Question about Oki Electric Industry B410D Laser 30PPM 2400X600DPI USB 32MB Dupl PCL5E 120V Printer
I have a new OKI B410d printer which is givng error message "Install Toner 613 Toner Missing" yet toner cartride intalled adn plenty of toner in drum
  • 13 Answers
It is more than likely that you have an incompatible toner fitted to the drum unit. Either a generic cartridge or b430 or b440 cartridge which is not compatible with b410's. Beyond that it may be a faulty drum unit. Hope this helps.
Posted on Sep 14, 2009
  • 1 more comment
  • HW Link
    HW Link Sep 22, 2014
    I have 2 of these printers, the drum/toner is brand new in the one and works in one printer, but the other one says the same error as above, therefore your answer is not correct.
  • HW Link
    I have 2 of these and one is brand new. I switched the drum/toner unit from the new one to the one with the error and it still gives the same error. When I switched it back, it works fine. Your answer is in error.
  • jamesfg007 Sep 23, 2014
    9 ppl liked this for a reason mate. You can't just switch toners between printers. The error is on the machine, plus there are generic toners. Starter toners all sorts of issues by just switching them. I used to work for oki. I think you are in error of being a techie with a clue
Oki b410d printer has a new toner cartridge however it is still printing inconsistently on the page?
Open the lid. Mounted under the lid you should see a horizontal bar which is actually the laser [LED]. Once your toner cart has emitted, enough loose toner has accumulated on the laser that it can no longer draw on the page correctly. Using something soft and barely dampened with water [use a soft cotton cloth, NO PAPER PRODUCTS, no dirty rags, etc] and wipe gently from L to R to remove the loose toner. Turn to a clean section of the cloth and do it once more. GENTLY! No pressure, do not scrub it, or you can damage the laser. Close the lid and print something. You should be back to good now.
Oct 04, 2014 | OKI B Office Equipment & Supplies
Printing very light Okionly B410d printer usesblack toner cartridge
Try performing a stop test. Send a test page and turn it off mid print. Retrieve the page from the printer to see if the image is readable before it went through the fuser. If so the the fuser may need to be replaced.
Jan 16, 2014 | Oki Electric Industry C3300n Laser Printer
I have attempted to install 3 different black toner cartridges in my OKI c3400. I keep getting an error: "Toner cartridge lock lever is improper, drum missing, or toner sensor error. OFFLINE." I first...
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Mar 16, 2010 | OKI C3400n Laser Printer
Emty error with new toner. Oki B410
What a usless "solution"...Do you have something that can accually work?
There is a procedure that will solve this issue. I have a new toner inserted and it keeps crying that the toner is empty...I have taken in out and put it back in, Now how do I reset the **** thing?
Mar 06, 2010 | Oki Electric Industry B410D Laser 30PPM...
I have just put new toner cartridges in my Oki C3400 and I am getting the message of "toner sensor error"
look this solution http://my.okidata.com/oki-faq.nsf/FAQCentral/C384D8F74A91CF6E8525765E0065F636?OpenDocument
here the solution for your problem
i hope that it's helpful .... bye
Mar 05, 2010 | OKI C3400n Laser Printer
My Oki C9600 Printer showed an error message, Reset Drum Basket - Waste Toner Transfer Error. After removing and replacing the toners, drum and waste toner bottle a new message appeared, 940: Fatal Error....
940: Error
The transfer mechanism of the
toner duct for ID is not operating
properly.
Check to confirm that the basket
assembly is in position (if it is
engaged with the gear of the
printer).
Check to confirm that the holder
magnet D contains a magnet,
and check the magnetic polarity.
Replace the HAL IC circuit
board.
Replace the duct assembly
toner.
Dec 21, 2009 | OKI C9600hdn Laser Printer
Toner Error
Check to make sure that the sensors are clean and play around with the lock arms. Reset the machine and also download the utility from the oki service website to get exact error message. http://www.okic3400.co.uk/library/downloads/utilities/c3300c3400smv1115.exe
Jan 27, 2009 | OKI C3400n Laser Printer
OKI C3400 printer keeps saying
Okay, I had the same problem with my C3300. I phoned the people i purchased from and this is what fixed it for me:
looking directly at the printer:
-open printer
-remove drum in question (the drum is what houses the toner cartridge) in my printer it is black.
-look on the right side of the drum & there is a little (approx 5mm x 5mm) hole that has a little panel that opens- push this up to open it.
-replace drum close the top and try printing.
I had to do this 2 times before it worked, but it worked.
Jan 19, 2009 | OKI C5100n Laser Printer
Error message after installing new tonner
Check the little switch/door on the left hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
Resolution:
Oct 30, 2008 | OKI KIT-C3530N MFP LASER CLR P/S/C/F USB...
Oki Electric Industry B410D Laser 30PPM 2400X600DPI USB 32MB Dupl PCL5E 120V Printer Logo
6,611 people viewed this question
Top Oki Electric Industry Office Equipment & Supplies Experts
Tony
Roger Binsfeld
Randolph Tidwell
Are you an Oki Electric Industry Office Equipment and Supply Expert? Answer questions, earn points and help others
