Question about Kenmore Dryers
My dryer causes the breaker to trip - Kenmore Dryers
  • Kenmore Master
  • 5,344 Answers
What type of circuit breaker is there? Is it a GCFI (ground fault interrupter)? In that case, you should check for any water near the dryer that would cause an open circuit. Is the circuit breaker rated appropriately for the dryer's load on the circuit? With a circuit tester, you can check for a wiring fault.
I hope these ideas give you a starting place. If the wiring is good, the motor on the dryer is the source of the short. (My knowledge is limited on whether that would be a user fixable issue.)
Posted on Sep 08, 2009
  • 116 Answers
SOURCE: dryer internal breaker trips
If you are using dryer sheets in the machine the filter screen may be plugged and will have to be cleaned. You can check it by placing a bit of water on the screen if it beads and does not flow through then the screen is indeed plugged reducing air flow. There could be lint and build up in the dryer's internal ducting and sensors, the machine will have to be disassembled for a complete cleaning this will also reduce air flow and cause the machine to heat abnormally.
Posted on Mar 11, 2007
Kawika-56
  • 233 Answers
SOURCE: dryer causing circiut breaker to trip
Have you tried replacing the circuit breaker?
It may be the problem.
You do not mention how old the dryer is, or that model number does not tell me if it is gas or electric. (I wouldn't know)
Another thing you could try is to take the dryer apart and clean out the lint, you will also have an opportunity to replace any worn-out parts like the belt, or heating elements etc.
Working on a dryer is quite simple, if you have ANY mechanical capabilities.
Posted on Nov 22, 2007
Jimster
  • 240 Answers
SOURCE: whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
Posted on Feb 02, 2008
josecolono
  • 6 Answers
SOURCE: dryer keeps tripping breaker
THE BREAKER IS GOING BAD REPLASE IT OR THE BREAKER IS TO WEEK FORE IT TRY ANATHER PLUG
Posted on May 15, 2009
  • 43 Answers
SOURCE: Samsung front load clothes dryer not working.
may have loss to one line of voltage.may only have half the voltage required to power the machine.make sure proper voltage is coming to wiring block at bak of machine.may need voltage meter.
Posted on Oct 16, 2009
This is an update to my previous problem with my electric Kenmore Dryer Model #88042700. The dryer appeared to have no power. I had checked the breakers and thought the one for the dryer was on. But it...
There is a reason it's tripping..First I would have the dryer cleaned out it sound like the unit is full of lint and is holding heat also bad ventilation in dryer exhaused. If it's tripping it's electrical
hydeparkappliancerepair.com
Sep 08, 2013 | Kenmore Dryers
The dryer is causing the breaker to trip
check the entire venting system . possibly full of lint .
Dec 21, 2017 | Whirlpool LER4634J Electric Dryer
Dryer keeps tripping the circuit breaker
hello mam please change the mains breaker after tripping for several times the breaker will be defected and check the power socket outlet by removing the socket there should not be any loose connections and skinned wires.
Oct 02, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer Repeatedly tripping circuit breaker, Apartment Maintenance man said we had a defective dryer, Bought new dryer and 5 minutes after first load was put in it tripped the breaker, Maintenance man...
You probably have a bad plug connection, make sure all the wiring in there is tight, you may see signs of arcing. A bad connection causes resistance, and therefore causes the breakers to trip. It is best to replace the receptacle on the wall outlet with a new one because the problem will just resurface again soon.
Aug 12, 2009 | Dryers
Dryer trips circuit breaker smell almost like something burning coming from dryer
In order to trip a circuit breaker, there is almost for sure, a dead short to ground. Takes quite a bit to trip a breaker. The smell is most likely something electrical burning. Stop resetting the breaker and have it checked out. Continous resetting and tripping can cause more damage. The breaker is doing it's job.
Jul 30, 2009 | GE DVLR223 Dryers
The dryer will not turn on. I know I have power because the light is on. But nothing happens when I hit start
Check for a tripped circuit breaker (a ganged double breaker), sometimes only one breaker trips without tripping the other. Switch breakers off and then back on. If you have access to a voltmeter, check for 220 volts AC at the the two slanted slots in the dryer socket. Occasionally, one breaker of the pair will fail internally--replace the pair. If 220 volts is present, then problem is internal to the dryer. Usually, it is a short circuit in the heating element which causes the circuit breaker trip.
Jul 16, 2009 | Dryers
Help. My LG electric dryer, DLE5977 is not working
Hello berkyiu2002,
I'd be happy to assist you but an you elaborate on what happened? I can only assume you checked the basics...such as the circuit breaker has not tripped to the receptacle your dryer is plugged in to.. and the cord from the dryer is plugged in to that receptacle properly.. otherwise, please tell me what happened and when it last worked...
Regards,
Rick
Nov 29, 2008 | LG DLE5977 Electric Dryer
Kenmore dryer
first dryer should be on circuit by itself..if dryers runs ok for a while before tripping breaker call electrican to change breaker..change it not ck it ..too many times had electricans tell cust breaker ckd ok but after explaining to cust a breaker can not be ck without load they had breaker changed and solved problem ..not just old breaker but even new ones can cause problems..if breaker kicks as soon as dryer is turned on ck wiring at connection where ac is connected very seldom does any other issues with dryer cause immediate tripping of breaker
Sep 16, 2008 | Kenmore 63012 Electric Dryer
Dryer tripped breaker--shotgun blast sound
You may have a wire burn off the element and fall down to the base frame and cause a direct short. Turn you breaker off, remove the front and inspect for such a scenario.
Jun 02, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
60 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
