Question about Craftsman Garden
19.5 Briggs Craftsman Riding mower surging
I've sprayed carb cleaner, injecter cleaner in gass and rebuilt the fuel pump. Still have surging problem. I need to change the fuel filter to night - any other ideas. May just be trah in the injector.
Any ideas?
    Sergeant:
  • 302 Answers
Some of these have a screw in the very bottom of the carb or in the front that will adjust the engine loping problem
Posted on Sep 08, 2009
Why does my riding mower motor keep suring?
I think you mean surging ? right surging is a cause of only two things , wrong air/fuel ratio due to missadjustment of carb or dirt in carb , other cause is that governor arm spring has fallen off this happens a lot with briggs engines , simple to put it back on the little arm that connects to throttle arm
if dirt in carb is suspect , try adding a 50/50 ratio auto carb cleaner to fuel and running for an hour or so , this sometimes works and sure beats removing carb and cleaning it
Jun 06, 2014 | Craftsman Garden
Mower surges when idling
dirty carb
shut off gas
remove bottom of carb
spray carb cleaner up into every spot you can find inside carb
blow out with air
clean bowl out if needed replace the try it
if it doent work you need to soak carb
Aug 23, 2013 | Briggs & Stratton Garden
Have a 4.0 quattro Briggs and Stratton lawn mower. Starts up great and doesn't stall out. Has this annoying surge and slow down of motor. Removed gas from tank and sprayed some gum remover in tank and...
it does sound like a carb issue it may need to be rebuilt also check your fuel line and if you have a fuel filter check the filter clean the gov. assembly with carb cleaner
Jul 30, 2012 | Garden
My 1976 sears 18 hsp riding mower quit running now it just cranks but won't fire it has a onan engine
check for spark then spray a little carb cleaner or starting fluid in the carb if it fires its a fuel problem filter pump carb
Apr 10, 2012 | Craftsman Garden
My 13.5 ho b&s surges heavily but smoothed out when blade/ deck is engaged or when I apply choke. I've twice cleaned carbs and still now working. I ran in garage with no air filter to elimina
hello sir, mower will not start or run,runs only when primming, does it have good spark,good compression,or only runs on full choke, are you getting fuel to the engine if not try this,your fuel pump or your carb. is clogged up here is what you can do for a simple repair for the carb,you can remove the air filter and assy, empty fuel tank and clean out tank and line,remove the bowl nut and bowl careful of the gaskets,now spray carb cleaner in the small port holes in the carb steam in the middle of the carb until clean,now spray the bowl nut holes until clean there are three,after cleaning put bowl on the same way you removed it with dip towards front of float,put bow, and fresh gas,you should be good to go,hope this helps.,thank you.~~
Feb 19, 2012 | Mtd Garden
2010 model 20 hp Briggs motor. Fuel going through fuel line, but not going into carberator. Motor runs good for about 15 min, but after heating up this fuel problem starts. After cooling down for an...
Two things:
1 Is fuel coming out of the fuel line. Older mowers have old fuel lines and they tend to get weak and collapse went they warm up with engine heat. Replace the old fuel line.
2 deposits in the carb. take off the air cleaner, start it up and spray a good carb cleaner in the carb until the engine dies. Put some 'seafoam' in the gas and a little in the oil and put the air cleaner back on and start the mower and mow on FULL THROTTLE. this should claen out the carb. Yes the mower will run rough for awhile.
these two cheap fixes will solve 85 % of carb problems. GOOD LUCK
Jul 17, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
My engine turns but does not start i am getting spark at the plugs i dont think there is enough fuel being pumped in
Try getting a can off carb cleaner or brake cleaner and give it a good spray in the throttle/carb this will likely do the trick.
Jul 09, 2011 | Craftsman YT 4000 42" Briggs Stratton 24...
Briggs and Stratton lawn mower engine Model 10H902. Surges up and down but runs and is usable. Uses lots of gas.
surging is most likely starving for fuel try to clean carb with spray and replace all the filters ? you may need to get carb rebuilt?
Aug 29, 2009 | Garden
My 18 hp twin cylinder Briggs and Strat. Craftsman lawn tractor moter surges and dies. I cleaned the carbuetor body and the goveror linkage. No problems found. I rebuilt the fuel pump rubber and...
Hi..my name is Keith...and the engine is running too lean..and with you choking it..it richens the mixture..so its a carb problem..and that could be several things..1)..is the main metering jet needle on the bottom of the float bowl needs to be turn out until the engine runs smooth..or 2) the carb to engine gasket is bad and its sucking air..or 3)..the passage ways in the carb is stopped up..i hope one of these will help..if not please write me back
Jul 10, 2009 | Garden
My Sears riding mower chokes itself out after warmed up,
Careful with the high octane.. That can burn a hole in the piston..
It might be fludding.. At the bottom of the carb should be a bowl.. One bolt at the bottom.. Take it off and clean it.. Spray some carb cleaner up in there where the float is..
If that dont do it --
Maybe the float is bad & taking in fluid..
If it has sat for long piriods of time - the carb might need to be cleaned & rebuilt..
When gass sits in there for a long time it shalacks and wont work correctly..
Pop off the carb & take to your local small eng shop. Shouldnt cost to much..
Jul 09, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
350 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
