.
Bill
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
