Question about Brother MFC 210C All-In-One InkJet Printer
I have a problem with my brother MFC 210C printer. The magenta ink does not come out. what can it be?
  • 30 Answers
SOURCE: Brother MFC 210C series ink replaced
The brother machines require ink in all the cartridges as it is always flushing ink through the heads to "clean" it. This means you must have ink in all cartridges at all times unfortunately or the brother will not work. Even if you could somehow get it to work it could damage your printhead anyway.
Good Luck
Please rate my advice, good or bad.
Posted on Feb 06, 2008
  • 271 Answers
SOURCE: MFC-210C Error: "No Cartridge"
SOLUTION FOR EMPTY CARTRIGE ERROR MESSAGE...
1. UNPLUG PRINTER AND USB CABLE.
2. UNDERNEATH PRINTER SECURE WOUND CABLES.
3. CARRY PRINTER, TO VEHICLE AND PLACE BEHIND REAR TIRE.
4. PUT VEHICLE IN REVERSE MAKING SURE FRONT AND REAR TIRES MAKE REQUIRED PRINTER ADJUSTMENTS,.
5. PICK UP PIECES AND PUT IN RECYCLE BIN.
6 BUY DIFFERENT BRAND OF PRINTER.
7. PROBLEM ELIMINATED, NO MORE STRESS.
Posted on Feb 18, 2008
SOURCE: Brother mfc MFC-5440CN magenta issues
You cant print in ANY color when it says NO CARTRIDGE for any one color. Sucks.
Posted on Jun 25, 2008
SOURCE: vista and brother MFC 210C
download the driver click here
Posted on Jul 14, 2008
faxman789
  • 297 Answers
SOURCE: Brother MFC-210C All-In-One InkJet Printer ERROR 4F
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds.
This should put you in the maintenance mode menu.
Enter 80, then scroll down with the arrow down (round) key.
You'll find an entry listed as purge count.
If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then restart you printer.
Posted on Jan 22, 2009
The printer is not printing magenta, I've tried different ink cartridges and multiple cleaning to no avail. What now?
Were the new ink cartridges, Genuine Brother Cartridges?
Brother does not like gereric !!!!!!!!!!!!1
Good Luck
Feb 05, 2010 | Brother MFC 210C All-In-One InkJet Printer
I have also problem with the magenta
Check your ink cartridge if they are properly installed.
Check your cartridge if they are empty.
Make sure you are using original cartridge and not just a refill cartridge.
If still nothing happens replace your cartridge.
Sep 08, 2009 | Brother MFC 210C All-In-One InkJet Printer
Unable to clean message
Remove the ink, turn off the printer. restart the printer then reinstall the ink
Nov 08, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210c-Just replaced ink cartridge & it is already empty
I gave up on this printer and bought a new one from a different manufacturer.
Oct 01, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother model 210C all in one printer
i've expirienced that with my magenta ink... just try to remove the ink cartridge and then put it back again :D
Jun 06, 2008 | Brother MFC 210C All-In-One InkJet Printer
I have error 29 on my 210c
!!!! Magenta ink error !!!!
The ink has run out or the ink cartridge is not set into place.
26: Black ink
27: Yellow ink
28: Cyan ink
29: Magenta ink
1. Reload ink cartridges, referring to the Owner's Manual.
2. Ink cartridge PCB defective Replace the ink refill ASSY.
3. Cannot detect ink cartridges.Main PCB defective Replace the main PCB.
I know your machine was not originally showing signs of main board fault or Ink supply issues, although main board can be killed by incorrect use of maintence mode.
Nov 14, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-215C leaking ink
Buy a new printer ....unless it is a dodgy refilled magenta ink that is leaking,  if you are indeed using genuine Brother Inks then it will need a purge unit which is too costly to repair
Oct 17, 2007 | Brother MFC 210C All-In-One InkJet Printer
Empty magent
Magenta is the colour of one of the 4 inks used in your printer. You need a new magenta ink cartridge because it's empty.
Sep 21, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
46 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
