Question about Sharper Image Ionic Breeze 3.0 Air Purifier
It dont blow out air,,doe;tsclean air quite
It dont blow out air,,doe;tsclean air quite working,
  • 55 Answers
These things are junk. you could also be doing more harm than good to yourself and the indoor air quality in your home with the amount of ozone these appliances omit into the air. throw it away
Posted on Sep 13, 2009
Fan on air cleaner blows out top but does not suck
If air is blowing out - it most assuredly is getting in. The area of the intake make be large enough for you to perceive air being sucked in.
Make sure ALL filters are clean. Remove and replace disposable filters or wash and replace permanent filters. Do this for pre-filters too. Then, try again.
Oct 23, 2015 | Hunter 30200 Air Cleaner Purifier Filter...
Air conditioner hums does not work
Check your breakers if they've tripped the condenser will try to come on but the fan won't blow
Jun 14, 2015 | Trane Air Conditioner Accessories 1 Gal....
Were to buy small fan units for Brookstone Pure Ion Pro?
The Best place I have found that has quite a few at reasonable prices plus knowledgable store personell that will guide you to what your needs are..and their warenty policy at Lowes Stores.is excellent....give them a try and good luck.
Sep 18, 2014 | Brookstone Pure-ion Pro Air Cleaner
My xl-15 air purifier works but it does not blow out air with the purified smell. I think I see people calling it ozone.bthere used to be what looked to be an illuminated orange light behind the fan. It...
Easy. You need new plates in the machine. They cost about $15 a piece. Google 'ozone plates for XL-15' & sources will come up on where to buy them. Remember to clean the plates every 30-45 days w/ 50-50 solution of ammonia & water & a tooth brush on these plates. Dry thoroughly w/ hair dryer before putting back in machine.
Feb 15, 2011 | Alpine Air Purifiers
My Ionic Pro Turbo air purifier is blowing air in intervals of 30 seconds, blows for 30 seconds then stops for 10 sec. then repeats. Is this normal or do I have a defective unit? Thanks, Jerry
Have you cleaned the unit good and made sure that there is nothing crossing the grid wires? It sounds as if it is cutting off and resetting for some reason. Mine runs continuously. I take an air compressor and blow mine out every time I clean it. Also, on some models, you have to hold the on button down for several seconds to reset it after cleaning. Hope this helps.
Jul 03, 2009 | Ionic Pro FULL-SIZE Air Purifier
How much water to put in rainbow rainbow and should it blow out air
Fill the water in the basin to the top of the peg in the middle of the basin. (a little over an inch in the 2 quart basin) The Rainbow blows out air just like any other vacuum cleaner does throught the exhaust port. It will blow out there while the vacuum is running if the exhaust port cover is missing. Otherwise, with cover in place, it will blow out air all around the mid section of the canister while it is running.
Jun 21, 2009 | Rainbow Rainmate Air Purifier
Water filter
electronic circuit needs repair
Jun 01, 2008 | PUR (FM-9500) Air Purifier
Does XL-15 air purifier work well in a lakefront home enviorment?
i dont know if it will kill mold. I had mine in the houston area--high humidity and it definetly cleaned the air. You could check with the manufacturer, their customer service is excellent.
Mar 21, 2008 | Alpine Air XL-15 Air Purifier
Dead
check power outlet / test the Blue air power cable w/tester continuity , switch on and off, tester move forward and reverse meter means good plug/ if does not move the fuse of the unit is open.need to replace.
Dec 28, 2007 | Blueair Blue Air 402 Smokestop Particle...
Filter Queen Defender red light will not blink
no with the red lite on it mean that you need to change your filter its a safety feature so you dont burn out your motor and also so you dont blow unpurified air through out your home
Oct 13, 2007 | Filter Queen Defender Air Purifier
Sharper Image Ionic Breeze 3.0 Air Purifier Logo
89 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
