Question about Zebra Stripe S600 Thermal Label Printer
All lights are lit with pause and cancel alternating on and off. Other lights stay lit. Won't print anything.
Posted on Dec 14, 2009
Kenmore elite dishwasher manual
The cancel light is on because the cycle maybe paused or canceled. The lit red button should say Cancel/Drain. If you already tried to press start and if it won't finish the cycle then try pressing the Cancel/Drain to drain and start over.
Aug 15, 2014 | Kenmore Elite Stainless Steel 24" BuiltIn...
The CLEAN light is flashing on my Kenmore QuietGuard3 , but it won't clean anything. It starts a cycle for a few minutes, stops and starts flashing clean again. Any suggestions?
You will have to reset the dishwasher. First try and turn off the mains power and back on after a short time. If the clean light flashing starts again then you go through the hard reset procedure.
press NORMAL WASH then HEATED DRY buttons one after the other until all the lights on the board lit up (3X's). The dishwasher will enter into a cycle; Press Cancel. This should stop the flashing.
If you are supplying dishwasher from hot water inlet then make sure the inlet water temperature stays within the recommended range of 145 deg F.
Apr 21, 2013 | Dishwashers
Canon IP5200R printer. Green & red led`s flash 20 times, pause & repeat. print head will not come out of park position on righthand side. Fault occurred while printing a photo error 6500 displayed
Hello!
Error 6500 or green and red flashes 20 times, mean hardware error. Particularly, the Logic Board Assembly
There are two possible fix: first is to reset the printer's waste ink counter and the second is to replace the Logic Board Assembly (part # QM2-2733)
Reset the Waste Ink Counter:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the
Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a
function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power
button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
For technical help:
  • For toll-free technical support, please call 1 (800) OK-CANON (1-800-652-2666) during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. ET, excluding holidays).
  • Toll-free TDD Support Line for the Hearing Impaired is available Monday - Saturday (excluding holidays) at 1-866-251-3752
Hope this helps!
May 18, 2011 | Office Equipment & Supplies
When the printer has big green light and a orange light what does this mean?
Do you mean that the orange attention light is lit and the Go button/light is lit? If the attention light is blinking, then the printer is in manual feed mode or out of memory.
Put in the media and press the Go button. To reset the media selection, go to the Printer Properties. When printing from an application, click Print and then Properties. From the Printer control panel (Start > Devices and Printers (on recent Windows versions) or Start > Settings > Printers (on older OS versions - prior to XP).) In either case right click on the printer icon and choose Properties or Printing Properties.
If you have too large a file (too many large images) and are out of memory, stop and cancel this file in the print spooler. Then reprint with a lower resolution. (This is in the Print Quality options. See the above and then the Paper/Quality or Finishing tab) Options will vary depend on the OS. Alternatively, add memory to the printer.
If the Ready light is also lit, the error depends on the pattern. If the lights are blinking in rotation, then the printer is initializing or printing a test page. If the lights are steady, you have a fatal error. Try unplugging the printer for at least 5 minutes (remove all cords from both the wall, computer and printer for the best chance of clearing the error.) If the error persists, the printer needs service. If all of the lights are blinking together, than you have an accessory problem. Try removing the memory. You may be able to reseat the sticks; alternatively replace the memory.
I hope this helps.
Sep 03, 2010 | HP LaserJet 1300 Printer
Green power light is flashing and red light next to it stays lit
A flashing green on printer light generally means its waiting for a command for instance, push print, stop etc... also check that the pause button has not been pushed. if so depress again to release printing process
Jul 11, 2010 | Epson Stylus Photo 1280 InkJet Printer
Power light lit Pause light lit data light flashing and display saying printer idle , ribbon out
Press the pause button to take the printer off pause...
The data light is flashing because it has labels to print...
Check to be sure your ribbon is loaded properly.
Jun 20, 2010 | Zebra 203DPI Printer
Control lock stays on and no other buttons are working. I went into the laundry room to find the Control Lock light was lit. As I tried to hit the Pause/Cancel button nothing happened. No other buttons...
Thanks for using FixYa. To resolve this issue press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Apr 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Zebra Stripe S600 Thermal Label Printer Logo
446 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
