Question about Cameras
Canon a520's zoombrowser x, won t let me delete images once uploaded to ebay.
Error message... The delete operation has failed. Access is denied. Please check access permissions, and ensure the file is not in use
HeavyDLB
  • 46 Answers
SOURCE: Canon Power Shot A520 upload a image to the computer
Dear binghau:
The surefire way to have the date show on your pictures is to set your camera's resolution to PostCard Mode and thus record the date stamp on the picture itself. Your ZoomBrowser software, however can put the date on each of your images. I am using ZoomBrowser EX ver 5.8 as an example. If yoiur version if different it will still have similar functionality.
You can rename image files using four different naming schemes:
1. Image Name + Number (e.g. Vacation_001.jpg)
2. Shooting date + Number (e.g. 20080601_001.jpg)
3. Name + Shooting date + Number OR
4. Shooting date + Name + Number
You may choose to do either method 2 or 4 to get the date.
To rename selected images or a group of images using one of the above naming schemes simply open ZoomBrowser and point it to the folder that contains the images you wish to rename. For this example let's assume it was your recent vacation photos.
I would utilize either Zoom or Scroll mode to view the images on the main screen. Then follow these steps:
1. Click the task panel labeled "View & Classify"
2. Next click the sub panel "Rename Multiple Files"
3. On the left hand panel click Step 1 "Select images"
[Here you can select any or all images in the folder]
4. Next click Step 2 "Specify Rename Settings"
5. Select the way you want the files to be named and enter
the appropriate settings. Note: If you wish to keep the original
file and make a copy with the new naming scheme make
sure you check "Make Copies of files"
6. Lastly click Finish and your newly renamed files will be there
in the folder.
Hopes this helps.
Sincerely,
HeavyDLB
Posted on Jun 01, 2008
Pyrhyc
  • 2028 Answers
SOURCE: Problem installing windows XP
This is going to be either a bad disc or a bad hard drive. Do a hard drive test in the bios, if any part of it fails, then you will need to replace the hard drive. If the hard drive passes, then try a different operating system disc.
Posted on Aug 13, 2008
SOURCE: permission denied error when access hidden folders
ابي الثيم بأي طريقه ما عرفت لي اسبوع ادوره ما جبته
Posted on Sep 20, 2008
  • 2427 Answers
SOURCE: File is not accessible. Access is denied message
Hi.
Sorry for the delayed responce. Ok first thing is first. The "files/folder is not accessible" occurs because the program cannot find the files in the place where they should be. for example if you put your socks in a draw and your wife moved it, when you return you wont have axcess to them right :) will basically its the same thing here. What you will need to do is find the default directory of itunes it should be in the Options or tools ir settings menu (I dont use itunes so i am not sure just play around in the program until you find it) once you do you need to search you computer for where the PC Backup put your files ..
click start then search and type the name or piece of the name of a song you know should be there. Once you find it browse to the directory of where the song is located. Click start then my computer then local disk to get to your harddrive. Go to the folder that has the songs and copy them. then paste them into the directory where itunes is looking for them.
Posted on Nov 13, 2008
SOURCE: operation could not be completed (error 0x00000005)access is denied
This worked for me. Go to control panel, look for printer in the hardware and sound section. click on it. Right clikc on it, and run as administrator. Cancel all documents, and that should be good.
Posted on Mar 06, 2009
I cannot retrieve image from computer when camera is attached to computer...Canon software has been entered
Consider NOT attaching your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Canon ZoomBrowser or any other photo cataloging program.
Aug 27, 2010 | Canon PowerShot A520 Digital Camera
How to delete access denied files?
Install and use  http://ccollomb.free.fr/unlocker/
Mar 16, 2010 | Microsoft Computers & Internet
Canon zoombrowser ex ver 6.4.1 with windows 7
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use ZoomBrowser or any other photo cataloging program.
Feb 20, 2010 | Canon PowerShot S3 IS Digital Camera
Error message: access denied
go to ur control panel and make sure ur not useing a guest profile u must be in a admin.profile to change any files and try deleteing all passwords for ur admin. profile this should fix it
Mar 27, 2009 | Dell Inspiron 6000 Notebook
Aug 13, 2008 | Dell Inspiron XPS M140 Notebook
Dear binghau:
in the folder.
Hopes this helps.
Sincerely,
HeavyDLB
Apr 17, 2008 | Canon PowerShot A520 Digital Camera
Help
Here's the support site for your camera. Click on the "Downloads and Drivers" tab, select your operating system, and then download the appropriate driver for your system (note some OS don't require a driver.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=221&modelid=11125
You can also download the "Zoombrowser" program here, but it's 72 megs, and might take a while.
Feb 22, 2008 | Canon PowerShot A520 Digital Camera
Uploading images
I have the same camera, and the same issue. After a lot of research I have come to the conclusion the A520 will not allow this.
Dec 07, 2007 | Canon PowerShot A520 Digital Camera
Cannot Download pictures from camera to computer
There are numerous solutions for importing digital pictures from your camera to your hard drive. You can use Windows Explorer. By doing this, u maintain complete control over where ur digital images are stored on the computer. If you prefer to use an external application, Google's Picasa remains the best solution available. In addition to being a convenient way to manage your images, Picasa also includes common photo editing functions, supports some of the best photo organization works with low level photo data from your camera, and assists in uploading images to the Web or creating slideshows on your local system. Picasa uses the timeline features that shows when images were taken in relation to all your other images (which only works if your digital camera is set to the correct date). Picasa is free for Windows 2000, Windows XP, and Linux.
Oct 14, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Cameras Logo
212 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
