Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
Lost vacumn, door popped open alarm on
I silenced the alarm, moved food around, nothing was deforsted yet except some popcicles. I locked the door, left it off for 2-3 hours and plugged it back in. The compressor is very hot, the outside walls are very hot. The temp is down to 15 F..buzzer will NOT reset, yet.. Prior to this episode, the door , inside on top of the first shelf was frosting up, (FF freezer).
  • 4,070 Answers
If is the type of freezer where the shelves are also the evaporator(shelves are very cold and is normal to frost), the fact that only one shelf is iced would indicate the system is low on freon due to a leak. This would also explain the hot walls and compressor. It requires a service man to check the freon level and locate leak and recharge.
Posted on Sep 08, 2009
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Sep 02, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
On normal operation my freezer alarm will not stop bleeping.The only way to silence alarm is to switch to Fast Freeze ,however the compressor runs contually ,even after 24hrs and switching back to normal...
Have you cleaned the condenser grill and made sure you have plenty of air flow around the unit? It might also be time to take the food out and completely defrost your freezer! Since you do have an ice build up on your evaporator grill.
Jul 31, 2011 | Whirlpool Freezers
Hai this is arun from oman.. i want to know how to
Check the defrost timer is operating and that the defrost heat element is working, usual cause of ice build up in most units, you may want to get an electrician to do it coz one wrong move it WILL kill you. Good luck.
Dec 18, 2010 | Desmond 49 cu. ft. / 1388 liter Commercial...
Hi, i have a whirlpool american style fridge that beeps etc.
its the compresor packed up,,,if this compresor is not pumping freezer gas around the pipe work the freezer wont work sorry but a new compresor is not a cheep thing to have fitted as it will need a re-gas as well
Jun 29, 2010 | Freezers
Temperature Alarm
although you could just close the door and it should right itself,could it be the right time for a total defrost and clean.all the drains/vents.....auto defrost only does the inside of the unit,
Jun 24, 2010 | Frigidaire 13.7 cu. ft. Upright Freezer...
Can't get alarm to turn off while temperature stabilizes
My wife solved it for me :-) You turn the alarm off with a switch at the bottom. The alarm turns off, but the light stays red for another 4 hours. After that the red light goes off too, and you can turn the switch back on without the alarm going off, if the freezer is back to operating temp.
Aug 06, 2009 | Frigidaire Upright Freezer FFU12F2H
Red light on
The red light and the audible alarm both come on when the freezer gets warmer than the alarm point... unless you disable the audible alarm with the rocker switch
Nov 24, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
GE 16.7 Upright Freezer
HI the heat on the outside of the cabinet is normal. the freezer is now working properly give it 24 hrs thanks.
Jul 17, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Mar 22, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Whirlpool upright freezer AFG823NF-Thermostat not working properly
JennyT just trying to help with this. I assume this is a self defrost model. If so then is there an ice build up on the back wall? If so then the unit isn't defrosting. That is why pushing the Fast Freeze button is no longer working. You can get by however. Remove all the food from the freezer, put a vacumn in the freezer and shut the door. Turn on the vacumn, this will pull the warm air thru the freezer and in 30 minutes to an hour it will be defrosted enough to work until you can get someone to replace the 1 of 3 parts that the defrost system uses. The vacumn is what I use to defrost my nonself defrosting freezer. Sorry I couldn't be of more help.
Feb 03, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezers Logo
164 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
