Question about Philips Magnavox MWD7006 DVD Player
NEED DVD CODE TO PROGRAM MY UVERSE REMOTE
TRYING TO ADD DVD PLAYER TO MY U-Verse Rmote to program it.
    Problem Solver:
  • 12 Answers
One of these philips/magnavox codes should work press dvd and ok buttons then release - the top row of buttons will blink twice - then enter 4 digit code - after which the dvd button will blink twice - then try power - if fails - try next code.
2002, 2018, 2032, 2033, 2045, 2051, 2089, 2091, 2109, 2169, 2208, 2209, 2222, 2237, 2241, 2243, 2259, 2260, 2264, 2270, 2282, 2285, 2293, 2302, 2304
Posted on Sep 12, 2009
  • 3 Answers
2302 worked for my philips dvd player and uverse remote
Posted on Sep 16, 2012
How to Program an At&T Uverse Remote Control?
Turn on your U-verse TV, press Menu on your U-verse remote ,
select Help, Information, and then Remote Control Setup. Next,
select your remote control from the TV onscreen list. Refer to
your specific remote for TV/device setup options. Select Top Ten
Brand Setup, Automatic Code , Learning Mode, or Manual Setup.
Oct 19, 2016 | Televison & Video
How do I get the 4 digit code for Sony Blu Ray/DVD S1100 to get it to work off my Remote from Att
quite possible you can't as the remote is specific to uverse box not a universal device
May 11, 2015 | Sony Televison & Video
How do I program an AT&T u-verse remote to an ONKYO RC-866M remote
The RC-866M is the remote. What you need to do is add the codes for your Onkyo receiver into the ATT remote. There are 4 or 5 different Uverse remotes, but most can be reprogrammed by pressing the 'Menu' and 'OK' button together. First add your Onkyo codes to the ATT remote as an 'aux' device. After that is working, you can control the power and volume by adding the 'aux' device (Onkyo) to the power and volume buttons on the uverse remote.
These are all the different Onkyo Receiver codes:
Onkyo: 5002, 5018, 5073, 5074, 5075, 5076, 5077, 5078, 5079, 5080, 5081, 5082, 5084, 5085, 5086, 5087, 5130, 5131, 5140
This is how to reprogram the S10 style of Uverse remote:
http://www.att.com/support_media/images/pdf/uverse/standard_black_remote_control_uverse.pdf
Dec 22, 2014 | Onkyo Audio Players & Recorders
PROGRAM MY UVERSE REMOTE TO TCL TV
0174,0179,0173,1070. Try these codes. If you wish to get more, try the following links. Both the sites linked have set-up code list & set-up procedure to many popular brand remote controls.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Jan 21, 2014 | Televison & Video
I have tried to program a At&t U-verse remote to my Apex LD3249. Have tried all codes from At&t U-verse list. None work.
On uverse i got my apex to program by doing the search of codes. There is a code you can enter then hit a button to sequence through all codes by hitting power i believe. when tv turns off you know you have the right one. I am having the same issue on directv now since it does not have this option.
Jan 18, 2011 | Apex Digital LD3249 LCD TV
Trying to program my At&t Uverse remote to my
Sherwood Receiver/Amplifier 5027 Sherwood Receiver/Amplifier 5027
always press the mode key of the device they want to control before pressing any other key
Power on the device
  1. Press and hold the appropriate Mode key (TV, DVD or AUX) on the remote control.
  2. Without releasing the chosen Mode key, press and hold the OK key simultaneously.
  3. Release both the Mode key and the OK key at the same time.
    All the Mode keys should flash twice.
    1. Enter the four digit setup code by pressing the number keys (0-9) on the remote control.
    2. The Mode key will flash three times indicating correct entry and return to normal operation.
    • When an invalid code is entered, the selected Mode key will give a long flash to indicate that the Member has not entered the setup code correctly. Start over beginning at step 3.
    • Should the remote control time out before the Member completes the code setup, they will need to start over.
    1. Point the remote control at the programmed device and press the Power key once.
    2. The device should turn off.
    • If it does not turn off, repeat steps 2 through 6 trying each code for the brand until the correct code is found.
    1. Repeat steps 1 through 7 to program other devices if needed.
    2. Press the appropriate Mode key on the remote control to work with the selected device. To use the remote control for the Member's U-verse TV Receiver again, have them press the AT&T Mode key.
    Sep 05, 2009 | Sherwood RX-4109
    Att uverse remote won't work with other devices
    Yes you have to use the recommended Uverse codes, and follow the directions to enter the code. Hold the tv button down, on the Uverse remote, then with it stil held down add the OK button, let go of both, then you will see the lights at the top of Uverse remote light up, it is then ready to accept the code, it will be a four digit code, Go to helpme@att.net, and look under TV, then programming the remote is there. Put remote Code in the att search box if you can't find it.
    Apr 04, 2009 | Televison & Video
    Philips Magnavox MWD7006 DVD Player Logo
    1,956 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
