Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
Cannot pull the pull rope. Feels like motor is froze but when I pull the pull rope cover off the pull rope pulls freely and I can turn the fly wheel by hand easily. Put everthing back togeather it will not pull.
    Problem Solver:
  • 9 Answers
PISTON COULD BE SEIZED DUE TO LOW OR NO OIL MIXTURE,ALSO IT COULD HAVE FUEL IN THE CHAMBER,FIRST REMOVE SPARK PLUG--NOW TRY TO PULL IT--HINT,STICK A SMALL SCREWDRIVER IN THE HOLE AND SEE IF THE PISTON RAISES AND LOWERS,,IF IT WILL RAISE/LOWER BY MANUALLY TURNING THE CRANKSHAFT,THEN THE PROBLEM IS IN YOUR INNER PULL ROPE ASSY.(THERE ARE DOG EARS INSIDE THAT SPIN OUT AND GRAB THE FLYWHEEL WHEN IT TURNS)
Posted on Sep 08, 2009
Testimonial: "dallascuz was right on the money. It was oil in cylinder. Thanks a lot for the info. Harold"
I ran over a rock with my craftman 650 lawn mower and it now makes a funny cranking noise when I try to start it I changed the fly wheel key and it still doesn't start.
When you try to start the engine pulling on the rope, is it easier or harder to pull to turn over the engine? If easier there is internal damage as below, if harder there is internal damage as below. That cranking or grinding sound could be the rope starter or the clutch of the rope start. So when you have the cover off of the flywheel pull on the rope and see if it makes the sound you are hearing and check the clutch that threaded onto the the crank holding the flywheel in place see that it turns in freely in the opposite direction of the engine running.
You may have bent the crank, take the spark plug out, put the mower on it's side with the carburetor on the up side and turn the mower blade by hand and see if you can tell if there is a wobble. While you have the spark plug out, look in the plug hole while turning over the engine to see of the piston is moving up and down. Another possible problem the cam gear could be broken and the valves not opening and closing in time with the crank.
Jan 16, 2015 | Garden
Starter cord will not pull
The pull cord or rope works on a tight spring just under the cover that the rope is in. Usually three to four small bolts on the edge of the cover to remove to repair/replace either the spring or the rope. First I would try to turn the motor manually with your hand on the flywheel, it should move around either direction freely with no effort. If it does not the motor itself maybe stuck not the rope. Then you have a seized engine and a different problem to deal with.
Dec 27, 2013 | Husqvarna 41 141 41 136 36 Recoil Pull...
My troy bilt trimmer tb20sc rope is hard to pull. It all of a sudden stopped working. Took it all apart. Pull on rope off of trimmer,it still works fine. Took off spark plug, piston is moving up and down....
Jard you need to check that the bottom head is clean and there are no obstructions. Then check that the coil is in tight and the nuts are not loose. Finally have you been using the correct fuel mix? Clean the fly wheel with some lubricant spray and sand paper and re assemble.
Aug 31, 2013 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Pull rope will not pull
Remove recoil rope assembly. Ensure rope is properly wrapped around. While recoil assembly is removed use ratchet and socket to rotate fly wheel, remove spark plug first, observe compression and exhaust at spark plug whole during rotation of fly wheel. Clean or replace spark plug. Ensure oil is full. 30w. Set spark plug gap. Always use Stabile in gas. Replace coil rope is required. Purchased by the foot at any mower repair store.
May 12, 2013 | Toro Super Recycler Super Bagger Lawn...
Replacing a pull string on a lawn mower
This can be tricky depending on the brand. Most pull start systems will have 3 or 4 bolts on the fly wheel- puppeteer cover.when you take the cover off, it should all stay together. It will have a plastic wheel inside that the rope winds aroundand in the center of the wheel should have a bolt. Remove the bolt and remove the plastic wheel, but be careful it will have a wind up spring, but most newer models have an enclosed spring.you should see a hole in the side for the pull rope. Insert the rope through the outer sheild first and thenthen in theslot of the wheel(kinda like stringing a yo-yo) then insert the end of the rope on the side of the wheelwheel in the hole, and tie a small tight knot in the rope so it won't slip through.then put the wheel back in the shield, and wind up the rope around the wheel. You should feel the spring tighten up. Don't let go of the spring tensioned wheel and rePlace the center wheel bolt. The handle should sticking out the sheild hole. Now replace the assembly on the mower. Some models you have to wind the spring and hold it tensioned with a wire while you replace the sheild, this tricky. But most wind upwhen you pull the rope out. So when you release the rope the spring will wind it back up. Good luck this task can be tough for first timers.
Jul 31, 2011 | Briggs & Stratton Garden
Tiller seems locked up. was tilling in recently dead lawn from round up application and was getting lot of build up of dead roots and wet ground. pull rope would not turn the flywheel. took pull...
I have a similar problem, found the transmission to be jamming up in a certain spot. You can get a replacement transmission or parts on EBay
Jun 24, 2011 | Mantis 2-Cycle Tiller
The pull string broke how. how do i put the new one on?
Go to a hardware store and ask them if they have ant bulk pull starter rope. Buy about 3 feet or so of the small stuff (it is only 30 or 40 cents a foot, cheaper that the kits) Remove the motor cover with the pull start and turn it so you can see the wheel inside. Remove the knot that held the old rope in the handle and then cut the knot on the starter wheel and pull out the tag left in there.
Now the fun part. The wheel is spring loaded and the spring has no tension on it after the rope broke. Wind it up like a clock spring until it is tight then back off until the holes where the cord goes line up. Stick a small screw driver, nail, ect in the slot to keep it from unwinding . Do not tie the handle to the cord yet. Slide the new cord through the hole in the cover and wheel and then tie a knot in the cord and pull it snug in the wheel. Hold the rope and remove the pin and let the cord slowly wind itself up. Run the cord through the hole in the handle, Adjust to the length of pull you want and tie another knot.
Reinstall the motor cover (if it binds and wont go on, pull the rope just a little bit to line up the crank with starter wheel and it will slide down.)
It sounds a bit windy but it really is a simple fix.
Jun 09, 2010 | Troy Bilt Tiller/Edger 26cc, Model No....
The tiller stalled out and now won't crank. Why?
Was there oil in it? Check and see if a rock or other item is wedge in the tines. Take of the engine shroud, remove the spark plug and see if you can manually turn the fly wheel. If you CAN turn the fly wheel pull on the pull rope. It might just be stuck. If you CANNOT turn the fly wheel then the engine is probably blown.
Good luck hope this helps.
roundo4
May 23, 2010 | Troy-Bilt Pony Garden Tiller
I 'm trying to pull the rope and it will barely--honda pressure w
The rope may be bound up in the recoil. Take the recoil cover off(the piece where the pull rope goes into) and try to pull the rope with the housing off. If it pulls freely try turning the engine by hand, you may want to remove the spark plug to release the compression. If the unit will not turn over,then the pressure pump may have failed. Best of luck.
Apr 23, 2010 | Honda Karcher G4000RH Pressure Washer
How to assemble pull cord
Remove engine cover. Try turning the inside where rope goes counterclock wise then let go (watch your fingers so you don't get pinched. If it spins back remove the rope and and turn the inside till you get some good tension. Put a screw driver through the fins to hold the inside in place so it doesn't unwind. Make sure you line up the hole in the inside so the rope will go straigh through the hole on the shroud and the inside wheel. Tie off the rope and hold the rope and remove the screw driver and slowly let rope back in. Pull a few times to check before reinstalling. Also check the inside wheel. There should be in the center of the wheel a bolt that holds on a flat piece of plastic and under that directly across from each other is two little tabs that engage the fly wheel. Make sure they are both properly seated. If it recoils when you test it reinstall and try starting mower.
Good luck and let me know if this helps
roundo4
Aug 13, 2009 | Mtd Garden
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
743 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
