Question about Stoves 600SiDOm Gas Kitchen Range
Oven giving out awful smell when gases are lit transco have checked the gas over but no problem oven is also kept clean any logical explanation
  • kenaustwicke Sep 29, 2009
    yes quite a lot lately decorated staircase and living room
  • ITS THE GAS May 11, 2010
    HAVE YOU BEEN PAINTING OR USEING CLEANING MATERIALS .
Transco gas fitters have been working in my area and had put cleaning solution into pipework o/k now.
Posted on Sep 10, 2009
Why does my fan oven smell of fumes when switched on
could be a couple of reasons. if it is a new oven, it will smell for the first few times, they all do. If you have cleaned the oven recently it could be the residue burning off.
Oct 17, 2014 | Microwave Ovens
A gas smell is coming from the oven but all of the pilots are lit for the burners. The oven wont turn on.
Probably thermocouple needs to be replaced. pay attention to hygiene, KEEP YOUR COOKING APPLIANCE CLEAN and it will serve you reliably for a very long time. Keep it CLEAN and SERVICED and it will serve you for life.
Sep 10, 2011 | Tappan 30IN ELEC IGNa Oven
My Kenmore GAs RAnge Oven doesn't light up right away...lots of gas smell. The burners on top work though
check the gas range in the oven. clean the top apparently the ignitor isn,t working properly. I cleaned mine and once it lit I let it burn a while.
Aug 22, 2011 | Kenmore Kitchen Ranges
Oven & Broiler won't come on. I've installed new ignitor, bottom oven burner, and reg/ valve assembly. Ignitor heats up great, gas smell but just won't turn on. The digital oven control doesn't show...
Try to check the position of the ignitor.
Probably it is not aligned since as you said that gases already smells and still no flame.
Hope that helps you...
Thanks.
regards,
John
Jan 11, 2011 | KitchenAid KGST307 Gas Kitchen Range
Door does not close
After 3 years of perfect service, our toaster oven's door stop closing easily. After reading the internet and trying to contact Cuisinart for a solution I was stumped and frustrated. Someone on the internet mentioned using wd-40, but I didn't want the smell when I toasted! I try cleaning the metal arm that held the glass door using an alcohol pad and that actually helped a little! After thinking about something to lubricate the door are with that won't smell awful and hopefully won't catch fire -- I decided to try olive oil! I took a little, very little on a paper towel and rubbed the metal arm a few times -- It worked!!!!!!! The Door now closes with the greatest of ease! and doesn't smell awful when you toast, so far it has not caught fire. Give it a try! I love to give it 4 starts, but Cuisinart support didn't have a solution... I'm sure even if I suggest to them my fix that won't share the info, but use at your risk! I am certainly not responsible for any mishaps that may occur if try my fix, but worked for me.
Dec 31, 2010 | Cuisinart TOB-50 Toaster Oven with...
Did my self cleaning oven kill my bird?
no this should not have kille your bird.sorry to here about your bird. when using a self cleaning oven you should not use any king of oven cleaner in this will give of a smell that could have possibly cause the death of your bird but if no cleaner was used then your oven is in the clear
Sep 16, 2009 | GE JGRP17 Gas Single Oven
Gas smell coming from oven during preheat. once oven is warmed up, smell goes away. I have a Frigidaire FGF366EBC S/N VF6289284.What would cause this?
Typically, all gas operated appliances will get a "gas smell" from time to time. What you're really smelling is the odorant (rotten egg smell) that is added into both propane and natural gas, as these gases have no smell by themselves.
The smell will vary from normal to very strong as the "receipe" for how much ordorant is added into either your propane tanks or the gas supplied to your home. Typically, when tanks start getting low, the smell is more concentrated, while with piped natural gas, the smell can be very strong at different times, based on how and when the gas company adds odorant into the main supply lines.
Usually when a gas appliance is first turned on, the smell can be rather strong, until the gas ignites. So long as your oven is lighting properly, there is nothing to worry about.
However, if you're hearing a rather loud "whoosh" sound as the oven lights, it could be that your ignitor is getting weak and might need to be replaced. If you've got a weak ignitor, it could be allowing a little bit too much gas to build up in the oven compartment before it lights, hence the reason you're smelling the gas.
You can check for a weak ignitor by simply watching the oven when you start it, if the gas lights quickly, once the ignitor is glowing brightly and you've heard the "click" of the gas valve opening (in the oven), then everything is fine.
Hope you find this Very Helpful and best regards!
Sep 10, 2009 | Kitchen Ranges
Occasional gas smell
If you have a burner lit and gas build up, strong smell etc., my advice would be to stop using the oven immediately! You no way gas should come out, build up, to the point you smell it, Especially while a burner is lit. Dangerous condition.
Jun 21, 2009 | Viking VGIC305-4B Gas Kitchen Range
Kenmore Gas Range
The igniter needs to be replaced. I had the exact same thing happen to my oven. The igniter would glow, but after tested, it did not have enough amperage to actually ignite the gas, so the gas kept running with no ignition
Jul 19, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
GE XL44 Range
The pilot light is lit to light the main burner. First off, is your pilot light lit or is the igniter lit. There are two thermal sensor in the oven. One is above your pilot light and will not let the pilot light stay lit unless there is a flame. Secondly, you have a thermal sensor in your oven wired all the way to the switch to turn the oven on. If it thinks that it is at temp, then it will never turn on. This sensor may become bad or the case of my oven break. But if these are good, you many have a clogged burning unit underneath. Cleaning according to the owners manual may correct that. Check your owners manual to see what is user serviceable. Gas is nothing to play with.
Apr 20, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Stoves 600SiDOm Gas Kitchen Range Logo
119 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Ismael Rodriguez...
wayne murphy
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
