Question about RCA HD52W59 HDTV Projection Television
I Go through the channel setup. Turn of the TV and it doesn't store the setup information
    Problem Solver:
  • 6 Answers
You mean channel set up or you had personalised the tv set up? if you channel set up only you forget to stored what you had made
Posted on Sep 08, 2009
How to tune channel when channels are locked?
The Sony KV-36HS510 has an Auto Setup function for the channels.
1 Press POWER to turn on the TV.
2 Press TV FUNCTION on the remote control.
3 To continue running Auto Setup, press CH+. To exit Auto Setup,
press CH-.
Auto Setup automatically creates a list of receivable channels. When
finished, the lowest numbered channel is displayed.
To reset the TV to factory settings
2 Hold down RESET on the remote control.
3 Press TV POWER on the TV. (The TV will turn itself off, then back
on.)
4 Release RESET.
Apr 14, 2016 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Philips tv stuck on Setup screen
allow the tv to go through the scan make sure there's an aerial pluged in or a vcr playing a tape if you can do that. In most cases when you get this on a TV it needs to find at least 1 channel on analogue or digital and store it in. also make sure there are no buttons jammed on.
Feb 01, 2014 | Televison & Video
Sinotec LCD TV doesn't store channels anymore? It
The main system control memory IC to your TV is faulty. It should be replaced. It is a very small IC, having only 8 solder terminals, and can be located very near to the main system control IC. It will look some what like this, and will begin with a numner 24c**
May 26, 2013 | Televison & Video
I'm using a Time Warner remote as a universal for my TV but when I go to change channels, it just lights up the CBL button and doesn't change the channel. Can I program it to my TV or will it
Hi, you need to de-activate the "programming channel control lock" option. You can see instructions in the manual for the remote. They are as follows:
  1. On the remote control, press CBL once; It will blink once, Press and hold SETUP until the CBL key blinks twice.
  2. Enter 9 7 3. The CBL key will blink twice.
  3. Press CH- once. The CBL key will blink four times.
    Now the remote control will provide TV and VCR channel-control capabilities while in the TV mode.
for any other information with programming this remote:
Download the 1056B01 operating manual with codes for free.
Nov 30, 2012 | Televison & Video
Why does our TV go through the channell setup everytime we turn it on?
Are you turning "OFF" the TV with a power strip ? or a switched wall outlet..
Check your power source..
Jul 15, 2017 | Sanyo 52" Class LCD 1080p 120Hz HDTV,...
When we turn on the TV the channels wont go past 13 not sure why. the other tvs in our house goes up to channels 65 Lost the manual
If the tv was setup with auto tune it will only store the amount of channels(signals) that it can pickup
so if the signal is worse on that outlet it will find and store less channels
May 13, 2011 | Hisense LCD1504 15 in. Television
We bought a samsung tv off display and the tv is on store mode and we do not have the remote to change it.
frist turn on tv
press the menu botton
press the channel donw botton to go to setup
on setup press the volume +
press the volume botton again
press the source botton to enter in the plug and play option
press source botton and select store or home by pressing the volume botton
and then press the source botton again
after this just turn ur tv off and than on
Nov 30, 2010 | Samsung TV Remote Control
We have not had this tv on since went over to digital freeview built in hopwever just put it on and there are no channels stored how do we get channels?
Hello
Your TV has to be initilized. It should be retuned to get the channels memorized in its memory section. Then only you can get the channels stored. Hopes that you have its remote control hanset with you. Replace two new cells in it and proceed the folloing steps. Connect ariel to its back socket before doing these.
[1] Press power button on the front panel of your tv. The initial setup screen appears.
[2] Press Ch+ on the remote control handset or on the front panel of your TV to start auto program, or Ch_ button to exit.
The initial setup screen will appear each time you switch on the tv until you perform autoprogram.
To perform autoprogram again
[1] Press Menu button.
[2] Press to highlight Channel Menu
[3] Press Pr Dn button to hilight cable. Press [+] to select.
[4] Press Prog Up or Prog Dn to hilight On or Off according to how you connected your TV. Press [+] to select.
[5] Press Prg Dn to hilight autoprogram. Press [+] to search for channels.
[6] After autoprogram finishes, press "Menu" again to exit.
TO RESET THE TV TO FACTORY SETTINGS
[1] Turn TV on.
[2] Press and keep hold the "Reset' button on the remote control hanset.
[3] Press and release the "Power button" on the TV front panel. The TV will turn itsef off.
[4] Release "Reset Button" now from your hanset.
These are the processes to be done to either autoprogram or turn it to factory settings. Ok.
Oct 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Dec 12, 2008 | Philips DVDR3380/05 DVD Recorder
GE 20GT320 TV
don't use auto programme.
use manual or semi auto.
you have to press the auto programme button a few times.
Jul 12, 2008 | GE 25GT270 TV
RCA HD52W59 HDTV Projection Television Logo
53 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
