Question about Samsung SGH-d807 Cellular Phone
Need help I can not connect the bluetooth
  • Anonymous Dec 17, 2007
    Every time I trie to conect B/Tooth to PC it sez that BT server is not working what can I do
  • 3 Answers
Connect the PC to the phone not the phone to the PC
Posted on Feb 05, 2008
How to connect bluetooth headset to my nokia c5-03 phone
Hi Madhav,
Thank you for your question at Fixya,
The solution to your problem is as follows :-
  • The blue tooth connection depends on the fact as to whether or not the bluetooth handsfree that you have is compatible with your phone or not , a good idea would be to check it before you buy one.
  • Now if you want to connect your bluetooth handsfree to your mobile , you need to first make sure that your phone's bluetooth connection has been switch on and then it's not hidden and it should be in shown to all mode as this is a nokia phone.
  • When you switch on the bluetooth connection in your phone , then you need to switch on your bluetooth handsfree and then keep it on.
  • Then again you need to go back in the bluetooth option and then select search for paired devices option or new paired device option , then the phone will search for available bluetooth connections.
  • If it detects your bluetooth , please accept that connection and then it will ask you for a pass code , which you have to enter as 0000 and then press ok.
  • That's it! you will have your phone successfully connected to your bluetooth handsfree.
Hope that helps ...:) In case you have any queries, feel free to contact me.
Sep 19, 2011 | Motorola Mobility Bluetooth Headset, Mini...
I.Tech BlueBand Bluetooth Stereo Headphones whate is the pin code
Hi, In some states, hands free driving is the law. In order to avoid a ticket you need to talk on your cell phone with a bluetooth headset or speaker or with a headset that attaches directly into the phone. Bluetooth headsets are popular for this and other reasons but connecting it to your phone can be confusing. Here are some steps to help you connect your bluetooth device to your cell phone.
Instructions
Things You'll Need:
* Bluetooth headset
* Bluetooth capable cell phone
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Hope it helped.
And please don't forget to rate me...
Thanks and have a nice day...
Feb 21, 2011 | Itech Blue Pro Bluetooth Stereo Headphones...
How do i disable bluetooth on my SGH A561 samsung flip phone
To disableset Bluetooth on your phone
1. Go to Menu, select Connect or Connections or Connectivity:
Note! If the above steps do not work, please consult the user manual.
2. Bluetooth - Select On to disable Bluetooth.
3. My telephone's visibility - Select Shown to all if you want your device to be found by other Bluetooth devices. If you select Hidden, your device cannot be found by other devices.
4. My Bluetooth name - Define a name for your device. After you have activated your Bluetooth service and changed My phone's visibility to Shown to all, your phone and this name can be seen by other Bluetooth device users.
Hope that helps..
Thanks for using fixya.....
Jan 08, 2011 | Cell Phones
Bluetooth has lost connection with phone and I can't get it back
You should delete the headset from the "paired devices" list on the phone and completely redo the pairing process, it sounds like the two have gotten into some kind of wierd state.
If you need help with this please include the make and model of your phone.
Feb 09, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Could not found the bluetooth connection or device
Make sure you have every driver for your laptop loaded. Then let's suppose you want to connect your phone to the laptop bluetooth: Turn on the bluetooth in your mobile and make it visible to the other bluetooth device then only your handphone will detect the other bluetooth device and viceversa. Most of the recent notebooks are having bluetooth enabled but in some notebooks we need to turn on the bluetooth by using the buttons which indicated as bluetooth. Once you turn on then get into your computer running windows vista type this following command in the search box or in the run box "ncpa.cpl" it will take you to the network connection window [you can even use control panel option to reach the network options]. In that window where you find the bluetooth connection.Click the icon first and look it on the top of the window where you can see an option "Connect the the bluetooth"click it then you need to add the bluetooth device click add. It will find your hand phone then it will ask the passpharse key you can create one and then your handphone alert you to type the same key that u given in the notebook.Once it matched it will connect automatically. Later type bluetooth in the search option where you will get an option as Bluetooth(Transfer files wizard) . Click it then you receive or send the file via bluetooth between your notebook and handphone. Hope it helped.
Aug 05, 2009 | Lenovo 3000 N100 Notebook
Bluetooth installation
you need to disable your laptop.
The blue tooth connection is close to headphone jack, but you need to open the uppercase to connect your blue tooth.
Basicly you need the bluetooth and bluetooth cable.
Once you open the uppercase, you can see the internal microphone connection. the bluetooth connection is on the other side (motherboard).
Apr 22, 2008 | Acer Aspire 5610 Notebook
I can't get my phone to connect with other peoples
I assume you are trying to connect to another phone via Bluetooth. It would help quite a bit to know what kind of phone you are trying to connect to, but here is what you need to have configured on your phone for Bluetooth file transfers:
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life.
2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer, not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
4. You can now "Copy" media files to the phones nearby that you have connected to. Copy is an option while browsing through the files.
Dec 14, 2007 | Motorola Mobility RAZR V3
Can't connect with other peoples phone
Pairing a Jabra 250 headset with my new motorazr2
Here is what you need to have configured on your phone for Bluetooth connections:
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer (in the manual), not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
Samsung SGH-d807 Cellular Phone Logo
26 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
