Question about Ariens Garden
While cutting the grass the pto seemed to quit. I turned off the mower and haven't been able to restart it since. The starter is good and the spark plug is new. I'm thinking a switch or interlock of some kind is bad. Where do I start looking?
You probanbly have an electric switch that turns the blades on and off, the back of the switch has 6-8 spade type connections,this is because it not only runs the blades but the interlock that won't allow the motor to start.,Just buy a new switch they cost about 50-75 bucks depending the crook you have to deal with. Good Luck. it would be nice to have a littlemore information, but it sounds typical of all of those size units.
Posted on Sep 08, 2009
Changed filter, oil, full of gas checked gas flow everything is good , when I start m lawn mower it runs , when I engage my pto and start mowing for about 5 minutes it just quits
if this is got the 27 hp kohler engine, I know exactly whats wrong with it , due to grass and engine oil building up in a short time under cylinder heads , it actually makes a tight ball of grass and stuff there !! this holds the engine heat and ruins the ign module that's just above it there , I put two on in one season ( tractor runs 6-10 hrs day 6 days a week ) I finally gave up I bought a Kawasaki 27 hp twin and installed it , now its run for two seasons and no problems
engaging the pto has nothing to do with it , it would cut off if you just drove it around for 15 minutes
Sep 15, 2015 | Toro 52" 27hp Z Master Zero Turn Lawn...
Was running turned off and now want crank over no click nothing, headlights work.
the deck safety switch is bad,number 10 in diagram,
25716023-ghuqylfbvqx2ddmcce1obb43-5-2.png click on this in the link to get your manual, http://www.cubcadetpartsnmore.com/47.html then click on this number,13WF91AP010,
May 27, 2015 | Cub Cadet 2011 - LTX 1050 - 22 HP Kawasaki...
How to troubleshoot pto will bog down engine when you try to engage pto
when was air filter and fuel filter changed? are all pulleys turning free? spark plugs good? if everything seems good is motor wore out?
Sep 13, 2014 | Garden
Why doesn't my Toro z master PTO not engage
check to see if pto will engage if not check voltage at pto if non blown fuse if fuse not blown and power to pto bad pto jump the pto at pto with battery in mower does it start pto if does good pto have to check volts at switch check there start with that let me no what happened
Sep 04, 2014 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
Why does electric clutch click and seems to be getting no spark
While sitting in the seat with the ignition key on you should be able to hear a click from the pto clutch when the pto switch is activated but this click is audibly different from the click of the starter solenoid. The starter will be disabled if the pto switch is on. If you hear the pto clicking while trying to start then there is a failure in the pto switch. If the starter solenoid was bad the starter would not engage. Check ignition switch, pto switch, and look for wires melted together. Also be sure grounds are good. PTO clicking on start and no spark could have a relation with the pto ground and engine kill wire.
Sep 01, 2014 | Garden
How do i restart my cubcadet model cc46es after it stalled because of grass
disengage pto start up move to alredy mowed area shut off and clean grass from under deck restart it turn on pto cut grass
Jul 11, 2014 | Cub Cadet Garden
Tractor?troy bilt/mtd 2002
the electric clutch that operates the blades needs replaced
Sep 22, 2008 | Garden
Garden Logo
116 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
Are you an Ariens Garden Expert? Answer questions, earn points and help others
