Question about Audiopipe Audio Players & Recorders
I own an audiopipe apa 2500 amplifier. When I put it on there is alot of ststic coming from channel 1. After awile it goes away but off and on during my playing you can hear the static. Now all of a sudden channel 2 does not play. Give me some advice. I love my audiopipe
petraman7
  • 1175 Answers
SOURCE: Proton 520 Integrated Amplifier with quiet left channel
Hi...
Flush all the switches and controls with De-Oxit D5 or better.
Then get back to me.
Thanks
Posted on Mar 01, 2009
pjszilard
  • 72 Answers
SOURCE: ONKYO tx-sr605 HDMI CHANNEL 2 INTERMITTENTLY SWITCHES TO STANDBY
Check the Ohm value (4, 8, 16...) on the speaker and on the ONKYO too.
If not the same that is the (big) problem!
Posted on Nov 24, 2007
battlesmith
  • 382 Answers
SOURCE: Cassette Recorder play problem
Belts are prone to harden over time,the belt will be broken so replace it.. Also as you say the unit does turn off which is the problem of Take-up reel sensor ..Try to Take to any Service person and replace it,your player will be back in condition..Thank you..
Regards!!!...
Posted on Jul 24, 2008
SOURCE: Playing regular cds with serato
cdj
Posted on Dec 02, 2008
SOURCE: hitachi 42edt41green static
Dave you know your stuff man !!! You helped me fix my black line fix on my LCD / Plasma and then now you helped me get rid of my green dots on my screen !! You rock . thanks a Million
My audiopipe GM-1502 amp went into protect but i checked the circuit board and nothing seems to be blown or burnt but it won't come out of protect what could be the problem
If your voltage is good and you disconnected the speakers then you have damaged components on the board. You cannot tell they are bad by looking at thwm. The amp needs repair.
Oct 28, 2016 | Audiopipe Car Audio & Video
The channel 1 the light red is on
As always with stereo amps the two channels are identical, so if one goes wrong you have the other as a control for testing purposes. So if you start by looking and comparing the two channels. that's a start! If a part looks odd on the faulty channel, but is fine on the good channel you have found the problem. You can also do tests, such as touching the two channels with an insulated screwdriver, while powered up. If it buzzers on the good channel, it should buzz on the other channel at that point. Keep away from the power supply and ignore anything that is on it's own, that has no duplicate, or is common to both channels.
Feb 10, 2014 | QSC GX5 2Channel Amplifier
Audiopipe amp 1000w on 2 8" double ended bazooka
You may be over driving the speakers or there may be an impedance mismatch between the amplifier and speakers, especially if they are connected in parallel
Nov 12, 2012 | Car Audio & Video
Why is my blue power light flashing on my Audiopipe amplifier?
why is my blue light flashing an the red light staying on audiopipe amp
Oct 21, 2010 | Car Audio & Video
Amp will not come on keeps going into protection mode
nice amp you have to be leaking something from the car onto it. it should not get wet at all. did you go through the car wash and your whether striping leaks??
Apr 04, 2010 | PPI D2000/1 1-Channel Amplifier Car Audio...
My audiopipe 30001d amp come on but the protector light come on and it want work
Try unplugging everything exept the 12v, ground, and remote. See if you have the same problem. If no, you probably have a shorted speaker. If yes, an internal amp problem. brian.small@bobstgroup.com
Aug 11, 2009 | Sony Xplod Xm-zzr3301 Class D Monoblock...
No stereo signal out from yamaha p 2500 s
It's unclear what type of connectors are on the end of the cables(s) coming from your computer.
This amp only works with mono 1/4" TRS and XLR connectors, not standard RCA connectors.
Did you try the Right one in the Left Channel to see if the Left Channel worked?
Refer to the following manual and read up on the connectors (page 7) and the use of the Stereo/Parallel/Bridge Switch (page 8). When it is NOT in Stereo Mode the unit only uses the Right Channel controls and input.
http://img3.musiciansfriend.com/dbase/pdf/man/m_480824.pdf
STEREO/PARALLEL/BRIDGE switch
Use this switch to select the operating mode.
• STEREO mode
Channels A and B operate independently (as with a conventional
stereo amplifier). The Channel A input goes to the Channel
A output jacks, and the Channel B input goes to the
Channel B output jacks.
• PARALLEL mode
The Channel A input signal is output through both the Channel
A and Channel B output jacks. The Channel B input jacks do
not function. Channel A and B volumes can be independently
adjusted.
• BRIDGE mode
The Channel A input signal is output from the BRIDGE output
jacks. To adjust the volume, you must use the Channel A volume
control knob.
Apr 03, 2009 | Yamaha P-2500 Amplifier
Noise coming thru speakers
may be the ground of the rca or in your stereo. and many times in the inlet of the amp. good look.
Feb 09, 2007 | Clarion ProAudio APA4320 Multi-Channel Amp...
360 people viewed this question
Top Audiopipe Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Audiopipe Audio Player and Recorder Expert? Answer questions, earn points and help others
