Question about Gateway MT6840 Notebook
Gateway mt6840 new battery will not charge. New charger too. Bad charging port? Bad charger board?
  • 3 Answers
Try pulling out the battery. Then plug in the power supply and see if you can get it to power on. If so wiggle the plug and see if it shuts off. If either if those are true, en you most likely need your DC Jack replaced. You would want to take it to a laptop repair shop. It is usually $20 for the part and around 1.5 - 2 hours labor for the repair. Requires pulling out the motherboard and desoldering the old jack. And soldering in a new one. No fun
Posted on Jan 27, 2012
  • 615 Answers
Check the connection between the battery and the unit and clean them good try to use elctronic cleaner
Posted on Sep 08, 2009
Gateway nv52 won't charge
It sounds like you either have a dead mother board or a bad power inlet. Did the machine work with the new battery while it was charged? If so, then the battery connector was good and the inlet was bad. If not, your motherboard could be dead. I've also seen where a bad battery connector would syphon off enough power to not power on the machine or charge the battery.
Nov 14, 2012 | Gateway NV5215u Notebook
Gateway MT6840 won't power up
before checking ur mother board check for ur operating system.
Mar 08, 2012 | Gateway MT6840 Notebook
Hi I have a Gateway MT6840 laptop. The problem I'm having is it won't run or charge a good battery. I have borrowed a friends Gateway MT6840 laptop to test it and my battery charges and works great in his...
Are you sure that the charger is working?
If not it could be the battery slot. There is nothing you can do on your own except swap batteries ant try.
Mar 03, 2011 | Gateway MT6840 Notebook
My gateway mt6840 does not read my new battery
Have you tested your power supply to confirm it's sending out the right amount of current.A simple ac tester is all you need.On the back of your power brick it will tell you your in-put and out-put voltage requirements.If your ac adapter tests good your new battery is probally the problem.
Jun 02, 2010 | Gateway MT6840 Notebook
My sanyo pm 8200 wont hold charge!
Since the battery and charger are new and yet it does not still hold charge.
Have put the battery in another similar phone and try to charge with your charger to see if it will hold charge? if you have.
It means the charging port of your phone is bad and you will need to replace it.
The charger is not charging the battery in anyway because the charging port is bad, so just change your charging port, your phone will now hold charge.
Take care.
Apr 14, 2010 | Sanyo PM-8200
I have a gateway MT6840. I am having charging problems.
This problem requires the dismantelling of the system and the socket either being resoldered to the motherboard or replaced if it is damaged. if you cannot or are not comfortable with doing this yourself, you will need to get a tech shop to do this for you.
Feb 12, 2010 | Gateway MT6840 Notebook
Gateway mt6841 won't turn on or won't take a charge, no lights when ac adapter is plugged in
Hello
Thank you for using FixYa for your problem
Always check the charger unit is acturally giving out the power, then it maybe the DC Jack in the laptop (where it plugs in) Is this loose
It should be taken to an authorized repair centre for a repair estimate.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 03, 2009 | Gateway MT6840 Notebook
Power port for gateway MT6840
First easy check is to stick a toothpick into the jack to see if the middle pin is loose. If it's not loose, try another power adapter to check just incase. If you dont have one ask around to borrow a universal one. Dont jiggle and wiggle the plug with the power plugged in if it is loose because i've seen shorts happen.
usually plugs are mounted onto the mainboard. To get to the main board, you'd have to take apart everything because everything attatches to the main board. The case, keyboard, heatsinks, speakers, and so on must come off before you'll be able to see the power jack. With parts and labor, it comes close to a new laptop.
Jul 29, 2009 | Gateway MT6840 Notebook
Have a gateway 3520, won't power up
you could have a bad power port...how do you know that the batt is charged?
if its not the power port then it could be a bad switch...or main board
what happens when you press the power button?
can you hear your cd drive fan or anything start up?
how advanced are you?
May 25, 2008 | Computers & Internet
Gateway MT6840 Notebook Logo
585 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
