Question about Bunn VPR Coffee Maker
Bunn omatic won't make full pot-even with water line hooked up
We have the water line hooked in but when we hit the button it will not make a full pot of coffe- i found the adjust ments but not sure what to set it on
  • Ernest R
    Ernest R May 11, 2010
    Have you tried to run the deliming spring through the brew tube, or have you tried to adjust the brew level?
    President:
  • 635 Answers
Use the dial with numbers on it and adjust to a higher number. Remember to go in half steps such as 2 adjusted to 2 1/2, 3 adjust to 3 1/2 etc.
If you only have a High Low knob, that is to set your water temp.
If you have an electronic circuit board, you will need to follow the batch instructions pasted on the inside cover (facing the lower burner) to adjust for water level/batch. This cover has 4 screws.
Posted on Mar 11, 2010
How do you get a bunn pour omatic coffe maker to pour water into the hopper. I put water where it's supose to go it heats up but no water come out. Is there something I'm not doing. Its an older one.
did you pour in another pot of water? It heats up the reserve tank so you always have hot water instantly, but to get that water you need to pour in another pot of water to replace it.
Manual:
www.bunn.com/sites/default/...manuals/10424.0000.pdf
May 12, 2016 | Bunn Coffee Makers & Espresso Machines
Just hooked up a used bunn omatic the water will not stop running
One of 2 things. The water refill valve or high water probe is bad
Sep 15, 2014 | Bunn 10 Cup Home Coffee Brewer
My pour-omatic steams up overnight then will not brew full pot
Check the thermostat on the machine, make sure pot is full before brewing. The water in the tank just heats up it is loosing most of it, make sure lid is on pour in screen.
Feb 18, 2011 | Bunn Pour-O-Matic VPR
My bunn omatic coffee maker is putting out too much water. about 1 and 1/2 pots worth... the model number is OT20
More than likely could be a bad timer.Check the time of the brew cycle is consistant each time.See if the sprayhead is in place.You may also try rodding out the brew tube with a de-liming spring p.n. 1111.0000.
Jan 05, 2011 | Bunn OT20 Coffee Maker
It only makes 1/2 pot when I pour the water in after sitting over night some times it takes 2 pot of water or more to make a full pot
I recommend slowly pouring in about a half a pot of cold water without coffee in the filter basket 5 or so minutes before you brew in the morning. There are 2 good reasons to do this-
1. Overnight you are having some evaporation due to the fact that your Bunn brewer has a reservoir that keeps a couple of pots worth of water at brewing temperature... a better temp than most "home" model brewers. This will top off the reservoir and you will not "short pot" except for the amount that the grounds themselves hold back.
2. Also overnight, due to the fact that the water is kept hot, the oxygen can dissipate from the water in the tank. Topping off with fresh water will mean a fresher first pot.
The Bunn brewers have a low wattage/keep warm heater so the actual heating element isn't doing all of the work over those long periods... it only kicks on when the temperature in the reservoir drops considerably (like after brewing). Be sure to let the brewer heat back up before brewing (you will hear it stop heating)
Hope this helps.
Oct 28, 2010 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
I have a Bunn VPR, it brews fine for a couple pots
Try running a quarter-pot 50/50 solution of white vinegar and cold water through to clean out calcium deposits in the pump system. Use a clean filter to catch the pumped debris. When pumped through, let cool somewhat, and reuse the cold mixture again twice more. Pour out the vinegar solution and run several cold water loads through to wash out the taste. Hope this helps!
May 24, 2010 | Bunn VPR Coffee Maker
Inconsistent water amount being dispensed
It sounds like there is some build up in the brew line, find the nearest bunn dealer and get a delimming spring, then remove the shower and run spring through brew line.
Apr 26, 2009 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
Bunn Coffee machine only makes 1/2 pot
What's happening is that it isn't leaking, it's boiling over. You need to turn down the thermostat under the top lid. Also, before you brew coffee, add water to the tank and let it pour into an empty pot. Once it stops brewing, let it heat up for a few minutes then make your pot of coffee.
Jan 02, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn omatic model F20 doesn't stop dripping
Check out:
http://whles.com/General%20Mtx%20Knowledge%20%20Tony%20Roach/BunnOMatic%20F35%20F20%20F15%20x.pdf
This is the free full service manual F15, F20 & F35 complete with troubleshooting section at the rear. This section has easy, plain english steps to follow to solve this very problem (others, too).
Oct 02, 2008 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
BUNN Pour-Omatic
Most likely it is your tank heater, but look on the top of the tank heater, because sometimes the wire will burn off the top of the element
May 20, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn VPR Coffee Maker Logo
277 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
evans_lloyd
Level 1 Expert
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
