Question about E-Machines eMachines Desktop PC
How to connect Samsung 40" LCD tothe eMachine desktop T2615. It looks like there is only one connection for a monitor? The computer is about 6 years old.
    Novelist:
  • 190 Answers
Older LCD TV's have a variety of inputs, one of them being VGA, to connect to your PC. The problem seems to be that you either connect your PC to its own monitor, OR to the TV, but not both? If that's the case, you may have a couple of alternatives:
The most expedient one would be to get a VGA splitter cable; the other, more expensive: replace your video card with one that has dual outputs: either one with two DVI ports; one with one DVI port and one VGA port; or one with one DVI port and one HDMI port. As you can tell, there are several possibilities, depending on the connectors available on your TV.
Posted on Sep 08, 2009
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
I was wondering if i can use any monitor with an Emachine computer? my friends monitor went out and i want to replace it for her.
I use a regular 17 inch monitor from 10 years ago with my eMachine that came with a 22" flat screen. It's just a matter of connecting to the correct input and output. You do have to install the correct drivers for the monitor you are using unless it uses the Windows Generic drivers but it will work.
Feb 15, 2011 | E-Machines eMachines Desktop PC
Can't connect my emachine to 50" samsung plasmatv mod#pn50B530S2F
try going to "display properties" and adjusting the settings there. Right click on the desktop wallpaper and go to properties, then click on the settings tab. Make sure the TV setting is turned on
Mar 28, 2010 | Acer Aspire L100 PC Desktop
Want to use samsung 2233SW LCD monitor as TV
Yes you can, if you has PC desktop, plug your lcd to it. change LCD resolution from your PC.
-- Right Click on desktop
-- Click properties >> click settings tab
-- You will see Screen Resolution, change to the lowest (800x600)
-- Nnplug VGA cable from PC
-- Now plug the cable tou your TV Tuner.
Feb 08, 2010 | Samsung SyncMaster 2233SW Monitor
Emachines monitor e15tr model 568 wont come on
Try to connect the monitor to the VGA-output port of some other desktop or notebook computer. If it does not work, then it needs repair or replacement. If the monitor still under warranty:
* standard 1-year warranty from Gateway
* extended warranty that you may have purchased from Gateway
* extended warranty that some credit-cards offer for items purchased with that card
* extended warranty that you may have purchased from the retailer
If not, it's probably cheaper to replace a 15" or 17" or 19" monitor
that it would be to try to repair it.
Nov 27, 2009 | E-Machines eMachines Monitor E15T4
Has a cord that has the same type of connection on both ends
Look on the back of the emachine, there should be a blue connector with 15 holes in it. Thats the VGA connector and thats where the other end of that cable goes.
May 31, 2009 | E-Machines eMachines Desktop PC
Need to know scan frequency of the computer
Most TV have interlaced 60, which is really 30 hz...
You can set your computer's scan frequency by right clicking on desktop, then going to the rightmost tab, under advanced, click on the monitor tab and select 60 from dropdown tab...
However, most videocards output Svideo to tv, not VGA so don't worry about it. if your TV has VGA in, you can select 60, but if it has VGA in, it probably has greater than 60 capabilities... but 60 is rock safe for everything.
Apr 19, 2009 | E-Machines eMachines Desktop PC
Two monitors
You just need to get a video with dual monitor support , so that you can connect two monitor on that emachine tower , because basically emachine only came with a video card that you can only connect 1 monitor...
Hope that helps.............
Oct 05, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
221 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
