Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
Stopped working, lights work, shows full light when not full.
  • 430 Answers
Remove the bag and put in a fresh bag. Then rotate the dial on top of the vac to the middle position. When cleaning fine dust the vac will shut off before the bag is full as it is sensing a clogged bag and cannot sense proper air flow through the bag. If this persists the sensor under teh top dial may be damaged and need to be replaced
Posted on Sep 08, 2009
My vacuum is an Electrolux model el 20 the power head stopped working and has a flashing red light on it now
No Owner's manual? Try manualslib.com
But wild guess is the filter bag or possibly the secondary filter is
full. Sometimes. the effect of the full bag will pop open the latch for the filter bag and as a result, will automatically stop. Otherwise, it may be that the motor has overheated as a result of the full filters and stopped due to the overheating.
Mar 26, 2015 | Electrolux Vacuums
Lights on front of unit stopped working and a little while later the whole unit stopped working while in the middle of vacuuming
Take it to a qualified repair facility. Even as there isnt to much to a vacum let the tech check it out. Could be a faulty switch or controls. I dont think its a serviceable by homeowner problem.
Dec 20, 2013 | Kenmore Vacuums
Oil filled radiator stopped working
What does this have to do with a vacuum cleaner?
Sep 17, 2013 | Electrolux Vacuums
Red when bag is not full
The red light will also come on when there is a blockage in the pipes leading to the bag compartment. To test that the light is working correctly, you can unplug the flexible hose from the top of the bag compartment then switch the machine on. The red light should be off, but will come on if you block the hole with your hand. If that test shows the light is working, you need to search for a blockage - which is most likely to be in the flexible hose, but can be in the rigid plastic tube or in the base of the machine (turn it over and look in the little trap-door). Clearing a blockage from the hose can be difficult - you are more likely to be successful if you can devise a way to pull it out rather than trying to push it (as with a broom handle, for example), because pushing may just compact it. Good luck!
Apr 03, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
What is the symbol above the "change bag" symbol?
When the bag is full, the "full bag" light will come on and will turn itself off. Replace bag (make sure there is no clog) and try again.
Hope this helps.
Aug 17, 2009 | Electrolux Epic 6500 Vacuum
Roomba Schedular
Let it charge for a full 24, or even 48 hours, regardless of the green light. If it still dies you probably need a new battery.. or worse.
Aug 31, 2008 | Roomba Robotic Floor Bagless Vacuum
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
272 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
