Question about HP PSC 1610 All-In-One InkJet Printer
I have a hp PSC 1610 all in one printer, connected to a hp desktop computer. I have a lynsys wireless router connected for a wireless network in the house, the desktop is the main computer for this network. I want to be able to print form other computers in the house to this printer wireless. I have a hp jetdirect 175X print server. Will this work if so what are the connections I need to make and what drivers or software do I need.
    President:
  • 1,187 Answers
Two ways to do this:
Since this is a USB printer and not a network printer you have to create a "share":
1. On the main computer that has the printer attached, go to the printer properties (START, PRINTERS AND FAXES, Right-click on the printer icon and select "sharing"
2. Select the Sharing" tab and select "Share this printer" radial.
3. Enter a short name for the printer in the "Share Name" box, such as: HP1610
4. Save that configuration and remember the "Name" you gave the share.
At each computer on your network:
1. Go to the printer setup sceeen (see #1 above)... and "ADD A PRINTER"
2. Select "Network" printer (not local printer)
3. Select "search for printers and the HP1610 will appear on the list.
4. Select it and follow the instructions from there...
Hope this helps!
Posted on Sep 08, 2009
Is the HP PSC 1610 all in one printer....Wireless capeable?
HP PSC 1610 is not wireless. You can connect via USB to computer width wireless and share them.
Nov 13, 2010 | HP PSC 1610 All-In-One InkJet Printer
WRT160N Wireless Router : i just bought a new laptop and a lynsis wrt160n......
The wired and wireless speed will always be different.
The maximum wired speed will be 100 Mbps. That means the wired connection is working properly.
Wireless connection speed will depend on the router and the wireless adapter on your computer.
If you are using B-Adapter then max speed will be 11 MBPS. IF it is G-Adapter then max speed will be 54 Mbps.
The N-adapter will give you more speed.
Check in the Device manager which adapter you are using on your wireless computer.
One more thing you can try changing the wireless channel on the router.
You will need to access the router settings page.
Update the drivers of your wireless adapter on the computer.
You have WRT160N router.
This router has issues with the Firmware.
Is there any computer connected to the router with the cable.
If not then you will need to connect the computer to the router.
Download the firmware of the router from the manufacturer's website.
enter the model number. select proper version number and download the firmware of the router.
Once you download the firmware, you will need to open the router set up and upgrade the firmware of the router.
After upgrading the firmware, it is recommended that you reset and reconfigure the router.
Click Here for more information about router and networking
May 07, 2010 | Linksys WRT160N Wireless Router
I upgraded my Mac mini to Snow Leopard OSX 10.6.2. Reloaded the printer software but the printer wont print. THe printer is connected via USB. When I send a document it shows error on the printer queue....
HP PSC 1610 All-In-One InkJet Printer Printer HP PSC 1610 always printed till I... Answer I think I have a similar problem:HP PSC 1610 always printed till I installed Mac OS X 10.6. also does not digitalize since I downloaded: HP_Installer_PSC1600_v9.7 An error apears about a missing extention ? ? ? ? Carlos Moniz
Feb 02, 2010 | HP PSC 1610 All-In-One InkJet Printer
Can the HP PSC 1610 All-In-One InkJet Printer have wireless networking?
If it have a network connector, just link it to a wireless access point in client bridge mode. Sure it works.
Nov 16, 2009 | HP PSC 1610 All-In-One InkJet Printer
I want to add my PSC 1610 as a network printer (it's attached to a print server device). When adding the network printer windows asks for the *.inf file... I can't find this file on the installation disk...
i have the same printer- unplug the printer usb cable- un-install the printer- plug the usb back in. when the new device wizard comes up, tell you have cd. insert install cd- browse for your cd device letter- choose that. then re-install printer- full install! will prob. ask you to 'name' your printer!- write down that name! you'll need that, as well as your psc 1610 i.d. then , if your computer is the net-work comp., you need to set it up on control panel to share. then check other computers on network and see if they 'see' the hp psc 1610 and then add them to printer sharing- this is where you'll need the 'name'. i had less problem with w98se, than i did with xp pro or home! love you, microshaft!!
good luck!
Nov 09, 2009 | HP PSC 1610 All-In-One InkJet Printer
I am trying to access an HP 1200 psc over a home network
Have you set up the printer to be shared via the network? You can usually set this up in printer options, through control panel. If the wifi is a closed network, so much the better. That way, nobody else can use the printer. You should be able to do this easily, as long as both computers are connected to the wireless network.
Oct 22, 2009 | HP PSC 1210v All-In-One InkJet Printer
Connection of HP PSC 950 All-In-OneInkjet to Wireless N network
since your printer dont have NIC or network card..there are 2 option to connect it to your local network
Option 1
Go to Control Panel
Select Printers and Faxes
Right Click on the Printer icon
Select Sharing
then Configure it
Option 2
Buy Print server Port (Wired or Wireless)
depends on cable interface on your printer (USB or Parallel)
Mar 13, 2009 | HP PSC 950 All-In-One InkJet Printer
Can't get psc 1610 to print on new macbook wirelessly
If you install the Hp wireless driver on your Mac, that should do it.
Aug 18, 2017 | HP PSC 1610 All-In-One InkJet Printer
Need help with HP PSC 1610
You need a USB printer cable. You can get that at any computer store
Sep 25, 2008 | HP PSC 1610 All-In-One InkJet Printer
Connecting 2 PCs to the HP PSC 1610 Printer at the same time
Hey,
This usb printer can only be connected to one pc at a time, you could use a USB SWITCH to connect both computers to the switch and printer into the other end, so with the press of a button you could connect the printer from port 1 (pc1) to port 2 (pc2)
Click here
Thanks,
Ekse
Aug 30, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
169 people viewed this question
Seeker5211
Seeker5211
