Question about Garmin GPSMAP 230 GPS Receiver
Garmin 230 GPS
My Garmin 230 GPS doesn't stay on when I try to power it up. It tries to come on but the screen goes black and then it just goes off.
I have have checked the power cable, the ground and the cable from the antenna and they appear to be o.k.
Any suggestions?
  • alfo6523 Nov 29, 2008
    I have an older Garmin GPSMAP 230 Receiver. It will light up on start up, but screen goes black , in a second, then light. But no data comes up.
    All inputs connected. Garmin will not work on these older units. No support from them. Any idea. Thsnks
I have the same problem...did you find a solution...
Smukii
Posted on Mar 02, 2008
I power my nuvi 255w on and it says loading maps but doesnt and it makes a beep and powers off. there is no reset button on this unit and i don`t know what to do to get it to come on and stay on? ty
Hold the power button for more than 20 seconds till it restarts - this is a soft reset. Then try again.
If that doesn't help, do a master reset which clears all user data back to the factory state. From powered down, turn the Garmin on while holding the right bottom corner of the screen for at least 20 seconds. A question should appear if all user data should be cleared. Then try again.
When it works again I would suggest to update the software in there till the latest version available on Garmin.com
Jul 04, 2011 | Garmin nuvi 255W GPS Receiver
Touch screen doesn't work
Have you tried the screen recalibration; by touching the upper right of the screen for 30 seconds or so while turning on the unit. This usually cures the problem.
Next try; sliding the "Power" key to the left position and hold it for eight to ten seconds to reset the Garmin. I have attached a link to the Garmin manuals for your 255W.
Once you get it going you should update your unit also at the Garmin site. The updates will fix the software glitches.
Thanks for using FixYa
https://buy.garmin.com/shop/store/manual.jsp?product=010-00718-20
Jun 02, 2011 | Garmin nuvi 255W GPS Receiver
My garmin nuvi 255w keeps freezing up at loading maps screen...i have tried the hard reset but that doesn't work, when i push on the bottom right corner and start the gps, it doesn't even make it...
There is a hard reset button under the sticker at the bottom of the unit. It is located directly under the check mark on the sticker. Once you get it going fully charge the unit then go to the Garmin website and register and update your 255w. I will attach the link to the Garmin Site. Thanks for using FixYa
https://my.garmin.com/mygarmin/registrationGettingStarted.htm?productType=auto&categoryType=AUTO
May 29, 2011 | Garmin nuvi 255W GPS Receiver
My New Garmin Nuvi 1400 will not turn on - it just gets to the screen "Loading maps" and then the screen goes black. I have tried the suggested holding down the power button for 10 seconds, but nothing...
My Garmin Nuvi 1490 was on for five or six hours driving then the screen went dark and now unit will not turn on or light up screen at all ? ANY HELP OUT THERE ?
Feb 09, 2010 | Garmin nuvi 1490T GPS Receiver
My garmin nuvi 255W has been working fine. I
Try resetting your unit with the reset button on the bottom. If this doesn't work, slide the power button all the way to the left and hold it for 8 seconds.
Dec 30, 2009 | Garmin nuvi 255W GPS Receiver
My Garmin Nuvi 260 is frozen on the Garmin screen
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Jul 27, 2009 | Garmin Nuvi 760 Car GPS Receiver
My garmin streetpilot c340's screen turns on and then goes black. I have it plugged into my car but it still won't stay on.
I found the solution on another blog. He said to try resetting the reset button . It worked. The button is located under the front screen. Remove screen frame by fingernail under the Garmin name. I'm thrilled. navinscs
Jan 25, 2009 | Garmin StreetPilot c340 GPS Receiver
GPSMAP 235 Sounder
Some 235s had a problem with the contrast setting. When the contrast is set to full the screen turns black.
When you turn on the GPS and the screen goes black, try tapping the left arrow on the track pad a few times. You should see the screen start to lighten. If that doesn't work, tap the power key and try tapping the left arrow a few times.
May 17, 2008 | Garmin GPSMAP 235 Sounder GPS Receiver
Garmin GPSMAP 230 GPS Receiver Logo
327 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
