Question about Compaq Presario 700 470024-192 Notebook
Mine computer is not starting and at start its showing blue blink for microsecond and then turn off.
    Scholar:
  • 132 Answers
The BLUE BLINK you speak of . . This is the microsoft screen of death . .
This normally suggests a hardware failure, of memory issue. Firstly, have you installed or uninstalled any hardware ??
When you power up , keep pressing 'F8' - This will allow you to start your PC in a restricted way (you can then establish if any hardware is failing or HAS failed.)
You will be able to re-install any 'upset' drivers from here via the control panel.
At a minimum, you will be able to recover any images / documents that you require, prior to a re-format and installation / system recovery...
Keep me informed if you progress . .
Posted on Sep 08, 2009
Sharp lcd tv.lc45gd4u no power red light blinking two times pauses then repeats
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1200 posts to different brand TVs now. Pull up older posts there. Blinking codes to so many brand TVs are described in detail here.
Nov 12, 2012 | Televison & Video
Tv turns on for a few seconds then shuts off and the blue power light blinks.
Mine never turned on but the blue power light would blink.I disconnected the upper y buffer and got light on the bottom half of screen and the blinking stopped.I have the upper board on order and I think this will fix my problem.There is a blink code somewhere,just count how many blinks.Start pulling connectors from power supply and when it quits blinking you've found the one,could also be the power supply with bad cap.
Jul 14, 2011 | Hitachi Ultravision P50S601 50 in. Plasma...
I have a blue vertical flashing light showing just above the Dell emblem. In the past there has been a solid light. I have checked on OpenManager which indicates all is well but I do not like unexplained...
Great thanks,
That's just a system indicator flash. Solid blue means on and normal, blinking means someone either turned on the system indicator in the management software or bumped the indicator switch on the back of the server. This was designed to make easier transitions from back to front when working with multiple servers in a rack. To turn the indicator off, just go to the back of the server and find the Ethernet and usb ports that are together. If the usb is the bottom and Ethernet port is the top then just to the right you should see a small blue blinking light and a button, pushing the button wil turn the blinking off.
Again, no worries this is just a "locator beacon" not an error message, if the light ever blinks yellow then you have an issue.
Hope this helps FixYa,
Chris
Jan 10, 2011 | Dell PowerEdge 1800 Server
System will not boot properly unless in safe mode. Windows tries to boot, a blue screen with some type of messages comes up for a microsecond and it starts over--I get the black screen with options for...
I suggest downloading a free registry fix program called "glary utilities" and run the program. It should fix all your problems. If anything, you can always do a system restore
Jul 01, 2009 | Dell Latitude D505 Notebook
My Plantronics Voyager 510 will not go into pairing mode.
i actually got this to work with my iphone 3G S. i pressed the little black button then saw a blue light flash, and then i pressed and held the + volume button and the call control button until it started blinking blue and red and my iphone picked it up instantly. it did take a couple of times to get the headset to go into pairing though
Jan 16, 2009 | Plantronics 510 Voyager Headset - PLN-510...
Blinking question mark at startup
It's saying it cannot find the OS. You must have done something to it?  Put your disks in and it will start from them. You can also use it to fix the problem. Do a install and archive.
Nov 11, 2008 | Apple Mac OS X 10.4 Tiger for Mac
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Won't turn on, computer won't recognize it anymore...
Comment by c-lesha, posted on Jan 06, 2008 mine won't charge shows sansa in blue then lock pic then turns off won't turn back on doess this every time i put it on charge when in "charging" it shows a little blue box if it is showing the locked picture then it is locked and you need to hit the switch on the side to unlock ~Temp
Jan 06, 2008 | SanDisk Sansa m260 MP3 Player
TV goes out
pyrosp4,
it maybe you blue crt (picture tube). mine turn blue and then shuts off. i got it repaired for 460. 300 for the part 160 to install. you can try to adjust the voltage settings behind the speaker screen and see if that clears the problem. if not its you blue crt.
pridah
Dec 18, 2007 | Sony KP-65XBR10W 65" Rear Projection...
Compaq Presario 700 470024-192 Notebook Logo
65 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
