Question about Refrigerators
My Hotpoint refrigerator, has a warm spot (hotpoint) in the center frame. It's a side by side, the warmspot is right between the two doors in the center. It's an old unit. I got this number off the back OK8-8WM. Thanks, Ron +++ Please reply to towingd@bellsouth.net
  • towingd Sep 14, 2009
    Where is the timer located? I'd like to manually turn it, if I can.
    Thx, Ron
  • 93 Answers
Most of the time that is from your condenser fan motor being out and your unit is not rejecting any heat from the freezer.
Posted on Sep 13, 2009
Testimonial: "Thanks, already found that info on Repairclinic.com. However, I have another question - What should the cycle rate for the defrost timer be? +++"
  • brooksktm02 Sep 13, 2009
    Defrost cycles are on 8, 10 or 12 hour timers depending on the timer you have or the control boalrd you have so basically I would say about every 10 hours your fridge will go into defrost
Hotpoint Side By Side Refrigerator Failing HSS22IFMDWW
Power down power up resets most electronic controls a power fluctuation could have caused the glitch recommend a surge supressor for the wholle house or the type made for appliances no power strips
Aug 08, 2012 | Hotpoint Refrigerators
I have a Hotpoint CSX24GRXA side by side refrigerator. The freezer side started having cooling problems in that it would get too cold, so I adjusted the thermostat to warm up the freezer. Then, I noted...
ok one thing at a time . the center post that is hot is a sing that the coils need to be cleaned and that the compressor is running to hot . this will also cause over run times and this causes tempt problems . such as too cold for the settings . so clean coil and if it look good the you did a good job and ck the fan blads and clean them too . they can't run properly if dirty and out of balance . some warmth on the center post is normal but if very hot then thing are getting dirty .. hope this helps mm
Oct 06, 2010 | Hotpoint Refrigerators
My is SxS fridge is warm on top & freezing on bottom- both sides
there is a computer board part number WR55X10942 ,if you're in front of the fridge it's on the left hand side down near the bottom,
Mar 21, 2010 | Hotpoint HSS25GFP Side by Side...
I JUST INSTALLED MY REFRIGERATOR BUT THE FREEZER DOESNT SEEME TO BE GETTING COLD ENOUGH TO FREEZE FOOD
HOTPOINT (made by G.E--enough said). Do you already have food loaded into the unit? If so, how warm is it, and do you have it packed up to the vent?
Jan 29, 2010 | Hotpoint HSS25GFP Side by Side...
My frige stays warm all the time it is a Hotpoint
evaporator coils are iced up on the freezer side. either take everything out of the fridge and unplug it and let it sit for a day to defrost, or remove the inside rear panel where there is frost and (with the fridge off) use warm water sprayed on the ice to defrost it (or use a hair dryer, but just until the ice is melted. do not overheat the metal). soak up the excess water (underneath the fridge, too), and turn it on empty. let it run empty for a day to get it cold, then put the stuff back in. if the stuff is in there when it's warm, the humidity will ice up the coils again.
Jul 23, 2009 | Hotpoint HSS25GFP Side by Side...
There is a hot spot on both doors near the top
NORMAL- THIS IS USED TO PREVENT THE AREA FROM SWEATING
Jul 06, 2009 | Hotpoint HSS25GFP Side by Side...
HSS25IFMD quit cooling--was plugged with dust/dirt
Hi: When both sides get warm it is a bad sign. I wish I had better news. Hope all works out for you, Jeff
May 30, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Water under side by side hotpoint
You can deal with it once for all by pouring warm water into the drain pipe to clear any blocks and sopping it off with a sponge..
Oct 29, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
143 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
