Question about Canon PIXMA MP830 All-In-One InkJet Printer
Canon MP830 6A00 Error. Took the unit apart. Cleaned the purge unit. Still didn't work. Was able to manually rotate a gear on the purge unit which allowed it to move through its' cycle. Initially had to wind the gear backward and then forward to complete the cycle because it stopped turning forward after each phase of the cycle. After multiple times going through the cycle this way, It appeared to turn continuously in one direction without stopping and I was able to have the unit go through a complete cycle without jamming. After test runs appeared to work, I reassembled the printer, but the 6A00 error returned and the purge gear it sticking as it did earlier.
Canon ipf 750 e161-4050
The error refers to a purge motor failure. Which could explain why the printer is saying that you do not have enough ink. You can solve this error code by removing the purge unit. You have to replace the purge unit with a new one.
Read more: E161-4050 on iPF750. error not in manual. Cleaned print head? - What is this? Not on internet anywhere. I`m sure others have had this issue. :: Ask Me Fast at
Jan 11, 2013 | Canon iPF700 InkJet Printer
Error6A+MP810 No print, no scan, no normal operation
12 times AP position error [6A00] An error occurred in the AP motor during purging
operation.
- Sheet feed unit
- Purge unit
- Logic board*
Try to manually move print head at left position and then try torotate the gears of purge unit, if it moves (purge unit) switch off and on printer
Jan 12, 2010 | Canon PIXMA MP810 All-In-One InkJet...
Canon MP830 Purge unit sticking
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 10, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I have a printer MP620, and get a error 6A80 need help.
6A80 can be either a sheet feeder error or a purge unit error, either can be caused by paper scraps or other debris caught inside. You need to inspect closely with a flashlight and remove any scraps, beyond that you may need a shop to take apart and replace gears or even a purge assembly.
Oct 22, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Canon printer mp 510 error 5010
That is a purge system error, either you need a new purge assembly or there is a paper scrap caught in there stopping it. The purge unit is on the right where the printhead parks at shutdown and where the printhead is cleaned.
Aug 25, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Canon IR 1600 the code display 000
Main motor malfunction error.Remove the fuser unitmand rotate manually to see to work easy,if not the problem in this unit(change the bearings or gears).Rotate the transfer unit and developer unit manually.If worked is OK.Open the front door turn OFF the power switch,wait 3 sec.turn ON and closed the front door.
Aug 20, 2009 | Canon Office Equipment & Supplies
Need disassembly instructs for canon mp780 printer purge unit
Canon doesn't have instructions to take apart that part. A new one is around $40.00.
HY7-2919-020
Jul 27, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Error code 4 flashing orange - code 5c00
Hi Chris,
Error code 5c00 (flash in orange /green 4 times) indicates that purge unit has broken so that the printhead is locked down when initializing process performed. Sorry I have to say that no first aid for this problem unless you bring it to nearest service centre for part replacement. Hope this information helpful for you.
Regards,
Source:
Canon Inkjet Forum
Dec 13, 2008 | Canon PIXMA iP90 Mobile Printer
CANON i860 PRINTER - ERROR SIGNALS
hi i am a certified Canon tech for a repair shop on the east coast of the united states. by what u are describing the problem seem to be with the purge unit that it is not spining to release the carridge unit. this could be due to something stuck in the purge unit or in its gears. if you take the top cover off the machine on the right side is the purge unit towards the back of the unit is a white release that has to be pushed down inorder to move the carridge unit. once that is released you can look into the purge and check for things jammed in the gears or obstructing the up and down operation of the purge pad and the back and forth operation of the wiper assy. if everything looks normal the purge unit most likely is still at fault and can be purched for 30-40 dollars plus shipping.
Jan 03, 2008 | Canon i860 InkJet Photo Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
309 people viewed this question
old marine
old marine
