Question about Garden
My jonsered 2050 will not start and there is a feul line that comes up out of the left side of the carb (from the gas tank) and goes to the right it is broken at the other end and I can't see anything it would go to
    Problem Solver:
  • 5 Answers
My 2040 was not getting gas. I just looked for a solution online and could not find the answer. So, I went back to it and unscrewed the air filter. Not touching the 2 screws that tighten the carb, I loosened the screw holding what looks like a top plate and also backed out the idle, high mix and lo mix. Then I carb cleaned her up. First pull she went. I had been messing with her a while now with pre-mix in the carb and under the plug but the carb clean seemed to do the trick...rots a ruck
DonR
Posted on Sep 12, 2011
    President:
  • 2,220 Answers
I found an IPL here but it isn't good. Page J shows your fuel system but I'm not certain the hose shown isn't for bar oil.
http://www.jonsered.ws/21452150.pdf
You might try here.
Beg for manuals thread
http://www.arboristsite.com/showthread.php?t=72322
At the top is the [Search this Thread ▼] tab. I did a search for Jonsered 2150 and got 3 hits; 2 for "workshop manuals" If you need to join it is free. They are a collection of chainsaw enthusiasts and will be very helpful. Your saw is considered good; you won't need your flak vest. HTH
Lou
Posted on Sep 08, 2009
Craftsman 33cc weedwacker rep lace fuel lines
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, hh
Feb 21, 2012 | Craftsman Garden
Tip
Poulan 2050 fuel line routing & replacement
If you were like me, you can't find anything specific on the Poulan 2050 fuel line routing. However, I have just completed this task successfully and this applies to an engine that has a Walbro carburetor, with an inlet at the top right and bottom left. The smaller diameter tubing which runs from the tank and is connected to the fuel filter in the tank goes to the nipple which is on the top of the carburetor, period. There are two lines running to the primer bulb and one goes to the bottom left side of the carburetor and one goes to the line running into the tank. If you have an original primer, the lines on the primer itself may not be marked, so you may have to switch them around to get them right. When they are right, fuel should travel from the tank, up the small diameter fuel line, through the carburetor and the excess goes back into the tank through the primer. Simply switching these lines around on the primer will solve the problem. An easy test is to remove the supply line (the one that comes from the filter) from the carb nipple and pump the primer. If gas comes out, then you have it right. To replace the actual fuel line and filter is easy enough as well if you cut the end of the small line on a diagonal of about 2" or more so that it easily slips through the hole in the upper part of the tank. Then simply grab it with a pair of needle nose pliers and pull it down slowly until you can feed it using your left hand to pull, right hand to thread. I am not a mechanic but this is exactly how I did it. Hopefully this simple description is helpful and yes, the nipples on the carburetor are repectfully input and output but determining which is which is not often easy, so that is why I specifically talk to a Poulin 2050 model. Now replacing the trigger assembly is another matter which I need to learn about.
on Oct 27, 2011 | Poulan Garden
Fuel line diagram for sears mini cultivator
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, ``
Feb 17, 2012 | Ryobi Garden
Internal line in gas tank came loose
Jan 23, 2012 | Homelite Mighty Lite Lawn Trimmer
I need the fuel line routing diagram for a Craftsman Model No. 358.791510 Weedwacker 32cc/1.9 cu.in. 2-cycle
Jan 18, 2012 | Garden
I have a Craftsman's Gasoline Weedwacker model 358.791580. The weedwacker wouldn't start after priming and choking. I observed the fuel filter inside the gas tank unattached because the fuel l
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, oo
Craftman trimmers has two gas lines wich one goes to the primmer the one with the filter or the thine one
Jan 09, 2012 | Garden
Poulan chain saw model #2025 - fuel lines dry rotted and disintegrated. There are 3 fuel lines: l from gas tank and 2 from primer button but only 2 fuel ports on the carb. What goes where and how?
You should have 2 to the tank, the one with filter coming from tank goes to nipple on right side of carb, the nipple on left side by primer bulb goes to primer bulb and other from primer bulb back to tank as return line, how it should work is when you push primer bulb it pulls fuel from tank through carb and back to tank on return line so watch in tank orleave one line out that you think is return line and see if gas comes out when you prime, but remember it goes through the carb first before it goes back to tank, had a pic but too big to put on site sorry, 2StrokeJim
Oct 11, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a Jonsered 535 and recently replaced a ring and cleaned it up. I went to put it back together and can't remember where the gas line on the walbro carb goes. The line I'm talking about is the...
This sounds like the hose from the tank breather, the hose goes from the tank on the l/h side to the cylindrical vent, then from the other side of the vent the hose goes around the back of the carb and out through the side of the crankcase with a sintered plug in the edn, there is also a hose from the cylinder base, this is the impulse tube and fits to the top of the pump cover of the carb,
Jun 14, 2011 | Garden
Poulan 2050 chainsaw. Fuel line routing. Replaced all fuel lines. Primer bulb is marked Tank and Carb side. Tank side is for larger line and runs into tank and fuel filter. Carb side is smaller diameter...
Replaced my fuel lines on poulan 2050 today. The large diameter line is a return line from the primer to the tank. The smaller diameter line is the supply line from the tank to the carb. You need to cut this line and run a second piece of small diameter line from the card to the primer. I'm not sure if it makes a difference which of the two stems on the carb is the inlet or outlet line. I used the top stem as the inlet, and connected the bottom stem to the primer. My chainsaw started right up. So I either got lucky or maybe it doesn't matter.
Apr 14, 2009 | Garden
Garden Logo
1,312 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
