Question about Garmin Nuvi 350 Car GPS Receiver
Don't have pin code
I bought the Nuvi 265W at a flea market. The merchant input the pin number with me present and we went through the steps of changing it.
Once the unit was turned on two days later, the pin that I changed it to, will not work. I don't want to send it in to Garmin with my proof of purchase, because I have no idea how the merchant reveived the product (although it was in a box).
Please email me if you can assist.
gforce(at)ymail.com
  • 6 more comments
  • luieluie Sep 14, 2009
    I have already tried all examples of "default" and "easy" codes, none are working.
    I need someone (who knows how) to offer me an opportunity to reset the pin. I know, I know......99% of eveyone here is going to say that it isn't possible.......
    but
    it ABSOLUTELY is possible.
    If Garmin can do it, it can be done.
    If you can help me, please feel free to contact me on here or via email
    gforce(at)ymail.com
    Once again, if you cannot help, please don't feel like you need to respond.
    Illegal refers to something that is prohibited by LAW. I assure you that nothing in my inquiry is covered by any law in the United States. If you disagree, then by all means, do NOT post your illegal solution.
    All have provided great ideas, but none work.
    I have returned to the merchant at the flea market so that location is not the "secret location".
    Still asking for pin.
  • luieluie Sep 15, 2009
    4276 doesn't work
    I appreciate all the responses, but I feel as though some members aren't reading my issue.
    ....bought at fleamarket
    ....merchant set new pin right in front of me
    ....i never saw the unit say anything about a "secret location.
    ....unit worked fine for 2 days
    ....after 2 days, i turn on and it asks for pin
    ....won't accept my Personal PIN that I selected at flea market
    ....i try all factory defaults, 0000,1111,1234,4276
    ....i returned to merchant (with unit) to see if that was the secret location, it still asked for pin.
    ....i show merchant and he says that i had to of messed something up because it was working when i left (which is correct)
    If you want, you may quote the owner's manual, but I have a copy of it. It came inside the box that the unit was shipped and sold in.
  • 2,200 Answers
Hi
The bottom line here with this unit, is that you absolutely cannot do what Garmin can do with it. This Unit is now completely locked down and cannot be reactivated by any other means.
It does not matter what other answers you get to this - this unit will have to go back to Garmin to be hacked by their techs with their own specialised security software.
When the pin cannot be identified or the default location is lost there is absolutely no other way to reactivate it. These units are highly protected as an anti-theft measure and you are wasting your time trawling for any other solution.
I fully empathise with your situation and it is extremely disappointing for you to have this happen within a matter of days but it is important to be clear and upfront with what we are dealing with here.
My advice - contact Garmin Support and have it sent back for repair and reactivation ASAP to save yourself a lot of wasted time and effort. The procedure for returns is clearly outlined at this link
http://www8.garmin.com/support/warranty.html
Hope this helps. Please do rate this answer. Many Thanks.
Posted on Sep 15, 2009
  • Radio Code Pro
    Radio Code Pro Sep 16, 2009
    Just to add as to why I am putting this solution strongly to you as the only way to resolve the issue.
    You should be aware that the PIN for this unit is written into non-volatile memory. Because of this it is completely impossible for the PIN to be accessed or hacked via a standard USB connection between the GPS and a PC.
    Also you cannot reset the PIN by any means of disconnecting the power or forcing either a hard or soft reset on the Unit.
    This is why the only possible solution is a return to Garmin.
    Hopefully this has saved you some time and energy and please do remember to rate this answer.
    Thank You.
  • 3,051 Answers
Hello there here is a post for you Garmin provides a feature called "Garmin Lock", which allows the GPS owner to assign a (4) digit numeric unlock access code or PIN to their GPS. The PIN is designed to prevent your GPS from being used by an un-authorized user. It was also meant to be used a a deterrent to thieves, making the GPS useless if stolen. The PIN setup can be accessed by pressing the "wrench" symbol on the main menu (Nuvi Series). Next, press the "gear" symbol and you should see a listing for Garmin Lock. When you set up the PIN, you will be asked to enter in a (4) digit numeric code. After you enter the 4th digit, you will be asked again for the code. This is to make sure that both entries match and that verify that the PIN that you request will be the one written into memory. Your PIN is written into non-volatile memory..... it's not a file that is accessible via USB communications between the GPS and a PC. You can't clear it by disconnecting the power or disconnecting the battery or letting the battery run down. There is no jumper or switch inside the GPS to reset it, so don't waste your time tearing the GPS apart. Now, after you set the PIN, you will be asked to set the "secure" location. This can be anywhere.... your work location, home, local gas station, school, etc. In order to set the secure location, your antenna must be up and you have to have a satellite lock. If you don't have a lock, the "set" key will be grayed out until you acquire a lock. The secure location is your "back-up key" in case you forget your PIN. If you have forget your pin, all you have to do is physically go to the secure location. Make sure your antenna is up and that you have a satellite lock. When you are in the secure location, your GPS will NOT ask you for the PIN when you turn it on. You'll then be able to reach the main menu and change the PIN and secure location to something else if you desire. If you have forgot both the PIN and secure location you are out of luck. You'll have to send your unit back to Garmin to have it unlocked. Garmin may charge you for this service. Note: If you do send the unit back to Garmin to be unlocked and you are found not to be the original owner of the GPS and it's determined to be stolen, Garmin will contact law enforce
  • Michael Thomas
    Michael Thomas Sep 15, 2009
    Hello there again
    have you done every thing i had listed on the post there is a lot of information there so please read it carefully ok
    best regards michael
  • Michael Thomas
    1. Garmin Nuvi 360 GPS Review
      ... is a system for requiring an PIN number to access the GPS receiver functions. ... 350. This happens with many auto GPS systems and isn't limited to the ...www.gpsreview.net/garmin-nuvi-360 - 298k - Cached
    2. Garmin nuvi 760 Review (GPSmagazine.com)
      To configure GPS Lock: Figure 127: Setting a PIN Code for Garmin Lock ... Like the Garmin nuvi 660, the nuvi 760 uses SiRF's high performance StarIII GPS receiver. ...www.gpsmagazine.com/2007/10/garmin_nuvi_760_review.php?page=10 - Cached
    3. gpx drm10 GPS Devices - Compare Prices and Buy gpx drm10 GPS Devices at ...
      ... tom gps, tom tom, garmin nuvi 350, garmin nuvi 260, garmin ... 360 Car GPS Receiver $548 ... You may provide your Zip code above if you would like to improve ...www.shopping.com/-gpx+drm10 - 123k - Cached
    4. Garmin Nuvi 360 - Car GPS (Navigation)s - CNET Archive
      Read product reviews and find out more about the Garmin Nuvi 360 Car GPS (Navigation) stored in CNET's Archive. Brought to you by CNET Reviews.reviews.cnet.com/car-gps-navigation/garmin-nuvi-360/... - 231k - Cached
    Guru:
  • 194 Answers
Hello luieluie
Unfortunately , this pin that was entered is part of the Garmin anti theft system and can only be reset by Garmin. You will thus need to send it in to have it reset.
One thing you can try is the following.
Return to the location where you bought it from the mechant. When he entered the pin , he might have accidentally set the security location to where you where then instead of allowing you to set it to your home or work address.
If this is the case you should be able to use your Nuvi at the market without needing to enter a pin , and once the unit is on , you can change the pin and the security location to meet your needs.
Also , make sure that the pin the merchant changed it to , is the one that you are recalling while you are there and ask him if he knows where the security location of the unit is.
Other than that , you will unfortunately need to take it to Garmin to have it reset.
Good luck and I hope this information is of use to you.
Kind Regards
Stephan
  • Stephan Reichert
    Stephan Reichert Sep 15, 2009
    The problem is that Garmin actually opens the unit and inserts a cutom data cable.
    Then they reload the software on the unit , they do not actually recover or reset the pin which is the reason why it won't be possible to 'crack' the code in any way.
    There is always the shear force approach where you start at 0000 and work your way up to 9999 if nothing else is working and Garmin won't reset it for you. it will take you a good 5 hours , but it's a guaranteed way to get your unit unlocked barring there is some secondary locking system.
  • Garmin Master
  • 15,941 Answers
Wow the numbers that are in those are designed to prevent theft and you are on the bad side of this. There is almost nothing that you can do other than what you suggest.
  • 986 Answers
All you have to do is go to the location where it was set... and turn the unit on... it should not ask you for the PIN and then you can go into the menu and change/delete the PIN.
See this link for more info:
http://www.sharc.net/gps_lost_pin.htm
  • 854 Answers
Try 4276 I remember from many moons ago something about a Garmin Unlock don't have pin code - smile.gif
Posted on Sep 14, 2009
  • 311 Answers
Thanks for using fixya i am reviewing your information, For Bluetooth the pin number is 1234 Menu
1. enable Bluetooth settings tools > settings > Bluetooth enable
2. enable Bluetooth settings on your cellular phone
3. search for devices and select nuvi from them
4. when prompted for pin enter 1234
the nuvi also has internal memory, i am aware that you would need to send the device in to them to get it unlocked but, as a tip. if you go to the location where you set the pin number, the device will automatically unlock for you. allowing you to change the pin or remove it I'm sure.
here is the method to do that as well.
theirs only really 1 way to unlock the unit and that's with your security location. example. if you set the code at home and you are at home then the code dose not have to be entered at all. the device will know you are at the location and unlock automatically, however. if say you entered the new pin at the auction then you would have to return to that auction inorder to be at the location where you set the pin number up. i hope this helps you. and i hope i have been able to provide you with valuable information about the device. it is a gps triangulation device that knows where you set it's lock code at, once you return to the location it will be unlocked and you can set a new or possibly remove it. good luck.
  • 3,230 Answers
Well you need to contact to manufacture (Garmin), follow the below link to contact -
http://www.garmin.com/garmin/cms/site/us/support
Note.We do not have any permission to provide any illegal code or codes.
You can please follow the above link and ask them for your code, they ask some information about your gps.
Or another way is - you can download a firmware for your GPS. and update it, after that when your GPS ask for the code just input the default code.
follow the below link to download the firmware -
http://www8.garmin.com/support/download_details.jsp?id=4103
Good Luck!!
Thanks
  • 657 Answers
The default pin for the Device would be "0000" or "1234"
Incase you are not able to connect with these codes pls. revert.
Posted on Sep 08, 2009
Ive been using my garmin nuvi 265 and all of a sudden its telling me to enter a pin. Ii wouldnt permit me access so I entered 0000 and 9999 with no luck. What should I do?
The Garmin
Lock (anti-theft feature) security feature has been activated.
Going back to the security location will unlock the unit but in order to reset the pin code, the original pin code must be input.
To unlock the unit, it must be sent back to Garmin.
Sep 13, 2011 | Garmin Nuvi 265W GPS Receiver
265 garmin pin probem
What pin problem are you having?
If this is the Garmin
Lock (anti-theft feature) security feature.
May 01, 2011 | Garmin Nuvi 265W GPS Receiver
Got a used garmin nuvi for christmas from flea market no papers but it want pinn # how can i unlock it
Unfortunately, you cannot unlock it. It can only be unlocked by the original owner with either a PIN or taking it back to their 'security location' which they set. Otherwise, you have to send it to Garmin with the original receipt from an authorized Garmin dealer and they will unlock it for a fee. If you/gift giver got this from a flea-market, it looks like you are out of luck in unlocking it.
Dec 28, 2010 | Garmin nuvi 200W GPS Receiver
Trouble with Garmin Nüvi 265W.
I can help you reset and update your Garmin Nuvi 265W.
There are three steps to take to get your Nuvi 265W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 265W Manuals here.
Mar 28, 2010 | Garmin Nuvi 265W GPS Receiver
Hi, im having problems with my gps, it doesn t turn on, i don´t know what happened, it is pretty new...i used it just a few days. thank you
I can help you reset and fix your Garmin Nuvi 265W.
Getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted.
I hope that helps.
Feb 14, 2010 | Garmin Nuvi 265W GPS Receiver
I bought a garmin nuvi 350 at a flea
Take it back and get your money back, as it is probably stolen. The PIN cannot be broken as it is set by the original user and cannot be reset by a third party. Even Garmin will not reset it without the original receipt from a Garmin dealer.
Nov 22, 2009 | Garmin nuvi 350 GPS Receiver
My Garmin Nuvi 265W will not turn on. A couple of weeks ago when I booted it up, it had reset back to like new. Asking me to do set up and such. It's been cool since then. Today I shut it off at 5pm and...
I hope that helps.
Oct 15, 2009 | Garmin Nuvi 265W GPS Receiver
Garmin nuvi 265w
Getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted. Don't skip the hard reset step (or the backup step!)
I hope that helps.
Dec 25, 2008 | Garmin nuvi 350 GPS Receiver
Pin number
The only way to get it going is to send it to Garmin. The PIN is a security lock and Garmin will only unlock and return it to the registered owner ... who is not you. This is to prevent miscreants from stealing them and then selling them at, erm flea markets. You DID ask for proof of ownership, manuals etc from the flea market person didn't you?
Sep 12, 2007 | Garmin zumo 550 GPS Receiver
Garmin Nuvi 350 Car GPS Receiver Logo
114 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
