Question about Tappan TEF242 Electric Kitchen Range
Bake element t
The bake element does not heat up some foil fell on it ,is it aburnt element or eoc problem
  • 205 Answers
I'm just guessing here...
Heating elements are high resistance. If the foil fell on the element near where it inserts into its socket it could have short circuited the element. If there's a fuse in the heating element wiring it could have blown. I could not find an electrical diagram for this stove so I don't know if it has a fuse or not.
Also, depending on the wiring your thermostat or selector switch may have been damaged. Does the broiler still work?
Let us know what you find.
Posted on Dec 09, 2007
Is my problem with the EOC or my bake element?
It does sound like the EOC is bad. Burned connectors are a good indication.
Nov 06, 2014 | Ovens
My bake element snapped on my Frigidaire while baking and and tripped my fuse. I replaced the element and my eoc still did not have power. I assumed it was fried during the element incident so I replaced...
The oven thermostat controls when the power is applied to the element. When there is a catastrophic element failure you may have fried the contacts in the thermostat as well. Look to see if the thermostat is working properly.
May 28, 2014 | Kitchen Ranges
Bottom oven bottom element doesn't heat
Phil. If you do not have voltage at the element, then the Electronic Oven Control ( EOC ) has failed. Part number # 5701M403-60
In order to check for the correct voltage at the element you will need to remove power and pull the range out of its installed location and remove the back panel of the range to gain access to the wiring and element. CAUTION ! I cannot stress this enough ! There are dangerous voltages in this area!! After the panel has been removed, return power to the range,set the lower oven to bake, and check the voltage at the element. You should find 220-240 volts between the element terminals with them connected to the element. If you do not have the proper voltage then you will need to replaced the EOC.
Apr 18, 2014 | Maytag MER6772 Gemini Electric Kitchen...
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Oven wont heat
Hello, It could be that the EOC is bad but have you checked both sides of the breaker? as you may already know the 220v is on 2 breakers, although you may see the clock still working you still have 120v to the control side, the 120v breaker for the heater side of the cuircuit could have popped...If after checking the breaker you have a full 220 then I would have to say it's going to be a problem with your EOC or high limit if this model has one. Mike
Sep 03, 2009 | Lang Manufacturing EHS-APM Electric Oven
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Changeing both bake and broil elements
I would recommend you check BOTH elements for proper resistance prior to replacing them. If both of them are not working, the problem may actually be with the Electronic Oven Control (EOC) board. This is your clock assembly. On electric ranges, the EOC controls all the oven features. Check the resistance of the heating elements by performing the following:
- Perform a resistance check from terminal end to terminal end (where the wires connect to). You should get a high resistance reading in the Kohms range (this varies between models). If the reading is infinite, you have an open heating element. (Must be replaced).
- Second, perform a resistance reading from one terminal end to the outer shell of the heating element. You should get an infinite reading. If this reading is a low resistance or short, the element is shorted. (Must be relplaced).
NOTE: Take these readings with the wires disconnected.
You may be right, but please take the time to check both elements and let me know what you find. You may have started off with a bad element, but it could have damaged the EOC as well. I have seen this happen before. The result is an oven that still doesn't work after the homeowner replaces the defective element.
The following link explains how to replace a heating element:
http://www.fixya.com/support/r469407-replacing_bake_or_broil_element_in
I hope this information is helpful to you.
Nov 13, 2008 | Whirlpool RF364 Electric Kitchen Range
Bake element blew 2 weeks ago got new part...and still won't heat up
Depending on how the element blew, in some cases it will also ruin the Electronic Oven Control (EOC) board. This is your clock assembly. The EOC controls all the oven functions on electric ranges. There are separate relay controlled circuits on the board that control the BAKE and BROIL functions. The EOC will still display the time and the broiler may still work, but the bake feature will not. My bet, it the relay for the bake element, or a component in the bake circuit is blown. There should be a schematic diagram located inside the operator console, or on the back of the range for assistance in troubleshooting. I would recommend you inspect the EOC for any burned components or wires.
Now...there is a remote possibility you've purchased a bad element (it does happen). A resistance check from terminal to terminal should yield a high resistance in the K ohms range. Next, check the resistance between one terminal and the outer shield of the element. You should get an infinite reading. Anything else, you probably have an element that is shorted.
I hope this information is helpful to you in some way. If you have questions please let me know.
Nov 11, 2008 | Frigidaire Kitchen Ranges
Heating coil
The oven features on electric ranges are controlled by the Electronic Oven Control (EOC) board. Commonly referred to as the clock assembly. Each function (bake or broil) is usually controlled by a separate circuit. If you have installed the new element, and can rule out the possibility that you may have received a defective part, the EOC may be a likely culprit. Before you go tearing the console apart, however, double check your wiring on the element you just replaced and take a resistance check of the element. Measure on the element terminals with the wires removed. The reading should be in the K ohm range (resistance will vary between manufacturers). Then measure from one of the element terminal to the outer shell of the element. If it reads a short (0 ohms) you have a grounding problem and probably have a bad element. If you are confused by any of this, please post back with any questions you may have. I hope this helps you.
PS There should be a tech sheet inside the operator console to assist with troubleshooting.
Aug 01, 2008 | Frigidaire Gallery GLEFM397DS Electric...
I have a Kenmore Stove and the bottom (bake) element does not heat up. The top Element is fine. I have replaced the bottom element and checked the fuses and they seem fine. Could it be a control panel that...
You could very well have an Electronic Oven Control (EOC) board problem. There two separate circuits that control the oven BAKE and BROIL functions. If you have replaced the BAKE element, and have ensured it connected properly, the only other component that controls that function, is the EOC. If you post back with your complete model number, I can double check to make sure. The model number will be located on a nameplate somewhere around the oven door opening or lower drawer opening. The reason I need to confirm is because some ranges have a separate relay control board.
May 28, 2008 | Kenmore Kitchen Ranges
Tappan TEF242 Electric Kitchen Range Logo
190 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Sal De
Craig Butler
Craig Butler
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
