Question about IBM Infoprint 40 Laser Printer
Ibm info print 40 fuser 90h3567 same as xerox n40 fuser 109r486
Is ibm info print 40 fuser 90h3567 same as xerox n40 fuser 109r486?????????Can anybody Help me....
    Scholar:
  • 81 Answers
Xerox put identity chips into their consumables and I presume IBM do the same which means even if the fuser is exactly the same your printer is going to reject it as a incompitable part
Posted on Sep 08, 2009
Testimonial: "Thank You!!!! I appreciate your respond..."
We changed the fuser on the IBM Infoprint 40 Model #004, Type 4332. However, after changing the fuser, we still get an error code in the display that says "008 Change Fuser." What does code 008 mean? ...
008 is the printers code to tell you to replace the Maintenance Kit. IBM Part Number 90H3567. After installing it, you have to make sure to tell the printer to reset the count value for that maintenance kit.
Jun 11, 2010 | IBM Office Equipment & Supplies
Where do you install the fuser cleaning wand?
On the top of the machine (right where the paper lands after it prints) there is a small cover you can open by pulling it to the side and then up. The wand goes there (on top of fuser and under the cover) Make sure you pull the old one out or the new one will not go in the hole.
Mar 04, 2010 | IBM Infoprint 1332 Laser Printer
Printer will not power on. Electric outlet checks
Without knowing your skill level, your best solution is to get a repair tech on site.
I would suspect that the power supply is shot. If you can get to it easily, verify the power in voltage and then the power out voltage.
However, there are many possible causes, for example, on the IBM copiers I used to service there was w fuser overtemp sensor and a fuser lamp fuse. If either of them opened, then the same failure would present itself.
I must mention that I have not worked on an IBM Copier for about 20 plus years but the design of products such as copiers demand safety cut-offs.
Don
Dec 10, 2009 | Xerox WorkCentre Pro 412 All-In-One Laser...
Infoprint 1512 prints blanks from int. and ext. print source
How to get on software to setup for printer , infoprinter 1512 ( Ibm ) .
tha for kind wondows ( wondows vista )
Aug 14, 2009 | IBM Infoprint 1512 Laser Printer
Is $80 (CAD) a good price for used IBM 1222 printer w/ 50% toner
It's a good price, you mainly look a rubber rollers for age or wear, listen for quiet smooth printing, if you can look at the fuser rollers in the exit, look for wear and toner sticking. Print quality issues may show need for a toner cartridge.
Aug 11, 2009 | IBM Infoprint 1222 Laser Printer
Hi, I have an IBM Infoprint 1352 and it keeps having a 925 fuser error, the Fuser and LVPS (low voltage power supply) have both been replaced and the error comes back within a day or less. Any ideas?
Okay, I need some additional information from you and I have a couple of suggestions for you.
First, is your printer plugged directly into a wall receptacle? If not, plug the printer cord into one.
A couple of other things could be going on. The fuser that was used may not be the correct fuser. This can cause the fuser sensor to report an error based on the wrong heat lamp inside the fuser.
The system board (motherboard) may be reporting the error incorrectly/ In which case the motherboard should be replaced.
The fuser sensor may be defective.
If the repair was completed by an IBM Certified technician, then there is a warranty period associated with the repair. Call your local IBM Office and ask for a service manager and issue a complaint on the repair activity.
IBM may in turn refer you to a TSS manager or choose to handle the complaint on its own. When I was a field tech for IBM, the goal was first time final, so I imagine that they will be very concern that the tech has been there twice and yet the failure is the same.
Good luck Don
Jul 15, 2009 | IBM Infoprint 1352 Laser Printer
IBM Infoprint 1532
There is probably a small piece of paper in the back of the printer in the fuser. Shutdown the printer and wait a few minutes as this part is hot. You may need to remove a few screws to take off the back cover and check inside the fuser.
Jun 03, 2009 | IBM Infoprint 1532 Laser Printer
IBM SELECTRIC III, won't print
try turning the metal shaft that the carrier is on. turn it towards the back of the machine.
Apr 10, 2009 | IBM Wheelwriter 30 Typewriter
IBM Infoprint 1352 Laser missing an inch of test on the left hand side
could be, but first take out the cartridge then look inside the unit there is a black roller, kind of spongy or hard rubber, is the black part towards the right? grab it and give it a tug and see if you can SLIDE it to the left if so then it needs to be replaced, that is your problem.
It could also be the fuser, are the copies on the left coming out smudged or with a grainy shadow? then it's the fuser.
Oct 11, 2007 | IBM Infoprint 1352 Laser Printer
IBM Infoprint 40 Laser Printer Logo
297 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
CheckitRight
CheckitRight
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
