Question about Acer Aspire E360 PC Desktop
My computer is an Acer Aspire ASE-360-U-A3503 desktop computer and I still cannot get the power up button to shut off no matter how long i press on it. Then the monitor cable connector on the CPU is not giving out to the connector from the monitor. It keeps flashing cable not connected when the two aren't together, and when i plug them together, it says no signal. Could you please tell me what is wrong i can't take it anymore
    Novelist:
  • 190 Answers
You seem to have two problems here: The power button and the video connection.
It should take 4 seconds of continuously holding the power button in for the PC to shut off, unless the settings under Power Saving say that doing this action should have a different outcome. Check your settings. If all is correct and you still cannot turn the machine off, you may have a deffective toggle switch. This is something you can get at Radio Shack or other electronics store.
Regarding the video connection: There's a set of buttons on most monitors where you can choose the input source. Your monitor has probably been set inadvertently to receive a DVI signal while it's connected via a VGA cable, or vice versa.
Posted on Sep 08, 2009
How do I find the Acer Aspire ASE 380 UD421A schematic?
Computers are wired like a car. Your "wiring harness" comes with plug ins for upgrades, like a second hard drive. In all likely hood if the computer is running correctly, these plugins are for upgrading purposes.
Jun 09, 2014 | Acer Aspire 2100 (91.AB675.D02) PC Desktop
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    My computer comes on but the monitor keeps
    check the resolution.
    start up through safe mode(F8 key before boot-up), and reduce the resolution.
    Feb 11, 2010 | Acer Aspire m5640 PC Desktop
    Put vista operation platform to sleep wont wake up but all lights are on on my acer l320
    I usually just shut the system down with the power button and then go into control panel, power options and turn all sleep and hibernate functions off. A deep sleep of the computer is usually initiated by hitting the power button and computers do not come out of this easy at all. All the sleep functions can be accessed in the power options of your control panel. Take your time and go through each one and modify the settings to accommodate your habits.
    Sep 12, 2009 | Acer Aspire L310 Desktop
    Thank you so much, but Im not really getting the computer to boot up so i could get into the settings on my Acer Aspire ASE60-U-A3503 PC Desktop computer. Like I said, The VGA connector when connected to...
    If you have more that one connection for the monitor try one of the others.
    This happens frequently when people add video cards and forget to disdable the onboard one or maybe swap to the onbaord one and forget to turn off the extra card.
    Sep 08, 2009 | Acer Aspire E360 PC Desktop
    What seems to be the problem with my Acer Aspire ASE 360-U-A3503 desktop computer. Turned computer on monitor is blank/black On the CPU the battery light is on fan is going very loud and when you go to...
    When you want to turn-off the computer hold down the power button until it shuts and it will.
    It seems to be hardware problem...
    So we have to proceed by elemination here...
    Now if you see absolutly nothing on the screen, chance are that you have a memory problem, maybe it just need to be cleaned, maybe you need to change a stick.
    First, take away the side cover of your desktop on the side that you can see the interior of the computer then you will see a/some slide(s) cliped-on the MotherBoard, unclip it clean the dust, you can take an eraser to clean the gold connector (you erase them and it will clean the gold). When it's clean, make sure there is no dust inside the slot of the slide and then replace it/them then try to boot the machine. If it work, your a winner, if not you come back to go further in the diagnosis.
    Thank you.
    Sep 03, 2009 | Acer Aspire E360 PC Desktop
    Pc frozen how do i reboot
    rebooting is restarting a computer..try pressing control +alt+delete simulataneously and then shut down..if that doesnt work..press the power button on a laptop for a few seconds..for a desktop press the reset button below the power button(if there is one) or the power button or remove the power cord...hope it helps!
    Nov 08, 2008 | Acer Aspire 5100 Notebook
    Cant shut down
    keep start button pressed 30 seconds, the pc should turn off. If not brutally unplug the power cable. Do a scan disk on restart.
    Feb 16, 2008 | Acer Aspire™ T180 PC Desktop
    How can i get my computer to turn off automaticaly
    What OS are you running? Try hitting control/alt and delete at the sametime when the task manager open click on shut down computer and see if that works.
    Dec 16, 2007 | Acer Aspire T310 PC Desktop
    Acer Aspire E360 PC Desktop Logo
    133 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Steve Sweetleaf
    Steve Sweetleaf
