Question about LG LFC25760ST 25 Cu. Ft. Panorama French Door Refrigerator w/ Glide N' Serve Drawer & Internal LED T...
The unit that incases the temperature controls has broken and is hanging by the connector. How can I replace it?
  • 553 Answers
Just turn off your refrigerator and detached the thermostat control (temperature control), you can do that just by using some cross screw drivers, at the back ot that thermostat control is a part number where you can buy on the service center or any refrigerator parts supplier, just give them the model and the part number and they will give you exactly the same piece, then just put it back again the same way how you take it off. then turn on your refrigerator..
Take NOTE: if you are taking some parts of your appliances (any parts) just all remeber this..
The first thing you take out will be the last thing you will put back...
Posted on Oct 31, 2009
Help me how to remove system error cod e000 for canon pc-d 340
PC-D320/PC-D340/FAX-L400 Chapter 4: Maintenance and Service
E000 Fixing unit failure
Cause: (1) Shorted/broken wired main thermistor (2) Shorted/broken wired sub thermistor (3) Broken wired heater/blown thermal fuse
Solutions: (1) Turn the power off and remove the fixing unit from the machine. Measure the resistance between the fixing unit connector J206-2 (FSRTH) and J206-1 (GND). If the resistance is not within the range between 350 KW and 520 KW (room temperature of 20°C), replace the fixing film unit. (2) Turn the power off and remove the fixing unit from the machine. Measure the resistance between the fixing unit connector J206-3 (FSRTH2) and J206-4 (+3.3V). If the resistance is not within the range between 370 KW and 520 KW (room temperature of 20°C), replace the fixing film unit. (3) With the fixing film unit removed, if there is no continuity between the fixing unit connectors J102-1 (ACH) and J102-2 (ACN), replace the fixing film unit. (4) Replace the ECNT board. (5) Replace the SCNT board
See Service Manual page 105 (4-25):
Canon PC D320 Service Manual Page 105
Jun 04, 2015 | Canon PC-D340 All-In-One Laser Printer
WHAT HAPPEN ON IR 2202 FOR THIS EOO2-OOOO AND HOW CAN IRSOLVE IT?
E002-0000 Low temperature during temperature control.
The target temperature is not reached during temperature control. - Check the connector of the fixing film unit. - Replace the fixing film unit. - Replace the
Aug 20, 2014 | Canon Image Runner 2022 Copier
My amana 26 side by side refrigerator/freezer keeps running and everything is freezing. i have tried to turn it down with no help
1x1.gif How To Replace the Temperature Control Remove the temperature control dial or housing. Pull the dial straight away from the wall. Remove the temperature control. If there is a housing over the control, it either snaps into place or is held in place with screws. Remove the screws, or gently depress the retaining clips with a small screwdriver. Allow the housing to hang by its wiring.
Before replacing the control, unplug the refrigerator to avoid an electrical shock hazard.
The control is connected by two wires. Label the wire placement on the control before disconnecting the wires. The wires are connected to the switch with slip-on connectors. Firmly pull the connector (do not pull on the wire) off of the control's terminal. You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors for corrosion. If the connectors are corroded they should be replaced.
The temperature control also has a temperature probe permanently attached. Follow the path of the probe and remove any fasteners that hold it in place.
Carefully replace the temperature probe along the same path as it was originally installed. Avoid any unnecessary bending, and do not bend it into a sharp angle as this can damage the probe. Connect the wires to the new temperature control. Replace the switch and housing (if any) and press the knob onto the the control's hub. Adjust the control to a midway setting. Plug in the refrigerator. After one to two hours check the temperature.
Aug 13, 2011 | Amana Refrigerators
Km2030 showing code c610
C610 Broken fixing heater wire
• Warm-up does not end within 90 s.
• The secondary stabilization fixing
temperature drops to 100°C/212°F or
below.
• The fixing temperature remains below
40°C/104°F for 7 s or longer after the
fixing heaters have been turned on.
Causes
  • Fixing heater installed incorrectly (Check and reinstall if necessary.)
  • Broken fixing heater wire. (Check for continuity. If none, replace fixing heater.)
  • Poor contact in the fixing unit thermistor connector terminals.(Check the connection of connector CN12 on the main PCB and the continuity across the connector terminals.Remedy or replace if necessary.)
  • Broken fixing unit thermistor wire.(Measure the resistance. If it is ∞ ?, replace
    the fixing unit thermistor.)
  • Fixing unit thermistor installed incorrectly.(Check and reinstall if necessary.)
  • Fixing unit thermostat triggered.(Check for continuity. If none, replace the
    fixing unit thermostat. Check the operation of the cooling fan and repair if necessary.)
Jul 09, 2011 | Kyocera KM-1505 Copier
I have an System ERROR E001 following Error E808 on my canon 2016j copier and waht shal i do me out guys
E001 0000 Abnormally high temperature (detected by main thermistor)
The main thermistor detected an
abnormally high temperature (240 deg
C) during temperature control.
- Replace the DC controller PCB.
E001 0001 Abnormally high temperature (detected by sub thermistor)
The sub thermistor detected an
abnormally high temperature (295 deg
E808 0000 Fixing drive circuit failure
- The heater does not turn on.
- A fixing drive motor failure was
detected.
- Replace the fixing drive motor.
- Replace the power supply PCB.
Feb 19, 2011 | Canon iR 2016i Black and White Copier
The fridge keeps freezing
You have a problem with the cold control.
Carefully replace the temperature probe along the same path as it was originally installed. Avoid any unnecessary bending, and do not bend it into a sharp angle as this can damage the probe. Connect the wires to the new temperature control. Replace the switch and housing (if any) and press the knob onto the the control's hub. Adjust the control to a midway setting. Plug in the refrigerator . After one to two hours check the temperature.
Nov 28, 2010 | Hotpoint HSS25GFP Side by Side...
System error 004
E004 Fixing unit failure
E100 Scanner unit failure
E246 The Counter board is left out
E676 Communication error
E677/6F-61 ROM check error
E677/6F-63 RAM error
E733 A fault occurred in the communication between the SCNT board
and ECU board/TOP signal cannot be detected
New E805 Fan failure
TRY THIS:
Measure the resistance between the fixing unit connector J301-1
(FSRTH) and J301-2 (GND).
If the resistance is not within the range between 350 W and 520 W
Measure the resistance between the fixing unit connector J302-1
(FSRTH2) and J302-2 (GND).
If the resistance is not within the range between 360 W and 530 W
between the fixing unit connectors J303-1 (ACN) and J303-3
(ACH), replace the fixing film unit.
(4) Replace the EPU board.
(5) Replace the ECU board.
Jun 24, 2010 | Canon Office Equipment & Supplies
Fisher and paykel compact outdoor fridge compressor won't run. Power is good, door switch works properly, cold control knob(potentiometer) works fine. Compressor is cold and run/start relay is not...
I have seen this problem on similar units and one of two problems are usually the culprit.
1- too much freon -
2- broken rod or piston on the compressor
Just thought I would share this just in case you over looked it. 8bbb0eb.jpg
Apr 19, 2010 | Fisher Refrigerators
Canon ir 2016j
E003 0000 Abnormally low temperature (detected by main thermistor)
After the temperature detected by the
main thermistor has reached the
specified value, it does not reach the
specified value during initial rotation.
0001 Abnormally low temperature (detected by sub thermistor)
sub thermistor has reached the
Jan 09, 2010 | Minolta EP4000/5000 CS/PRO Copier
Heater/AC control no longer allows change in temperature
You have one of two possible problems.
1) The temperature shaft retention nut is loose behind the knob
2.) The wires to the potentiometer part of the temperature may be broken.
Either one is common to this vehicle. The replacement of the AC controller is about 900 dollars. If the wires are broken, they can easily be reattached to the circuit board via soldering. What you would have to do is remove the control box from the dash, and disassemble it. Once the unit is apart, there are 3 wires from the temp knob to the circuit board that need to be re-soldered. The unit CAN be repaired, as opposed to the expense of replacing it.
Apr 23, 2009 | 2006 Toyota Highlander
LG LFC25760ST 25 Cu. Ft. Panorama French Door Refrigerator w/ Glide N' Serve Drawer & Internal LED T... Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
