Question about Verizon Communications Samsung FlipShot Cell Phone - Red
Camera Error When I start the camera or camcorder the splash screen shows the "Starting Camera" text and spinning circle, followed by an error screen that says "camera error"
    Sniper:
  • 75 Answers
Your camera is damaged.or your camera ic is damaged.take it to mobile repairing shop...
Dont forget to rate thnx
Posted on Sep 08, 2009
Head
hello,
showing error c:31 mean your camera have defective mechanic, which one contain error? well, to make sure your problem try to inserting cassette and see the mechanical work:
1. when tape is insert it, before reel try to raising the tape, head will spin first.
2. after head is spinning then the tape will load
if your problem is in no 1 the head drum doesnt spinning, try to check the flex cable the top section of the head.
if head drum is spinning its mean your capstan is broken, try to change with a new one
thanks
otto
Jul 17, 2013 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Video Camcorder Error Message
Per SONY; To service the C:31 code, Sony recommends you do the following: Turn off the camcorder. Remove the battery or disconnect the AC power adapter for 60 seconds. Insert the battery or reconnect the AC adapter. Turn on the camcorder. If the error message appears, service may be required.
Sep 15, 2007 | Sony Handycam CCD-TRV608 Camcorder
Micromax x510 - camera module not ready
I purchased Micromax Van Goh last month. Within few days of usage it is giving following error when I try to use camera or camcorder:Error ''Camera Module Not Ready''. Any solutions?
Jul 13, 2011 | Nokia N95 Cellular Phone
I can't get my Dash to start the camera. No error, no nothing, just the camera is not working. What should I be looking for to fix it? Video recorder is also not working.
Try holding down the camera button for a few seconds from the home screen, and then let go. There should be a spinning circle on the screen. Wait for that to disappear into the camera application (the circle will disappear, and then the camera app will load up.) Also, CHECK TO MAKE SURE THAT YOU HAVE ENOUGH MEMORY ON YOUR PHONE. I think you should have at least 10 MB of free (unused) program and storage memory. Try these things. Also, this phone can be sluggish, so I would suggest trying to wait a little longer for the camera to open up. Also, try taking the battery out of the phone for 3 sec (soft reset) and then putting it back in and starting the phone up. Then open the camera FIRST before you open any other programs. I WOULD ALSO HIGHLY RECOMMEND BUYING A MICRO SD STORAGE CARD FOR THIS PHONE, and storing all your programs, data, AS MANY ITEMS AS POSSIBLE on it so that when you have to HARD RESET YOUR PHONE, if ever, you won't lose as much information.
Feb 10, 2011 | T-Mobile Dash Smartphone
My camera view finder shows"Check
Good day,
The CHECK DIAG appears in the view finder when the camera's automatic self diagnostic function detects an abnormality.
From here you must first perform error checking on your camera by doing the following:
Press the menu dial.
This will perform the error check on the Digital Signal Processing(DSP) and the Memory Circuits.
When no error is detected OK will appear.
If an error is detected it will be displayed next to DSP or Memory on the screen. Diag Error will also appear.
If Diag Error appears contact your Sony dealer!
What this means is that the camera is doing a routine check or has detected an abnormality with the system.
I hope it is just performing a routine check and there is nothing wrong with your camera!
Best of luck and let me know if this was useful!
Kind regards
Dec 01, 2010 | Sony DSR-500 Mini DV Digital Camcorder
No picture displayed on record mode all the icons are on the screen but the screen is black
I HAVE FOUND THE ANSWER!
this is a strange method so bare with me (found the solution on another site)
turn on the camera and then hold it upside down then for want of a better word "tap" the camera near the lens (i tapped the mic in front of the flash) and hey presto your image will return!
dont ask me what this does as i have no clue, it might have the same error after you switch off the cam but just follow the same method and it will show images. or if your not happy giving your camera a slap then speak to JVC or any camera repair centre.
heres then link where i found this solution
www.avforums.com/forums/camcorders-video-editing/690055-jvc-ccd-lens-cap-error-claim-deadline-extended.html
Apr 01, 2009 | JVC GZ-MC500 Memory Card Camcorder
GZ-MC500
Sep 25, 2008 | JVC GZ-MC500 Memory Card Camcorder
FOCUS ERROR
I also had this problem. When starting the focus error alert came. Trying to move the focus button also triggered this. When I turned it off, the lens did not pull back.After being close to trowing it away, I used a little bit more force than before and turned the lens manually. I heard a click, and than it worked again. PS: Follow this tip on your own risk.....
Mar 11, 2008 | Fuji FinePix F410 Digital Camera
DCR TRV320
That is the "LOAD" error code.
However, to service the C:31 code, Sony recommends you do the following:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Oct 25, 2007 | Sony Handycam DCR-TRV320 Digital Camcorder
Verizon Communications Samsung FlipShot Cell Phone - Red Logo
519 people viewed this question
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
Bee Santiago
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
