Question about Palm Treo 750 Smartphone
My phone palm 750 froze so i took the battery out and put it back in now my contacts are all erased and i cannot get to my "phone" screen as in like the main screen but i can do everything else.
    Problem Solver:
  • 9 Answers
Go get it checked as soon as possible now u will not realise the problem but after a month or two set will go dead move to a nearby shop and get the set checked he will put a new ic .it will cost u around rs400
Posted on Sep 08, 2009
Just bout a palm pre from a friend and I'm tryin to hard reset it cause I dont have the pin. How do u hard reset the palm Pre?
1. Remove the battery cover.
2. Remove the battery and put it back in while holding the "Power" button. Keep the button depressed.
3. Release the button when you see the "Palm Powered" screen.
4. Press the "Up" button to confirm the "Erase all data" action.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 14, 2011 | Palm Pre Cell Phone
My phone had froze. So i took the battery out and put it back in and it didnt turn back on!
first kwwp ur phone's back cover open and wrap it up in a cushions for 48hrs.
then touch every part of ur battery to the sides of a steel glass having too hot water in it nd then wrap dat battery also into another cushion fast nd keep for 48hrs
then take out, wipe it properly nd then plug nd see.............
Feb 28, 2011 | Palm Treo 500 Centro
My palm treo 700wx froze on the white screen that says TREO. i dont have an SD card in it. i tried doing resets but the same thing happens again. what do i do?
You tried taking out the battery completely? There is a reset button next to the battery, try holding the button in for 10 to 20 seconds.
Feb 28, 2011 | Palm Treo 700wx Smartphone
My screen is frozen
Hello tara_martell,
Have you tried doing a soft reset? All your information is retained when performing a soft reset. These soft reset instructions are from the Centro Tips, Hints and Shortcuts manual:
1: Press Power/End (Red Button) to turn off the screen
2: Slide the battery door downward (on back of the Centro) to remove it from the Centro
3: Remove the battery from the battery compartment
4: Align the metal contacts on the battery with the contacts inside the battery compartment, insert the battery, and then press it into place
5: Slide the battery door onto the back of the Centro until it slides into place
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Jul 07, 2010 | Palm AT&T C/PHONE PALM CENTRO S64801
My palm treo 750 is freezing up or going really slow when I try to use it. When I go into my messages to txt someone it wont go to the message screen or if it does then the key board wont work for me to...
You can do a reset but you will loose all you info in it.
Take the battery out and before you put it back in press and hold up on the arrow pad. put the battery back in and power up the phone while holding up. When the status bar is complete let go of the up and follow the steps on the screen.
Feb 27, 2010 | Palm Treo 750 Smartphone
My phone froze so i took out the battery and put
I know this is a little obvious but it sounds like the battery is not charged or will not hold a charge. Charge or replace the battery. Your cellular store might let you try out another battery just to test things out.
Another possibility is that the phone is damaged from getting wet or dropped. If this is the case you must let it fully dry out or have it repaired.
Finally, it may just need a hard reset. This will reset the phone to its original settings and will erase any data that you have stored on it.
Instructions are available at Palm support. Start here:
http://kb.palm.com/wps/portal/kb/na/deviceselector/page_en.html#NA
I hope this helps.
Jul 20, 2009 | Palm Treo 750 Smartphone
PALm CeNTro
The last thing you need to do is doing a hardreset.
This will erase all the data in your phone but usually fix the problem.
If the problem persist, bring your phone to the nearest store to fix it.
Oct 17, 2008 | Palm Treo 500 Centro
Palm 755P Freezes
Well, thank God I had done a recent Hot sync! I found out how to do a hard reset by holding down the power button while reinserting the battery then letting the button go and the system will ask if you want to erase all data? I put yes! Then it erases all my data and restarts the phone. I had to plug the phone in to be recharged because the looping ultimately drains the battery. Then, I plugged in the Hot sync cable and pushed the button to start the sync and ta da! back to its working state! Yippee! Do it! It's easy! Just make sure to hot sync often so your info stays current!
Aug 26, 2008 | Palm Treo 755p Smartphone
Everything is gone
just put the battery back in and once it connects and you have the G up in the top right corner, everything will load back onto your phone. that happened to me today and i was so mad, but everything came back.
Feb 06, 2008 | T-Mobile Sidekick ID Cellular Phone
Palm Treo 750 Smartphone Logo
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
