Question about HP Office Equipment & Supplies
HP6500 wireless printer says ink cartridge is missing or damaged. Any one else having this problem?
    Novelist:
  • 93 Answers
Hi There !!
Thank you for choosing Fixya.com
First you should do is turn the printer completely off and unplug form wall outlet(This will reset the printer). Next take out all the ink cartrideges and make sure that all the metal contacts are clean from debris and check the contacts on the printer also((Clean with 91% isopropyl alcohol with a soft cloth)). Reinsert the cartridges and plug it back in and turn the printer back on.
Under the HP software, try to check each one there is a utility called Service my Printer & perform the servicing & it'll get resolved.
Hope this will help !
Posted on Sep 08, 2009
Hp6500 will not print - paper processes through but no print
Sounds like your Printer Driver has been corrupted. If so install another one. Also check to see whether the printer will print a TEST PAGE. If not, is there Ink in the cartridge? You'll be surprised! Good Luck. George
Mar 29, 2013 | CMS HPQ6400-500-M72 500GB 2.5 SATA Hd...
Ink cartridges Missing or damaged Officejet Pro 8500
Check with another working or new cartridge, if problem not resolved,fault with iss unit(ink supply station). check ISS cables, PCB..replace ISS unit
Jan 31, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
I have an ongoing problem with my HP Officejet 6500 wireless printer. Everytime I need to change the three color cartridges, I get the same error message: "The following ink cartridges appear to be...
This normally happens when the "window" on the ink cartridge is dirty. It may not even appear to be dirty, which is hard to tell, because it is a cloudy and dark gray color, but it still needs cleaning.
The manual (at least on 6500) says to clean the little "window" on the cartridge. For some reason this needs to be done even though it is new and you receive the message.
If cleaning with a normal cloth does not work, try cleaning it with some rubbing alcohol as well as this usually does the trick.
This has unfortunately been a common problem with the HP6500 printers.
May 05, 2011 | HP Officejet 6500 Wireless All-in-One...
Why the printer tells me that the cartriage is missing or damaged?
Hello, If the printer shows that the cartridge is missing and your cartridge is new, then you should pull out the cartridge and look for any inks or dirts on the back of the cartridges try cleaning it with some water and cotton or you can use an isopropryl alcohol to clean it, reinsert the cartridges and see if it fixes it,mostly the cartridge missing error happens due to dried inks or dirts on the back of the cartridges where it will connect with the printer. Hope this helps you
Apr 29, 2011 | HP Officejet 6500 Wireless All-in-One...
Catridge error refer to device documentation to troubleshoot
You can go to HP's site and find that you have a problem with one or more of your ink cartridges see:
http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf
It states: " Ink cartridge problem
Cause The indicated ink cartridge(s) are missing or are damaged.
Solution Replace the indicated ink cartridge(s) immediately so that you can resume printing.
If there are no ink cartridges missing from the HP All-in-One, the ink cartridge contacts might
need to be cleaned.
If there are no ink cartridges missing from the HP All-in-One, and you still receive this message
after cleaning the ink cartridge contacts, you might have a damaged ink cartridge. Contact HP
customer support." Go to:
www.hp.com/support
Basics Guide 29
Troubleshooting and support
Apr 01, 2011 | HP Photosmart C5180 All-In-One InkJet...
I changed all the ink cartridges and my printer says cartridge is missing or damaged. Went to the store and bought another ink cartridge but it still says the same thing?
Lift the top of the printer as if you are going to replace cartridges. When the print head comes into view you should see a grey lever on the right hand side. Lift it and reseat it. That worked for me!
Dec 09, 2010 | HP Officejet 6500 Wireless All-in-One...
Ink cartridge problem( s) appear to be missing or damaged
hi there,
Ink cartridge Problem
Cause : The indicated ink cartridge(s) are missing or are damaged.
Solution : Replace the indicated ink cartridge(s) immediately so that you can resume printing. If there are no ink cartridges missing from the HP All-in-one, the ink cartridge contacts might need to be cleaned.
IF there is no ink cartridge missing from the HP All-in-One, and you still receive this message after cleaning the ink cartridge contacts, you might have a damaged ink cartridge. Replace the ink cartridge.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Nov 26, 2009 | HP Photosmart C6280 Printer
I just refilled my HP6500 ink cartridge 920. The ink level indicator still shows a low level of ink. How do I reset the ink indicator.
There is no way to reset the ink levels on this cartridge type yet. Any replacement chips on the internet are violating patent law. Once the chip tells the printer it is empty it will not print no matter how much ink is left in it. There is always a lag time between the introduction of a new cartridge type and the ability to fill it properly. For refills I would recommend Cartridge World when this cartridge type can be refilled.
Nov 01, 2009 | HP Officejet 6500 Wireless All-in-One...
Instructions on how to refill an hp920xl printer cartridge
http://h10032.www1.hp.com/ctg/Manual/c01669504.pdf
Download the above manual.....go to page no. 144.
It has brief direction to reset ink level.
Sep 17, 2009 | HP Officejet 6500 Wireless All-in-One...
Ink cartridge problem! The following ink cartridges appear to be missing or damaged.
hi!!!!
try to clean the nozzle of your cartridge with the alcohol
or solvent used cotton
or replace the cartridge
try to email me ronaldsuboc@gmail.com
Sep 18, 2008 | HP Photosmart C7280 Printer
202 people viewed this question
Seeker5211
Seeker5211
