Question about E-Machines emachines (emachinees) CD-ROM Drive
ATAPI DVD A DH16A1P ATA DEVICE stopped working
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
    Novelist:
  • 142 Answers
  1. Click Start and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK.
  4. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  5. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  6. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
  7. On the Edit menu, click Delete.
  8. When you are prompted to confirm the deletion, click Yes.
  9. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  10. On the Edit menu, click Delete.
  11. When you are prompted to confirm the deletion, click Yes.
  12. Exit Registry Editor.
  13. Restart the computer
Posted on Sep 11, 2009
2 Suggested Answers
tbirdfan1
  • 3051 Answers
SOURCE: Windows cannot start this hardware device because
Hello there:
First i would double check to make sure that the device is windows vista compatable and is compatable for your system next i would uninstall the device using device manager and than select view and select scan for hardware changes and let the computer reinstall the device and it will let you know that your device has been found and is installing than it will let you know that your device is installed and is ready to be used or it wil give you a error message if so than i would contact the manufacturer of the device and see what they say about the message ok?
best regards michael
Posted on Sep 10, 2009
My cd driver isnt working and device manager says: Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19) have an hp probook...
Most cd/dvd's don;t use a driver they rely on a atapi common driver. Usually when you get problems it means the drive itself is the issue. For now what I would try is simply to go under /control panel hardware manager and delete the drive then reboot. Windows will detect the drive and should re-install the device information and correct the registry.
Sep 12, 2011 | HEWLETT-PACKARD ProBook 4520s
ATAPI DVD A DH16A1P ATA Device has error 10. Due to this error, I computer does not read any discs. I tried to uninstall it and reinstall, but that did not work. What can I do to fix this?
Your problem is very common,the only reason found is that,your cd or dvd drive is corrupted, You will have to install new windows.
THANK YOU
Oct 02, 2009 | Computers & Internet
How do i repair ''Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19).'' It's my cd drive ATAPI DVD A DH16A6L-C ATA...
Fixing the problem simply involves deleting the filter entries for the third-party device drivers. These entries can sometimes become damaged (which is what produces the "corrupt registry" warning).To delete the offending keys, open the Registry and navigate to HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlCl ***\{4D36E965-E325-11CE-BFC1-08002BE10318}. . Delete the keys named UpperFilters and LowerFilters and reboot.
Several of the products made by Roxio are infamous for causing this problem, although in fairness to the company the most recent versions of their Roxio CD/DVD writing software (6.2 and higher) do not have these problems. Users of 5.0 or 6.0 editions of the Easy CD & DVD Creator product, which has been bundled with many new PCs in the past, should upgrade to 6.2 or better. Other programs can also cause this problem, with the same solution.
Note that after you do this, you may lose functionality in the program that uses the filter drivers, which may need to be reinstalled.
Sep 20, 2009 | Computers & Internet
My cd/dvd drive is not working any more, when i place a cd in, nothing happens it reads for a moment than stops. I checked the settings on the computer and it says that for TSSTcorp CDDVD TS-L633L...
no need to download from other site coz driver for cd is available on all operating system. try to un stall the driver then reboot your pc and it will automatically detect your cd/dvd/
Sep 16, 2009 | HP Compaq Presario M2000 Notebook
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19) For emachines windows vista atapi dvd a dh16a1p ata device stop...
Hello there:
Sep 08, 2009 | E-Machines emachines (emachinees) CD-ROM...
Atapi dvd dh16a1p ata
If this is original equipment inside your pc then go to the website of who made your pc and check the spec's. If the burner does not say
dvd-rw, DL, then no it is not capable of burning a double layer dvd disk.
Apr 08, 2009 | Gateway (5500778) Internal 32x CD-ROM...
Download driver software for PIONEER DVD-RW DVR-K17LF ATA Device
it's look like you have problem with dvd isnot showing in windows explorer / dvd driver.
Try this step from microsoft http://support.microsoft.com/KB/314060
basicly just update (delete some key) the windows registry and restart. ussually this work ok.
Jul 31, 2008 | Toshiba Satellite P105-S9722 Notebook
Computers & Internet Logo
1,924 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
