Question about Panasonic PT-43LC14 43" Rear Projection HDTV
Unit shuts off at random
This TV shuts itself off at random and the picture is not very bright.It is about 2 yrs old with the original bulb.It shuts off more when you first turn it on.The problem persists for about a hr and then might be fine for the rest of the day.Picture is hard to see in a lighted room.Are other LCD projection TV's have the brightness problem?
  • klpnut Dec 09, 2007
    Thanks for the info...Will the bulb cause a low brightness problem...even though the bulb is still working partially?
    Scholar:
  • 137 Answers
You have a defective Lamp. The lamp part number is TY-LA1000
Posted on Dec 09, 2007
  • Mervin Guy
    Mervin Guy Dec 09, 2007
    Yes, This will also caused Low Brightness
The TV will shut off by itself randomly (anywhere
Sounds like the TV is going into the "protect mode", usually means there is a failure present and it's shutting down to ward off any serious damage to the electronics. The status light will usually blink a error code along with this symptom, call a service center and let them know how many times the light is blinking in a continious pattern and that will help them to diagnos your TV problem. Good luck and Merry Christmas!
Dec 25, 2009 | RCA D52W135D 52 in. TV/DVD Combo
Intermittant shut down with blinking green light on Sony TV 55"
Hi,Make sure you get the Original Philips lamps since they last 6000-8000 hrs 2-4 yrs,way better then Osram which last 4000-5000 hrs 1 - 1/2 yrs.
Oct 01, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
No power no picture no sound
i would say that its time to put that tv to rest is it a projection tv? if it is then it may be the bulb but i would recomend just getting a new set because repairing your current one will cost alot and wont last long so a new one is a better option
Jan 07, 2009 | Televison & Video
Tv shutting off timer light blinking
Your TV is in the protection mode. First, locate the horizontal output transistor. This is found very close to, or next to, the horizontal output transformer (also known as the flyback). The flyback should be on an aluminum heat sink, or on the side of the metal chassis. Disconnect or unsolder two of the three legs of the transistor. Measure it with your meter, or plug in the set with the light bulb attached across the fuse.
If the transistor is shorted, or the light bulb doesn’t glow bright anymore, replace the transistor and plug back in. If the light bulb glows bright again, you must replace both the flyback and horizontal output transistor simultaneously. In some cases this will fix the set, but sometimes there are multiple problems with a set.
Go to where the flyback is, and start measuring the diodes and capacitors on the flyback itself. If you don't find any shorts there, it could be a shorted vertical output IC, a shorted sound IC, a shorted disc capacitor in the Hi Voltage/sweep circuit, or in rare cases, a shorted capacitor or tuner.Feel free to ask and post whatever the result of your troubleshooting..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 30, 2008 | JVC AV-27D303 27" TV
Screen Brightness
What lamp did you replace it with? Some of the aftermarket bulb sources are not the original brand and do not work as well.
Dec 31, 2007 | Panasonic PT-43LC14 43" Rear Projection...
Sony KDF-E55A20 Lamp Shut Down with no blinking lights
If you TV is about 2 1/2 yr you probably need a new lamp they only last about 3 yrs. Mine popped one night and now picture comes in for about 1 min and goes out, I ordered a new lamp today they run $199. There is also a know issue with the thermal fuse. The part cost about $3 and if you know a lil about electronic you can replace it yourself
Nov 11, 2007 | Sony KDF-E55A20 55 in. LCD Television
Panasonic PT-43LC14 43" Rear Projection HDTV Logo
109 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
