Question about Compaq Armada M700 Notebook
Activaion KEY NEEDED BAD!!!
I lost everything in my cpu. I'm trying to get most of the important apps back. My instillation code is.
040195-784696-752786-506806-887660-393175-335915-886301-363581.
Giving this as a gift. PLEASE, PLEASE HELP.
Thanks a million.
DNELL
  • Compaq Master
  • 4,806 Answers
Unfortunately we can't give you a product key or activation code to activate the operating system, on Microsoft can do this.
The product key should be on a sticker underneath the laptop, use this key to activate the laptop. If it won't allow it you will need to activate by phone, tell Microsoft that you had a hard drive failure and they will activate Windows for you, just give them the code you have posted and they will walk you through the activation by giving you another code to input.
Have a pen and paper ready to write down the code.
How to activate Windows XP by phone loadTOCNode(2, 'summary'); To contact a Microsoft customer service representative to activate Windows by phone, follow these steps:
  1. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click Activate Windows.
    Or, click the Windows Activation icon in the notification area.
  2. Click Yes, I want to telephone a customer service representative to active Windows now.
  3. Click Read the Windows Product Activation Privacy Statement, click Back, and then click Next.
  4. Follow the steps in the Activate Windows by phone dialog box, and then click Next.
    Note The number appears now and differs based on the location that you select.
  5. When activation is completed and you receive the following message, click OK. You have successfully activated your copy of Windows.
Good luck.
Posted on Sep 08, 2009
How would i know if i hav a cpu problem 4 a car?
I assume your talking about the CPU in the "Brain" ...the electronic device that handles the engine ignition, monitoring, and operation of the engine and major associated engine components.
I would take it to the dealer and request a diagnostic test. Cost's a bit, not too much, but a bad CPU would produce no codes for the test ...or produce a 'bad' CPU code... both revealing a bad CPU. The dealer or a good repair shop can tell you if the CPU is good or bad.
You might try disconnecting your positive battery cable for 30 seconds or longer. This may reboot the CPU and reset it to normal operation. Then drive your car a couple of miles so it can
'normalize' itself . If you do this first...it would probably erase the stored codes if any for the dealer test. If you have a bad CPU, it wouldn't matter. BUT if it's not a bad CPU... you've lost your codes and a more simple 'fix' by telling you what 'was' wrong.
You can also Google your problem and find people's insight... having the same problem with the same model car
Good luck . .---bp
Nov 09, 2014 | Computers & Internet
Tip
How to Format ur s60 nokia phone
Its important to read through this topic before you proceed with formatting, you will need to charge your phone at least half full to enable a successful format.
Soft Reset *#7780# : Restores ini files from rom but preserves user data (photos, 3rd party apps etc) - Hard Reset *#7370# : This reformats the C: drive completely and all applications and files stored on this drive will be lost. *
With *#7370# and *#7780# the lock code will be asked before formatting the phone so be sure to remember your code, the DEFAULT CODE by nokia is 12345. *
Firstly you might want to make a back up of all your important bookmarks, calender, notes and contacts, Using file manager go to c:/system/data find bookmarks.db for bookmarks, calendar for calendar, notepad.dat for notes, and Contacts.cdb for contacts. *
Contacts can only be copied when phone is in offline mode/flight mode, use Psiloc System Tools for flight mode, not needed on 6630 or later. Or you can use Contact Manager app *
Ok so 7650, 3650, 3660, ngage and ngage qd can only be formatted using *#7370# Before your format, be sure that the problem is on phone, remove mmc and see if problem still exists. *
Also try starting in safe mode (press and hold pencil/abc key while turning on till op logo comes up). You can solve an apparent problem with simple solution
6260, 6600, 6620, 6670, 7610, 6630, 6680, n70 etc: Turn phone off, press and hold the green (talk) key on the left + number 3 on the keypad + the * key and then turn the phone back on. Keep pressed until phone boots up. *
Fonts and Formatting. If you have any fonts installed be sure to remove them using Font Remover app or go to c/ or e/ system/ fonts/ and rename it to whatever and delete it now reboot phone before you attempt format. *
and above all,this is very important,don't mess with file explorers (delete,rename,alter files) if you don't know what your doing. *
and yes,formating phone (soft/hard) can screw some app's on mmc. Some will work fine,others don't coz they share files on both drives (c:/e: ) *
OPERA - to copy opera bookmarks before formatting mmc, assuming opera is installed on e-drive. e/system/data/opera/bookmarks
don't forget to click the THANKS button.
Closed Thread
on May 12, 2010 | Cell Phones
I need an Authorization code for Photoshop CS2. S/N: 1045 - 0436 - 9551 - 0266 - 5984 - 9386 Activation Code: 3550 - 4696 - 3534 - 7261 - 0749 - 1242 - 1155 Activation Type: Normal 93: -13 Please and...
i need authorization code for photoshop cs2
s/n is 1045 - 0436 - 9551 - 0266 - 5984 - 9386
activaion number is 6322 - 0929 - 1695 - 9717 - 4625 - 4748 - 1610
May 11, 2010 | Adobe Photoshop CS for PC
I cant instill themes on the diamond
What is the message that you get about the cab files?
Aug 08, 2009 | HTC Touch P3450 Smartphone
Printer
Windows comes with drivers for many HP printers.
You can try to install your HP deskjet 5440 by going to (depending on operating system) "Start", "Printers and Faxes", "Add Printer". Select a local port. Select "HP" and Model "HP Deskjet 5440".
If 5440 is not in your list, or if you want the latest driver, you can download the driver for your specific operating system here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=445441&lc=en&cc=us&dlc=en&lang=en&cc=us
Aug 02, 2008 | HP Deskjet 5440 InkJet Photo Printer
I lost the instillation CD and need the wep code
The WEP code is whatever you make it when you set up the wireless connection. If you have lost this key. It is best to use the manual reset located on your wireless router. Will require a small point like a paperclip. Then you will have to access the router and set up the wireless internet over again. Then you can secure it with a new WEP key.
If you need further assistance please ask me.
Thanks,
Lee
Jun 17, 2008 | Belkin (F5D7633UK4A) Wireless Router
Error code E03
Hi. It could be bad. Your battery has probably failed long ago, and it needed to use it when the power went off. try this:
Turn key to PROGRAM mode.
Power off at wall.
Hold RECEIPT FEED down while turning power back on at wall.
Wait 10 seconds.
Let go of button. You should see 'FFFFFFFFF' on display.
Press SUBTOTAL
Check the printout. Look under the copyright at the bottom right, and you should see a number e.g 10801 or similar. If it's all zeros, you have lost everything, and it will need to have the batt changed and fully reprogrammed. Otherwise, turn to REG mode, and try it.
Mark
Apr 05, 2008 | Casio Parts Cash Register PC Desktop
Compaq Armada M700 Notebook Logo
244 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
