Question about Canon PIXMA iP4300 InkJet Photo Printer
I cleaned the print head, inserted it 2 days later
Getting code B200. Hope you can advise?
Error B200
Get steps to Fix Canon Printer Error Code B200 instantly. Watch below video to learn how to fix Error Code B200 on PIXMA Printer Call now +44-8000465291 for instant Printer help.
Source: https://goo.gl/xskzcB
For 4+ Cartridge Printers:
Step1:-Remove All Printer Cartridges.
Do remove the individual ink cartridges from your printer. This will be opening the lid of your printer and waiting for the cartridge cradle to be placed in the correct position.
Step2:-Remove the Print-head.
This is can be done by lifting the orange or gray locking lever on the side of the cartridge cradle and then gently lifting the print-head from the printer.
Get full Step by click below link
How to Fix Error Code B200 on Canon PIXMA Printers 44 8000465291
Feb 01, 2016 | Office Equipment & Supplies
Error code B200 PIXMA MX452
Error B200 is a print head overheat error. Just need a new printhead. You should see the power and alarm lights flash on and off 10 times then repeat the cycle. That's confirms the fault more than the error code. Its very simple to fit a head, just be careful putting the new one in as it's easy to break the pins in the carriage. No force is needed when fitting the head. Just let it drop in and lock the lever. Try taking out the old head first and gently clean the contacts at the back as they can rarely make poor contact with the carriage pins.
Good luck
Sep 22, 2014 | Canon Pixma MX452
Canon pixma mp560 printer error b200
Leave the cover open, turn off, before it off, hold the reset & Start (color) until it completely off, then turn it back on. it works for me, good luck folks
Jun 29, 2012 | Canon PIXMA MP560 CLR INKJET P/S/C/F FB WL...
What is error B200 when attempting to power up
http://www.printerdiary.com/2011/09/canon-error-b200-how-to-fix-it.html
Error B200 on Canon printers is a print head error. The print head is what the cartridges sit in inside of the printer. To attempt to resolve it, do the following:
(1) Open the printer and wait for the carriage to slide over
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head and each ink cartridge.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If that does not work then you have one of two possibilities:
(1) One of the ink cartridges is defective and causing the error
(2) If it's definitely not that, then the print head will need to be replaced.
Mar 24, 2012 | Office Equipment & Supplies
Error b200 in cannon pixma 258, how to fix
VH monitor error or Error Code B200
Condition: The print head voltage is abnormal.
Problems and Solutions:
  • Replace Print head and logic board (Replace them at the same time.)
  • Replace Power supply unit
  • Check and Clean Head contact pin condition of the carriage unit
  • Check Cable connection especially the carriage FFC
Regards
Sep 26, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
B200
Hi there!
If you're getting the error code B200 when you try to print on your Canon PIXMA MX850, there is nothing you can do except to have it repaired. This error code indicates a Voltage High Error of the Canon printer. If the printer is still under warranty, please contact Canon for further assistance.
Jun 26, 2011 | Canon PIXMA MX850 Multifunction Printer
Canon Pixma Mp258 B200 Error
My printer is canon mp258 there was an error B200 . how t fix this?
Apr 07, 2011 | Computers & Internet
Service error B200
Well every advice is the same except a little altered (use a warm cotton swab to clean inside machine and on print head channels) but then it says if possible replace print head but honestly this has become a primitive Machine for turning humans into corpses - buy a new one.
Aug 02, 2010 | Canon PIXMA MX850 Multifunction Printer
My is not working & shows an error code B200.
FLASHING ORANGE LIGHT ERROR MESSAGES
Try counting the number of orange flashes.
* two flashes means you’re out of paper or the paper is not feeding correctly.
* three flashes means there is a paper Jam or the output tray is closed.
* four flashes means the ink tank is empty
* five flashes means the print head is not installed correctly or not installed or is defective (before buying a new print head always try the cleaning instructions at the end of this post first.)
* six flashes means the inner cover is open or not closed properly.
* seven flashes means you counted wrong.....
* eight flashes means the waste ink absorber is almost full or full.
* nine flashes mean that a digital camera or video that is connected is not compatible with the printer. If a specific amount of time lapses without getting a response from the digital camera or video camcorder this will happen.
* ten flashes means it can not print to both sides of the page
* eleven flashes means the automatic print head alignment failed. (this can be caused by low ink levels, ink tanks not being installed correctly, the print heads being clogged. It can also be caused by the paper output slot being exposed to a strong light source (Press the resume /cancel button and move the printer to a darker location and try to align the print head again.
* check to make sure the lock lever is correctly positioned (down)
If the above does not work, align the print head manually by opening the printer properties dialog box and clicking the maintenance tab and then select the print heal alignment button on the left side, second row down.
Mar 25, 2010 | Canon Office Equipment & Supplies
Canon PIXMA  iP4300 InkJet Photo Printer Logo
102 people viewed this question
old marine
old marine
