Question about Rinnai Heating & Cooling
I just bought a house with a Rennai system still hooked up but they put in a brand new heating system so I can uninstall the Rennai. How do I do that or who do I call? Do the gas lines just get capped?
    Problem Solver:
  • 12 Answers
Call a plumber. Don't mess around with the gas! A slow leak could result in death.
Posted on Sep 08, 2009
Brand new rennai tankless hot water heater installed on newly built home. Rl75e model need to purge for the first time
Gas line I take it . You will need to purge from the outlet of the meter first to make sure service line and meter are clear of air . And then close to the heater make sure its well vented and no source of ignition soap test any joints you loosen .
Apr 25, 2017 | Water Water Heaters
Tip
Underfloor Radiant Heating for Your New Sunroom
You want to add a brand new sunroom onto your existing house. The problem is that you are not sure how to heat it. Electric heating with baseboard heaters will spoil the look that you want from your new room. Hot water baseboard is going to present all types of problems getting hooked in to the existing system and piping it. And, if you have hot air heating system then you will have the problem of getting ductwork to the room. There is another way to heat this room easily and efficiently.
Radiant heating has been one of the most comfortable and efficient ways for heating for many years. The problem has been in the past to find a good heating source for small radiant floors that will be affordable, effective and efficient.
This problem has been solved now, with the availability of small new electric combination heater- circulator units. These units use small electric heating elements together with a small circulator pump to give you a all in one heating source and circulator pump.
Now you just have to lay your tubing in the floor of the room you are adding on to your house. Then you run that tubing into your existing basement or other room in your house. The tubing and the electric are attached to the heating unit. Then, wire a thermostat to the unit, and you are now ready to make heat. This really makes heating a new addition room very inexpensive and easy to do.
The greatest thing about using this type of heating system is that most average do-it-yourself types can do this. All that is needed is a basic knowledge of plumbing and electric.
If you are thinking of building that little add-on and are worried about how you will heat it, think about using radiant floor heat and a small electric heater-circulator to do your project.
on Dec 05, 2009 | Heating & Cooling
How do I repressurize baxi 380 without manual or do not see loop anywhere in new house I bought. Where can I purchase manual and loop
To determine if air is in the system, attach a gauge and run the system running pressure should stabilize if gauge pressure bounces then that would indicate non condensables in system.
Sep 23, 2014 | Heating & Cooling
Rennai hot water heater very slow to heat up!
I would check the gas pressure at the burner. It should be 3.5 inches water column on the manifold. Hope this helps.
Sep 09, 2014 | Water Heaters
Rinnai 2520 problem
yes but do not think you will find the solution here and not sure you would be able to accomplish this either
I would contact the mfg of both pieces and as well look for DIY sites that may be of some help and more detailed
It would take a l t of time to walk you thru this
This being more of a it is broke I need to fix it not modify website I would not attempt to do here
Be cautious taking help on the net just because it sounds right does not mean it is
Oct 18, 2013 | Water Heaters
Sled4668w tv scans channals but always shows 0 found hooked upto dish network
This Orion TV made by Sansui was bought by me two weeks ago. It didn't last a week. The sound was terrible, picture was great, and it wouldn't hook up to soundbar without hearing a long delay in sound (A/V or Digital output tried two). I contacted their customer support twice, they were awesome. Told me this model has know issues and said to just bring it back. I found another TV for same price ($399) and same size (46) but it's LCD not LED, better picture and great sound! It is Insignia don't remember the model #. Bought at Best Buy (their house brand).
Feb 22, 2013 | Televison & Video
Six wire hook up and new thermostat has only 5
Some thermostats have an extra terminal for an outdoor sensor which tries to anticipate the need for heating or cooling. If this option is not present, you will have an unused terminal which may have a shorting link to a neighboring terminal. Your installation instructions should mention this if the option is or is not included with your model. Also, heat pump systems vary in the system control voltage and not all thermostats and systems are compatible with the more common split system thermostat.
Oct 01, 2009 | Honeywell Electronic Programmable...
Rennai gas unflued heater kerosene fumes
Have it checked properly - sometimes the reg won't open fully, but the heater will still run, but with improper combustion resulting in a funny smell.
Aug 12, 2009 | Heating & Cooling
Ruud centeal electric
Is this an older gas heat unit? If so, you may have a burnt out heat exchanger, this can be dangerous.
Dec 10, 2007 | Heating & Cooling
Heating & Cooling Logo
32 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
