Question about Vector Electronics - Others
Where can I get a wiring diagram for the vector 800 w inverter (model # vec046).
2 Suggested Answers
  • 608 Answers
SOURCE: vector 2500 watt inverter red led fault light no
There is a fuse on these things at the back of the case. Could be in a slide out plastic holder, or in a round holder with a knurled screw or bayonet type cap. If this fuse is not blown, then the news is not good.
Posted on Mar 21, 2010
Circuit diagram
Proprietary info. Good luck on that
Oct 06, 2013 | Vector VEC056D 2500 Watt Power Inverter...
Manual for black and decker 1200 watt invertor
some idea for inverter, collect inverter circuit Books from market.
May 28, 2012 | Black & Decker Vector Cable Kit for 1200...
I have a auto pro 800 watt inverter that gives 220volt ac **** wont run my kellerman freezer it runs in the house on ac can you help
If your freezer need more than 800 watts to run then your 800 watt inverter will be overloaded and it will shutdown.
Mar 21, 2012 | Vector 1000w Power Inverter
Plugged it into the recepticle in my2009 trailblazer, and it started smoking. removed it quickly
Hello Dusty,
Sounds like your inverter was already having issues. Otherwise, the power port in your trailblazer is wired backwards (center contact should be positive, barrel or ring should be negative).
Aug 26, 2010 | Inverter Vector Power - 70 Watt, Model...
I need help hooking my vector maxx sst 1000 w power inverter to my car
A 1000 watt power inverter hooks to the battery terminals directly, not through the cigarette lighter.
Jul 20, 2010 | Vector 1000w Power Inverter
Vector 2500 watt inverter red led fault light no output. Model veco56d.
Mar 21, 2010 | Vector 2000w Power Inverter
Need to buy the wall charger for my vector model vec 013 battery jumper
Call Vector and order what you need
Vector Products Customer Service # 1-800-618-5178
Feb 25, 2010 | JUMP START SYSTEM
Power inverter installation?? (Vector 2500W in Tacoma truck)
Don, There are two ways in which I would have satisfyied the 6 foot guide line. 1. Mounted the VECTOR under the hood. 2. Supplied the VECTOR with additional "bed mounted" battery to be charged via the present wiring with a two pole single throw "knife switch" as as the "connect/disconnect to the vehicle battery/alternator for charging the new battery. In any case, you should make it a twice yearly thing to inspect the 15 feet of wire now installed, for wear and tear faults that could result in sparks, smoke, fire. You may need to visit local electrical supply house to see what they have to offer in the way of small "breaker-boxes" that may be capable of handling such large GAGE wire. I MEAN #2 gage wire IS very thick and expensive per foot!!!! A disconnect box similar to type found mounted to brick-work and next to and connecting a 1.5 to 2 ton central air unit might do the trick. But anyhow, if you are not going to use the VECTOR disconnect the POSITIVE lead at the battery and tape the connector with electrical tape to be safe. Let me know how it works out for you. lmistyrel@ aim.com 12fixlouie
Nov 24, 2009 | Vector VEC056D 2500 Watt Power Inverter...
Electronics - Others Logo
613 people viewed this question
Top Vector Electronics - Others Experts
Matt Olenzek
Matt Olenzek
Are you a Vector Electronics - Other Expert? Answer questions, earn points and help others
