Question about LG WFT1071TP Top Load Washer
Black Flakes in Washing
These black flakes appear in the water during the washing cycle. I've cleaned out the filter at the back as well and that doesn't seem to be the problem. If someone could help me please.
SOURCE: flakes of dirt on washing
Is this perhaps a second hand machine or it has possibily been stored away for some time? When a washer dries out inside ( behind the washer bowl ) and is then put back in service, dirt from years of use caked on insides flakes away ( like a dry leaf crumbles) and re-enters the wash and can end up on washed clothing. The only way to stop this is complete removal of washer bowl , scrub and clean insides to remove caked on dirt - reassembly. problem fixed !
Posted on Jul 19, 2007
  • 15 Answers
SOURCE: LG WFT851 - Flakes of dirt problem
try putting some milton or baby bleach into the machine with the hottest possible wash with no clothes with the highest water level
I was given a new model LG washing machine recently, it works as it should however the original owner was a builder and whatever he was washing off his clothes has caked onto the sides of the outer drum.
I have pulled the top off the washer and can see that the outer drum is literally covered with a fulll layer of this thick, black muddy greasy clay like substance. I need to pull the inner drum out in order to be able to get the outer drum but haven't managed to figure it out as of yet.
I've tried dissolving portions of the gunk with detergent, acetone, cleaning vinegar, methylated spirits, paint thinner, auto degreaser and mineral turpentine, of all these agents turps is the only one that seems to have an effect however it's ability to dissolve the stuff is minimal.
Posted on Oct 14, 2007
freetek
  • 5568 Answers
SOURCE: whirlpool washing machine
It sounds like the porcelein on the inner or outer tub is damaged allowing rust to form.
Another possibility is that there are iron deposits in the internal hoses that are loosening.
I would (assuming you can afford the water wastage) run the machine on 'full load' and 'hot' several times with no clothes in it to see if it will flush out.
Posted on Aug 03, 2008
  • 2468 Answers
SOURCE: after washing whites clothes covered with black bits
your lip seal is leaking and the bearings are getting water in them,you need to get this fixed soon,because they can lock up if left too long like this and it will only get noisier and not better with time
Posted on May 09, 2010
Testimonial: "thanks very much.put me on the right path."
Whirlpool LA6800XTWO works but flakes appear in the tub: beige,slimy & smelly or dark & odorless. Tried cleaning cycles. Where are they accumulating (& can I disassemble & clean)?
Your model has a Magic Clean lint filter (see below) but no mention of how to access it. But it is also not clear how the lint would get back in the basin and look like flakes so that may not be it
magic clean-1s5ndzde1r2l1zm2olkfdzlo-3-0.png The only other thing I think of is that the fabric softener dispenser is gunked up .... try running hot water through it
Good luck on your troubleshooting
Jan 15, 2018 | Whirlpool Washing Machines
Waht causes black flakes on clothes when washing?
Hi, it sounds like you have to buy one of the inside washing machine cleaners its a liquid that you put in the washer and let it run its cycle to flush clean the interior of the unit.
Jan 23, 2016 | Samsung 4.8 Cu. Ft. 13-cycle...
My washing machine is getting little black flakes in it. They are very thin/fine, what can I do?
Depending on the material the flakes are made of they could be one of the rubber hoses that has perished and is eroding from the inside or it could be the sign of a future mechanical breakdown.
Feb 12, 2015 | Washing Machines
Black flakes
Dose the whole cube have a black tint to it? or dose it have black flakes in it? If all the ice has a solid black tent to it then check your water filter most all filters has charcoal in them when you change one out and apply water to them you need to dump the ice until you get clear ice. Now if it is just black flakes in ice than you need to clean the ice machine with scotsman cleaner nickle safe and scotsman sanitizer follow manufacturers instructions.
Aug 30, 2013 | Scotsman Kitchen Appliances - Others
Black flakes come out when the hot water side of the faucet is used
These black flakes must be in your line or your expansion tank. Remove the filter from your faucet, temporarily, and let just the hot water side run until the water comes out clean. You must flush these black flakes out.
Jan 31, 2011 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
My lg Washing Machine WF-T853A is putting black rubbery chunks and flakes through every wash.. This has been happening for about 12 mths and is getting worse to the point where half the lint bags are full...
sorry to ask you this but are you sure the flakes are rubber? usually the black flakes are lint from the clothes. to help combat this problem try this.1- buy 2 pkts of bicarb of soda or baking soda, 2- select high water fill. 3- select hot water fill.4- pour soda into an empty machine. 5- shut the lid and push the start button. 6- let it fill and wash, let it wash for about 5 to 10 min"s , do not let the water drain.7- turn machine off after letting it wash for 5 to 10 min"s , and leave the water sit in the bowl overnight . 8- in the morning start cycle again and let it go thru complete cycle. this should get rid of most of the lint. you might have to do this twice depending on how dirty the plastic tank is. please reply 4 more help and good luck.
May 12, 2010 | Washing Machines
Rubber mat flakes in washer
it will cause a clogged pump
take off the back wall
you will see the pump
unplug it
ctake off the two hoese( make sure botha re clear)
ensure pump is clean
reinstall and you should be ok
Oct 04, 2009 | GE WCVH6260F Front Load Washer
What are the black flakes and how to we eliminate
Did you buy the machine used? It sounds like mildew rinsing off of the outer tub. Try running a load of judt hot water with bleach to clean it out
Sep 13, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
LG WFT1071TP Top Load Washer Logo
520 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
