Question about Rheem RTG-74PVN-2 Natural Gas Pronto Whole House, Natural Gas, Tankless Wat
53PVN shuts off after a few minutes
My new 53PVN shuts down after a few minutes, with the error code C4 13. It is very well ventilated, nothing in front or on the sides. I am at 7000 feet but without a high-altitude chip. Could this possibly be the problem?
  • 3 Answers
Yes and because it wasn't running clean the oxegen depletion sensor needs to be cleaned.
There is also small orfice on the burner that could also be dirty. If you are not very handy call a pro
Posted on Sep 10, 2009
Rheem rtg-53pvn will not turn on and heat water when hot water is turned on - no error code - remote just goes off like the power is off
Before calling service technician, open following link for Rheem troubleshooting resources including Rheem chat:
Rheem will suggest you catch up on required yearly maintenance which would cover most causes for common error codes, and cover cause of no error code including plumbing problem or loose wire or PC board failure. Combination of problems can also cause failure and these issues would be covered by general maintenance.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Solve most tankless problems same day for $350
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Jul 21, 2011 | Rheem RTG-53PVN Indoor Natural Gas...
Error code c7 76 disconnected remote started heater had hot water for a few minutes then back to original problem. No hot water.
Before calling service technician, open following link for Rheem troubleshooting resources, and contact information:
Error codes are considered start place for troubleshooting:
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
Error code troubleshoot indicates: replace PC board if water heater does not function without remote.
Add a comment and say what you did to fix problem.
Jun 15, 2011 | Rheem RTG-53PVN Indoor Natural Gas...
I AM GETTING AN ERROR CODE OF C7 76 ON THE REMOTE WHAT DOES IT MEAN?
means that your remote panel is no good. remove cover and disconect the 2 wires. put cover back on and plug in. if that gives you hot water call the company and tell them you have a code76. they will send you a new panel for free over night
Jan 17, 2011 | Rheem RTG-53PVN Indoor Natural Gas...
Thermostat flashes IL ? Model PTG-53PVN
http://www.palomatankless.com/owners/homeowner+trouble.lasso#28-11
The Controller displays error code "1L."
There is a build-up of lime in your Paloma.
Contact your plumber to service the Paloma by flushing out the lime.
Also search u-tube for flushing lime out of tankless.
Dec 29, 2010 | Rheem Paloma Tankless Water Heaters...
Just installed a reem rtg tankless unit fires up then shuts down and flashes c7 12 the until will work if I balance water valve way down
I am a free answerer, and I specialize in giving you resources for free
The paid answerers may have a person who knows your product and the error codes
The manual will also have the error codes.
The person who installed the unit will also know the error codes (or should know)
Each day I see 20-25 unanswered questions about tankless water heaters.
The number of questions shows the complexity of the machines, and the inability of the manufactures to take care of their customers.
The manufacturer will refer you to the installer.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
http://www.rheem.com/products/tankless_water_heaters/
The link above goes to Rheem tankless water heaters
Click on a product and it opens a page showing many tankless models
Click 'more information' and another page opens with spec sheets and other pdf
Not surprisingly there are no troubleshooting steps or troubleshooting flowcharts
There are plenty of ways to buy a tankless
There are not many ways a do-it-yourselfer can fix a tankless
Oct 30, 2010 | Rheem RTG-53PVN Indoor Natural Gas...
Error codes c4 76
contact rheem it sound like the circuit board is gone
Jun 13, 2010 | Rheem RTG-53PVN Indoor Natural Gas...
How do I delete the stored error codes on my Rheem RTG-53PVN tankless water heater?
Some error codes cannot be reset...Example would be P/S failure on the PCB. Any other error, if you remove power for approx. 2 min - error should clear. - if not you need to contact Paloma/Rheem customer (800-432-8373) support
Nov 24, 2009 | Rheem RTG-53PVN Indoor Natural Gas...
Rheem tankless water heater error code C4 13??
check diaphrapm valve or micro/switch best of luck
Sep 13, 2009 | Rheem RTG-53PVN Indoor Natural Gas...
Rheem RTG 53 PVN with fault codes C4 or C7
I had the same problem with my tankless waterheater (flashing c4 76 alternately). I called Rheem
tech support and they had me 1 power down the remotepanel 2 unplug the unit from the wall 3 remove the cover 4 remove the wires for the remote panel from the circuit board and pull the twisted pair that goes to the remote out from the bottom of the unit. 5 reinstall the cover 6 plug the unit back
into the wall and turn on the hot water see if it works. It did in my case and they are sending me a new remote panel. I hope it helps.........
Nov 21, 2008 | Rheem RTG-53PVN Indoor Natural Gas...
Rheem RTG-74PVN-2 Natural Gas Pronto Whole House, Natural Gas, Tankless Wat Logo
112 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
