Question about SimpleTech SimpleDrive   STI-USB235/160 160 GB Hard Drive
1 TB Rock Mobile External Harddrive capacity
I just bought a brand new 1TB Rock Mobile external Harddrive? I understand that there is usually some information that needs to be preloaded or whatever and there is usually a loss of a some of the storage capacity. In this case though the Free Space on this drive is on 931 GB. That's like 69 GB of already used space and that just seems like a lot more than I would expect to see on a new drive. Anyone know if this is normal?? I am running Win XP if that helps.
    President:
  • 1,884 Answers
No. It is not that way. how it is read is as under: 1 K is 1024 bytes 1 MB is 1024 K bytes 1 GB is 1024 MB 1 TB is 1024 GB. As per books. BUT, when it comes to selling HDDs 1 TB is 1000,000,000,000 bytes. the extra 24 bytes at each lelvel have been overlooked. Thats where you loose so much of disk space.
Posted on Sep 08, 2009
My Seagate 1TB FreeAgent external Harddrive is not working on my laptop which is running on XP. In Manage Hardware section this device is shoing as unknown hardware.
go here
And download for windows. You see most companies like you to download the software from their website for older operating systems for your computer to recognize it.
Thanks, Cody
Sep 11, 2012 | Seagate Freeagent Go 1 TB Hard Drive
Buffalo external 1tb won't power up
Return the hard drive to the place of purchase, this is a manufacture defect.
May 12, 2012 | Buffalo Technology Buffalo DriveStation...
Hard drive clicks, fails to read but powers up. Approx 100GB of music files held and needs recovering. Laptop initially picks up drive on connecting to USB port but then drops out due to read failure.Drive...
Inside that plastic external case of the Hitachi XL 1000 external harddrive, is a regular desktop computer sized harddrive.
It is a SATA type of harddrive.
It is 3.5 inches across in Width. (3 and a half inches)
1 TB in size.
Looks similar to this example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5589521&CatId=2459
On the back end of the Harddrive is where it's power cable, and data cable are attached.
Inside the case of the Hitachi also is a small circuit board. (PCB or Printed Circuit Board)
The SATA harddrive is connected to this small circuit board.
The small circuit board, or Interface PCB , is attached directly to the Harddrive.
Or cables (Wires) are used to connect it to the Harddrive.
The Interface PCB is connected to the computer, via the USB cable that is attached to the Interface PCB.
It is this small circuit board that usually goes bad.
(Unless the external harddrive was on, and dropped. Then the problem is the Harddrive)
There are two solutions;
One, buy an 3.5 SATA external enclosure, and use the Harddrive as an external harddrive again.
Two, install it as a Slave drive in a desktop computer, and retrieve all your information. Burn to disk/s, or flashdrive/s.
When using a SATA harddrive as a Slave drive, there are NO jumper pins to mess with.
DO NOT change any jumpers on the back of a SATA harddrive.
(These are for the factory)
This is an example of a 3.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
There are no guides to open a Hitachi XL 1000's case, to my knowledge.
It isn't something the manufacturer wants stated.
However opening the external enclosure (Case) isn't that tough. It falls under the same as this model,
http://www.youtube.com/watch?v=hQ_vjyvK28A
Here we see at 3:00 through 5:00, that the Harddrive is attached directly to the Interface PCB.
Just remove the Harddrive from the chassis, and unplug it from the Interface PCB.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 02, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
The 1.0 TB External drive just quit being recoginized to either of my computers. It makes the connect and disconnect sound when plugged and unplugged but the computers never give me a external hard drive...
Do you know I had this exact same problem with my WD 1tb. What I done was stripped out the hard drive. Bought a SATA Drive Hub . And copied all data to another hard drive..
Hope this helps.
Jan 21, 2011 | Western Digital My Book Essential 1TB...
My XP will not boot when my Hitachi 1TB External USB 2.0 drive is connected. It gets as far as showing the Pentium screen and stalls.
Its probably trying to boot from your external drive.
Go into your bios and reset your boot setting to HDD0 as your first boot device, Disk drive 0 second and floppy third, unless you want to boot from an external drive. That being the case select an appropriate order.
If the bios shows your external HDD as HDD0, then you have to work out which is the drive carrying the operating system and set that to your first boot device.
To get into the bios, watch the boot screen for a key to hit to enter setup, normally its the "DEL" key.
May 03, 2010 | Hitachi 1TB External USB 2.0 Hard Drive
When i power up my 1TD external harddrive Windows is unable to access the drive or even reformat it is there a way to fix this?
Did you check the disk manager in Windows? Right-click My Computer and select Manage. You can see if the disk is there, if it is partitioned and formatted.
Could be a driver letter conflict.
Check some more ideas here: http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Dec 06, 2009 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
Samsung 1tb external will not allow my computer to boot
Try checking your bios to see what harddrive the computer boots from.
Your PC might be trying to boot from that samsung story which I assume doesn't have an OS installed.
Cheers
Oct 09, 2009 | Western Digital MyBook Studio 1 TB USB...
1TB WD essentials external harddrive timing out.
Well, never mind then. A simple usb port swap did the trick. Always something simple...
Sep 04, 2009 | Computers & Internet
Tring to back up pc to elements 1 tb external hd
Fat32 simply means that your hard drive can only read files up to 4GB, format your external harddrive using file system NTFS then try to back up all your files again. Hope it helps you...
Jun 22, 2009 | Western Digital My Book Home Edition 500...
SimpleTech SimpleDrive   STI-USB235/160 160 GB Hard Drive Logo
276 people viewed this question
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
