Question about Husqvarna Viking 1
Husqvarna 4320 sewing machine
Where can I get bobbins for an old Husqvarna 4320 sewing machine please?
  • Husqvarna Master
  • 1,388 Answers
Certainly from a VSM Husqvarna dealer, many good sewing repair shops will have a range of bobbins to suit most makes/models Google VSM Husqvarna and find the store locator page for your country or region to locate the nearest one...........or look in the phonebook for service centres.
Posted on Sep 10, 2009
My Husqvarna designer SE is not telling me bobbin is empty
Hello, Dene -
Go to this Husqvarna Viking Desinger SE Troubleshooting website:
http://www.husqvarnaviking.com/SiteMedia/Products/Machines/Support/Designer_SE_Troubleshooting_EN.pdf
Scroll down Page 1 to the section with the heading "Bobbin Alarm Does Not Work? Follow the instructions there.
If those steps do not get your bobbin sensor back in working order, I suspect you will need to have the bobbin sensor repaired by an authorized Husqvarna Viking sewing machine repair service.
I suggest you contact the Husqvarna Viking sewing machine dealer nearest you and ask about authorized repair businesses.
You can also contact Husqvarna Viking directly:
Toll free 1.800.446.2333
Monday - Friday: 8:00 am - 4:00 pm CST
info@husqvarnaviking.com
Jan 02, 2018 | Husqvarna Sewing Machines
What size bobbin goes in the Husqvarna Oscar 130 sewing machine?
It must fit snugly but easily spin. Also, when it sets inside the bobbin case it must be under the outside rim. The best thing to do is remove the bobbin case and take it with you where you purchase your sewing tools and compare it with the new bobbin and ask for assistance if you need.
Mar 07, 2017 | Husqvarna Sewing Machines
Can i use a metal bobbin with husqvarna 1100?
What is important is that the bobbin is compatible with your machine. Not all bobbins will work even though they may fit into the machine. Using the correct bobbin is very important for a successful sewing experience. For the few dollars it will cost, purchase the right bobbin for your machine.
http://www.sewingpartsonline.com/husqvarna-viking-1100-sewing-machine-parts.aspx
Husqvarna Viking Concave Bobbins for 1 1100 1090
Nov 30, 2016 | Sewing Machines
Husqvarna viking sewing machine bobbin
Could the part number be 4011770? I've found the Viking 7 bobbins here: http://www.mysewingmachineparts.com/top-quality-metal-sewing-machine-bobbins-4011770-husqvarna-viking/ . Another site with them is http://www.sewingpartsonline.com/bobbin-viking-4011770.aspx . This bobbin is compatible with the Husqvarna Viking 7, 49, 51, 52, 21 & 21E . It probably will work for other machines. Sears also has them listed as 11770: http://www.sears.com/generic-viking-sewing-machine-bobbins-sewing-machine/p-SPM6124767105?prdNo=1&blockNo=1&blockType=G1 .
I also found these bobbins: http://www.amazon.com/Viking-Metal-Bobbins-5-pkg/dp/B000YZ5QSC . The part number appears to be 1702.
I hope this helps.
(googling Husqvarna Viking metal bobbins found a number of hits.)
Mar 05, 2013 | Husqvarna Viking 1
Hi, I own a Husqvarna Prisma 940. It has always
I will help you,
Pls give the Model number of your sewing machine.
Jan 09, 2011 | Husqvarna Huskystar 207 Sewing Machine
Thread bunching up around bobbin
If you do not have a user guide, you might want to find one. Try ebay or have an authorized Husqvarna Viking dealer order you one. In fact I would find your nearest authorized Husqvarnia Viking dealer and visit them with you machine. They should be able to help you and usually are very helpful even if you didn't buy the machine from them. If they determine it is correctly threaded and the bobbin is ok, have it serviced by an authorized Husqvarna Viking dealer or have them send it to Husqvarna Viking (SVP) Technical Service Dept in Tennessee for service. The machine should give you years of good performance.
Use only genuine Husqvarna Viking bobbins.
To find an authorized dealer near you, check the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Sep 26, 2009 | Husqvarna Sewing Machines
My 5 year old Huskystar 216 sewing machine is
Sounds like the hook/needle timing. To check do the following:
With the power off!!
remove bobbin and bobbin case.
push needle all the way to the left.
Turn handwheel toward you watching the needle and bobbin housing hook. The point of the hook should line up right above the eye of the needle.
If not timing, clean bobbin area removing lint and thread.
Check bobbin tension, should get slight resistance when pulling thread.
Make sure using only Husqvarna Viking bobbins -- most are green but they have new colors now. All will have the Husqvarna logo on them (an H). Make sure the bobbin is unwinding in the right direction.
Remove fabric. Pull extra long bobbin thread (about 3 inches). Hold upper thread tail in left hand, turn handwheel toward you for 1 revolution. Is the bobbin thread caught by the top thread and pulled through the opening of the needle plate?
If you are still unable to get a good stitch, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Missing bobbin case and bobbins Husqvarna 4000-serie sewing machine
ask where Husquvana machines are sold. google dealers if you don't know.
Oct 24, 2008 | Husqvarna Sewing Machines
Sewing Machines Logo
323 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
