Question about Sony Cyber-shot DSC-W55 Digital Camera
WHEN I TURN THE CAMERA ON IT COMES FIRST THE CANNON DEFAULT AND
THE IN THE IMAGE SCREEN IT LOOKS LIKE TURNING ON AN OLD TV WITH OUT AN ANTENAE , BLURY JUMPY. CANNOT TAKE A PICTURE SINCE YESTERDAY
    President:
  • 1,564 Answers
Try cleaning the battery compartment with a Q-Tip dampened, not soaked, in rubbing alcohol. Then do the same to the battery and the charging station.
Posted on Sep 08, 2009
I try to turn my proscan tv on and the the power comes on but before anything the tv blinks a d it turns off immediately, any advice?
About 51,900 results (0.55 seconds) Search Results
    My Proscan 42 tv is turning on and off by itself, changing ...
    www.shopyourway.com > Manage My Life > Questions
    Oct 16, 2012 - My Proscan 42 tv is turning on and off by itself, changing channels on it's ... that is next to the power connection plug is discolored at the board.
    Proscan/RCA 123882 Power Supply Unit (PSU) Boards ...
    ? 2:48
    https://www.youtube.com/watch?v=TC908vQ8jaw
    Jan 17, 2013 - Uploaded by ShopJimmy.com
    RCA TV Repair for Blank Screen TV Will Not Power On How to fix... I have a Proscan PLDED3273A-E. Looks like my problem is the L1 (brown spot on board) - any suggestions? ... before it turns off the audio still works and the image still comes out if I ...Recently I tried turning it on and I get no standby light.
Jan 25, 2016 | Proscan Televison & Video
Canon rebel xt 1. image looks blury in eye
1. The viewfinder's diopter is probably out of focus (doesn't affect Auto Focus of photos). There's a dial and a +/- symbol next to the viewfinder. Turn the dial till you can see clearly through it. Alternative reason: The glass in the viewfinder is dirty/foggy. Use camera cleaning solution (a drop) on a cotton bud to clean it.
2. Malfunction needs Canon Service Centre to take a look at.
Dec 25, 2009 | Canon Rebel XT / EOS 350D Digital Camera
My tv is almost 6yrs old and all of a sudden the picture is blury almost showing double images. The color is also of at the top and bottom of the screen.
this is typic old projection tv, some tecnical ajust parameters have reset, so if you can adjust,this settings on service menu on tv, or ask for help on local repair store, to calibrate scren.
Nov 29, 2009 | Televison & Video
Our tv is blury, double vision with whites going
There seems to be two problems with the unit. The first symptom indiates your convergence IC's needs to be replaced. The second symptom coud be a several things, 1. Bad connections on the Crt board of the green tube, 2. The 200v screen bias voltage supplied by the flyback could have bad connections on it. Seems you have intermittent cold solder joints. Check the D board around the Flyback area for bad connections, or old grey looking solder connections all should look shiny. 3. The Green Crt maybe going faulty, the lines going thru the picture are scan lines and indicates that the Screen controls are to high. But i know you have'nt adjusted these so i would suspect the Green Crt is Faulty. But check solutions 1&2 first, One way to find out if its bad is to unplug the green crt board from the tube and turn the set on if it stays on and does'nt shut down then it is faulty, also while turning on look at the crt's neck for sparks which indicates arching in the tupe and will need to be replaced. Replacing the Convergence IC's will solve the distorted pic issue.
Nov 17, 2009 | Sony KP-51WS500 51" Rear Projection...
I have a Canon PowerShot S400 and every once in a while the image gets blury and the colors are off. is there something I can do to fix it?
This is problem with the sensor. See this link. Canon has acknowledged issues with sensors in some model cameras, including the S400. Instructions are provided on the link to have your camera repaired at no cost, regardless of purchase date. If you don't live in the US, contact your regional Canon service agency. This service notice is effective world-wide.
Let me know if you need further assistance
Thanks
Kinldy rate the answer
Kevin
May 12, 2009 | Cameras
Moto v3i camera is not working
You should take the phone to a mobile shop and have them flash the firmware on the phone.
Dec 11, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Powershot screen is black
Dear 31jp:
It sounds at first glance as though you're probably experiencing a failed CCD image sensor. This model has an product advisory out on that very issue.
First try pressing the display (DISP) button on the back of your camera several times to see if your image returns at any time. One of the three display modes is "off" to preserve battery life. Your problem may be as simple as inadvertently pressing this button into the off mode.
If that doesn't work, try doing a reset and then removing your batteries from the camera for a few minutes, reinstalling them and turning the camera on to test the LCD screen.
If your screen is still black, but you can clearly see pictures taken previous to the problem, and you can clearly see the menu system when you press the MENU button, then you likely have the CCD sensor problem. Contact Canon Tech Support at 1-800-828-4040 to have the camera repaired. If yiou are experiencing the image sensor probem as described in the product advisory, the camera will be repaired at no charge regardless of how long you've owned it.
Hope this helps.
Sincerely,
HeavyDLB
Jun 01, 2008 | Canon PowerShot S45 Digital Camera
Blury image
change the setting go to the ocd. and change it to auto..
May 10, 2008 | Samsung Digimax D53 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
