Question about Watches
How does a Anno 1640 wooden clock work?
Where can I finf a manual for a Anno 1640 wooden clock, Schematics and operations.
SEIKO ALARM CLOCK SQ767W MANUAL i GOT TWO OF THEM AND THE INSTRUCTIONS ARE IN CHINESE
The normal clock/alarm functions of the Seiko SQ767W work worldwide, but because the feature that automatically sets the time via radio signal only works in Japan, Seiko only provides the manual in Japanese.
https://www.seiko-clock.co.jp/product-personal/digital/temperature/sq767w.html
https://www.seiko-clock.co.jp/product-personal/up_files/FSQ-125P.pdf
Here's an English version I made with the help of onlinedoctranslator.com (uses Google Translate). I made a couple of adjustments but it's still pretty rough due to the machine translation.
https://1drv.ms/b/s!AKpNuPb-kshMyTo
Mar 08, 2018 | Seiko Watches
I have a Dakota Daniels grandfather clock. The chimes work, the pendulum works, but the clock hands don't move.
Change the batteries. The weight makes the pendulum and chimes work, but the clock in this thing is battery operated :>)
Accurate hourly Westminster chime movement tolls the hour - Automatic night shut off
  • Cathedral pediment, blue moon metal dial with raised roman numerals
  • Pendulum, weights and chains are made out of metal - Real tempered glass
  • Sturdy construction - Made of MDF & solid wood - Batteries (3-AA & 2-C) not included
  • Dakota Daniels grandfather clock Google Search
    Dec 12, 2016 | Dakota Watches
    Need a manual
    This is a great in-depth manual provided by The Clock Depot. Try it out and come back with any other questions!
    Grandfather Clock Operation
    Sep 23, 2012 | Watches
    Timex 1440 sport indiglo 50m convert from 24 hour clock to 12 hour clock.
    There are several models of your watch not all of which appear to have a 12/24 hour display format.
    Try this extract from a manual; press the MODE button six times to enter the 12/24 adjusting setting and then use the START/STOP or SPLIT/RESET button to change the time.
    Press the mode button to return to normal operation.
    Dec 06, 2010 | Watches
    We have a Acctim barrery operated westminster chime wall clock and cannot get the clock to work, pendulum & chimes work but not the clock, is there a reset button,how do we get it working. it is 11yrs...
    Press the red button at the back and go through all the hourly chimes until you get to the next chime due i.e. if its 3.15 whebn your doing this, only go through the chimes until 3 o'clock and no further. Then turn the hands clockwise ONLY never anticlockwide and she should be fine.
    Nov 19, 2010 | Watches
    Lookling for operating manual for Elgin Anniversary Clock.
    Thank you for contacting FixYa.
    I would contact Elgin at this link with the information on your clock.
    http://www.elginclock.com/Contact.htm
    Best regards. Jewel
    Oct 21, 2010 | Watches
    I want a manual for the Casio PQ-10D-8REF LED Digital Travel Clock
    I have searched their website and have been unable to find your model but I suspect that all the models operate in a similar manner, so the instructions for one of the other clocks could be used.
    If you go to http://support.casio.com/pdf/002/PQ30_31_DQ543_583.pdf and download that file, you should be able to find you way round your clock.
    Sep 29, 2010 | Watches
    I have a Westclox battery operated wall clock with chicken on face. The battery is new. The second hand tries to move but just "clicks" How can I fix this?
    Sounds like it is just worn out.
    Sometimes you can replace the generic clock works in these type of clocks. Go online and do a search for battery powered clock works, and see if you can match yours. They are removed quite easily after popping off the clock hands, and removing a nut under the hands that holds the clock works in the chicken.
    Here's a link to a site that sells the clock movements... http://www.clockworks.com/
    Jun 09, 2010 | Watches
    Need manuel fo operation and set up
    Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CITIZEN watch/CLOCK manuals.Rate me, please
    Mar 15, 2010 | Seiko Mantel Clock With automatic world...
    Repair of battery-operated wall clock
    We had the same problem with our wall clock, but it was due to corrosion from a dead battery. The battery acid leaked inside and disrupted the connection between the metal contacting the batteries and the circuit (the one with the copper coil). We took everything out cleaned the contact points with acetone (nail polish remover). After that we had to bend the contact heads up just a little bit so they would contact the circuit again (I guess we bent them down a little when we were cleaning it). It worked just fine after that. I know it sounds intimidating to take apart a clock and put it back together but you're going to throw it out anyway. Just give it a try. It was kinda fun. Think of it as a puzzle. If you can't fix it, I imagine you can get a new motor at any hobby store or Michaels.
    Jun 24, 2008 | Kenneth Cole 1213 Wrist Watch
    Watches Logo
    681 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
