Question about Epson Stylus Photo 950 InkJet Printer
My epson 950 suddenly started printing aberrant colours
Using premium glossy paper (preferences set correctly), some deep blacks print as a streaky red.
Using plain paper (preferences - plain), all colours are patchily bizarre; a re-try produces the same effect.
It is most likely I have stupidly missed something but I would appreciate help. Genuine Epson inks used. Nozzle aligment correct and heads clean.
David
I am printing pictures with my new Epson PX730WD and use only original Epson inks and Epson Premium Glossy photo paper; I had to put in a new original Epson black ink cartridge. Initially after printing...
Could be defective printer or maybe that is just the way it works and is unsatisfactory. If not happy with results try another printer after returning the Epsom. Check consumer reports for printers that do great job on photos and go that route.
Aug 28, 2017 | Office Equipment & Supplies
How do I print using glossy photo paper?
select the paper type in the printing preferences section. Make sure the glossy side is down when you load the paper so that it prints the correct side.
Oct 06, 2011 | Epson Stylus CX4800 All-In-One InkJet...
When I print on photo paper the ink doesn't dry and picture quality is unrecognisable
You have to match your print settings with the correct type of media used !
When you print, set the preferences, set to PHOTO quality and not draft, set paper type to PHOTO PAPER, or GLOSSY PHOTO PAPER whichever - If you select wrong media type your colors might be off. Select the settings that match the closest to your media. If you use paper use "plain paper" setting, if you use glossy photo paper, use "glossy photo paper" as settings and PHOTO quality.
I recommend use you use inkjet PHOTO paper, glossy, you can use HP or EPSON or even the cheap LIKON ones work amazing for me, they should be able to dry quickly, if they don't you are not using the correct settings.
By your description above it looks like you are using economy or draft mode - NOT good for photo paper.
Sep 26, 2009 | HP Office Equipment & Supplies
Epson r350 printer does not print thick paper or inkjet paper
Hi, this printer is "clever" in that you don't adjust the thickness setting it does it itself.
It does this based on the paper type you set in the printer properties, see the table below for the different types of paper it will accept & the setting you need to use.
For this paper Select this paper type setting Plain paper, sheets Epson Premium Ink Jet Plain Paper Epson Bright White Ink Jet Paper plain papers Epson Ultra Glossy Photo Paper Epson Ultra Glossy Epson Premium Glossy Photo Paper Epson Premium Glossy Epson Premium Semigloss Photo Paper Epson Premium Semigloss Epson Glossy Photo Paper Epson Glossy Epson Matte Paper - Heavyweight Epson Double-Sided Matte Paper Epson Matte Epson Photo Quality Ink Jet Cards Epson Photo Quality Ink Jet Epson Photo Stickers Epson Photo Stickers Envelopes Envelope
Hope this is of help.
Regards
Sham
Jun 01, 2009 | Epson STYLUS R350 Photo Printer
My printer no longer feeds in Epson Premium Glossy paper S041624
Try to clean the paper pick rollers with a cloth, dam it with little water and try to hange the paper settings by going into printer preferances.
Regards,  raj_p5983
Jan 20, 2009 | Epson Stylus Color 1160 InkJet Printer
Just want to print black !
hallow ,,,if your lookin to just print black and white so .while printing ,go the printing properties or prefrencies ,,in the colour option click just use black and white
Jan 10, 2009 | Office Equipment & Supplies
Epson printer that can print at art glossy paper
Epson's ink uses a dift technology so far better result you need to check what brand of glossy or photo paper you can use. You can purchase an epson photo or glossy paper for best results.
Your printer would work best using the list below:
Paper Types
  • Supports a variety of Epson plain and photo papers. Supports plain, bond, air mail, Epson Premium Bright White, Glossy Photo Paper, Premium Glossy Photo Paper, Premium Semigloss Paper, Premium Luster Paper, ColorLife paper, Matte Paper Heavyweight, Double-sided Matte, Inkjet Transparencies, Self-adhesive Sheets, Photo Quality Ink Jet Paper, Greeting Cards, High Quality Banner paper; labels; envelopes, Iron-on Transfers and Photo Stickers; Printable CD-R/DVD-R; Panoramic 8.3" x 23.4" Photo Paper
If you may have other questions pls feel free to ask.
Just rate me Fixya if your issue has been resolved.
Cheers.
Jun 17, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson R340 not loading ultra premium glossy photo paper correctly
I have several Epson printers and it would seem this is common, I am on my fourth replacement printer, Epson keeps shipping them.
Mar 08, 2008 | Epson Stylus Photo R340 InkJet Printer
Black ink on glossy paper looks like leopard spots
printer need head cleaning , after cleaning check nozzle , if solid color appear w/out space on black color it means good and clean nozzle.
Dec 27, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Open Questions:
See all Epson Stylus Photo 950 InkJet Printer Questions
Epson Stylus Photo 950 InkJet Printer Logo
64 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
