Question about GE Kitchen Ranges
GE gas oven Mdl# JGBS23WEH1WW oven lights even though the control knob is fully off. This happens any time of the day or night.
  • John Sep 12, 2009
    ignitor wires are not shorted out. Pulled out broiler drawer removed shield All wiring looks fine.
  • John Nov 22, 2009
    Sorry it took so long to reply, we had other problems that were more urgent. The thermostat was bad replaced it the only problem was that the whole top had to be taken apart to get to the thermostat and capillary tube. Thanks for the help. John S.
  • 11,896 Answers
Control knob may be faulty. Otherwise if you can see a relay, you may want to test that with ohm meter to see what position it is in.
Posted on Sep 12, 2009
  • Nate Stansfield
    Nate Stansfield Nov 23, 2009
    Also check the thermostat and it's connections. Sometimes these can become clogged, or corrorded and faulty. It is under the top cover to remove. You can test power to and from the connections with a VOM.
    Same with power to and from control panel and from thermometer, thermostat, control knob to main control panel/board as well.
    President:
  • 744 Answers
Hello, Your igniter for the oven is shorting against the chassis of the range, pull the drawer out and check one of the wire nuts is not lose or fallen off. Make sure the wire is not shorting down to the chassis. Mike
The oven lights randomly even though the control knob is set to"off." The stovetop burners work and the oven lights on demand. I have the range gas and electricity shut off until repairs are made.
Hello. I don't know how old this model is but I couldn't bring up parts for it--it sounds like from what you've described, the oven control is shorted--probably from grease or other contaminants getting inside. The clue is that the "oven lights randomly even though the control is set to *off*.
Sep 04, 2015 | Kitchen Ranges
Oven not working
Gas stove check gas oven safety value
Mar 17, 2014 | Ariston Technologies Ovens
My General Electric microwave shows RESET on the console but none of the buttons are responding even though i have plugged and unplugged it a couple of times
Good day Sir, here's troubleshooting tips.
Problem: Oven will not start
possible causes: power surge/plug not fully inserted/door not securely closed/start pad not pressed.
Jan 24, 2010 | General Electric Microwave Oven
Kenmore gas stove - oven won't ignite
hi gud day,do u think the gas is ok or every time u open is come out, or check ur control gas line valve maybe it close or authomaticaly close due to some laekage. chect it by smeling every turn on ur knob,but unplug the item b4 u do.
tnx gerbee
May 27, 2009 | Cooktops
Oven not working. Top, broiler, and warmer are working.
Have you checked for proper gas flow into the over or broiler? This is a gas valve back there that will sometimes go bad. Also there is a sensor near your knobs, it is a timer that will go bad, the valve is about 85 dollars and the timer is about 65 dollars
Feb 08, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Display goes blank, no heat, no oven
This I hope will be an easy solution for you. I think you have a circuit breaker tripped or a fuse if you have a fuse panel.. I am guessing you have an old fuse panel. When you have a fuse blown on a 230 volt appliance and you turn a swith on (like your knob) it feeds back to other circuits on the 120 circuits and will make it do crazzzy things, like making lights and clocks work..Regardless if you have fuse or breaker you dont have the 240 volt to run the range..You only have one120 volt leg powering your stove.
Nov 03, 2008 | GE Kitchen Ranges
Display is blank, no heat no bake
The oven control panel has failed. For more tech help with this issue and a place to order parts I suggest you go the link below, it is where I go for parts and help. You will need to model number available. Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Jun 28, 2017 | GE Monogram ZET3058SHSS Stainless Steel...
GE Oven does not light - no gas smell and no electronic ignition clicking sound
Gas oven does not work. Burners and broiler work. When oven kGnob is turned on, there is no glow at ignitor, nor any gas smell.
Jul 21, 2008 | Kitchen Ranges
Starter
Sounds like one of the control knobs got stuck or shorted in the start cycle. Can you get access to the inside where you can see each of the control knobs? Look for wiring and unplug one at a time. This may help you figure which one is shorted.
Mar 21, 2008 | GE JGRP17 Gas Single Oven
Burner will not turn off
I will need the complete model #. There should be a sticker near the bottom front behind the drawer. Can't use the # that is on the owners manual.
Oct 08, 2007 | GE Spectra JBP78 Electric Kitchen Range
Open Questions:
Kitchen Ranges Logo
49 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
