Question about Zoom X4 5551 Router (5551-00-00)
Need a usb driver for zoom 5510 router
I nee to connect my router via USB
    Novelist:
  • 136 Answers
Chris571 --
You will find your driver here:
http://www.zoom.com/techsupport/adsl/adsl_5510.shtml
**Note: One setup program is for the U.K., one is for all others)
Hope this helps!
-- RT
PS - If useful, don't forget to vote!
Posted on Sep 08, 2009
Testimonial: "thank ou!!!"
Cannot connect to laptop
why?isn`t difficult. first connect ac power.then,load drivers from cd/dvd.when asking,connect printer via usb cable and in few minutes will be ready for printing.
Mar 12, 2015 | HP Photosmart 5510
Tip
I think there are 6 ways (at least?) to connect this printer: (1) Direct to Mac...
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable(3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch(4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless)(5) WiFi to router, with Mac/PC via Ethernet to router/switch(6) WiFi to router, with Mac/PC also via WiFi.
As (1) should be simplest, tried this first. First document would print instantly and completely, next doc would hang in queue with unexpected msg, "Printer is offline." Only way to print 2nd doc was to power cycle (off-on) the printer. This problem occurred whether 2nd doc was sent to printer before or after 1st doc had printed. Tried 2nd USB cable, tried new driver, tried reinstalling printer; same problem. Spoke to both Samsung and Apple support, including both on a conference call; never got this to work and never clarified if problem was in printer hardware/software, driver, or something else. Both companies now showing this issue as unresolved.
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Procedure required connecting first via Ethernet, obtaining Configuration Report by holding down orange button for 5 seconds, then using browser to connect to the printer's IP address. Also required different driver for wireless config (as opposed to USB).
Bottom line: What seemed simple - USB direct connect - proved unworkable, but wired and wireless network config works fine.
on Apr 25, 2010 | Office Equipment & Supplies
Tip
Samsung ML-2525W printer & Mac OS X 10.6
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable (3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch (4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless) (5) WiFi to router, with Mac/PC via Ethernet to router/switch (6) WiFi to router, with Mac/PC also via WiFi
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Also required different driver for wireless config (as opposed to USB).
H1 won't connect via USB
This page has a download for a driver........ https://www.zoom-na.com/products/field-video-recording/field-recording/zoom-h1-handy-recorder
Also try a different cable....... Good Luck!
Mar 25, 2017 | Zoom H4 Handy Recorder
Top 2 lights are green, connections are all correct, and there is no internet connection to the computer. Is there a setting on the computer that I have wrong?
You need 1 more light, "Local Network". So you need to connect something, probably your computers LAN - Ethernet Port to one of the 4 ports that are together (LAN ports.)
If you are connecting USB, well that's always ugly, no cable support person will recommend that you connect a computer to a router via USB. But if you do, there's a driver software for that. Should be on a CD that you received in the package.
USB driver, no doubt, will create a virtual Network Adaptor. Then you'll get IP Automagically from this unit to your computer. The same thing should happen if you connected via LAN/Ethernet connection.
You normally don't have to set any settings, the default will be Automatic for IP Settings assignment. Which means you'll get it via DHCP protocol from this unit.
Nov 28, 2009 | 2wire 1800HG Router (RG1800HG00)
Router cannot connect to belkin g usb adapter it worked fine yesterday and today nothing!
Make sure to install the USB adapter's driver and utility. If it's installed, you need to use the Belkin WLAN Utility to connect to the wireless network. You should be able to find the signla coming the router and you can connect to it
May 07, 2009 | Zyxel P660HW-D1 Router
Title: Zoom H4 / Mac USB Problem
Upgrade firm ware from Zoom website
http://www.zoom.co.jp/english/download/software/h4.php
You will need an external SD card reader.
Good Luck
Mar 07, 2009 | Zoom H4 Handy Recorder
USB Modem V ADSL Router/Modem
Unplug the plug (from phoneline) on back of USB modem, plug into Zoom router. Plug one end of an ethernet cable into router and one end into your PC. Type http://10.0.0.2 into a web browser (eg. Firefox or Internet explorer) username/password is admin/zoomadsl go to basic setup and input your ISP username and password (the one given to you by your internet provider) under PPP. Click configure my connection. Save changes and then write to flash (both buttons on bottom of page)
Aug 12, 2008 | Zoom X6 Adsl Modem/router Rohs...
Connection of Paradyne 6211 to iMac (OS 10.5) via Ethernet
If you connect by using LAN port (RJ 45) you don't have to install driver. However USB connection will require driver. Do you have Ethernet adapter installed to you iMAC? If you have it will be resolved easily without using USB port. Check the following link for connection instructions
http://www.fixya.com/support/p200812-paradyne_6211_a2_200_router/manual-18800/page-18
If physical connection is successful you can go to internet browser type 192.168.1.1 and check your modem's settings. Please post if you need further assistance
Good Luck
Jan 27, 2008 | Belkin (F5D7233) Wireless Router
Zoom X4 5551 Router (5551-00-00) Logo
62 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
