Question about Ovens
Kic oven (kuco 600) stopped working - Ovens
I have a Regency Trend Gas Wall oven. The Grill part is working but the oven part has stopped. My guess the gas element is blocked. Is there anyone in NZ that is able to repair or refurbish it?
as it is a gas appliance any accredited gas service person will be able to diagnose the problem and repair it
most problems with gas appliances can be attributed to blocked jets , faulty regulators or control units
find a retailer that sells gas appliances and ask who they recommend for the fitting and servicing of gas units
May 31, 2016 | Ovens
How to replace the thermostat on BP y-600
Turn off gas supply. Open panel on left side. Loosen the top and bottom unions. Remove thermostat capillary line from the oven. Now remove thermostat with 2 pipe wrenches. install new thermostat and attach assembly to the unions you loosened. Now insert the capillary line back into the oven.
Jul 27, 2014 | Bakers Pride Y-600 Gas Single Oven
Replacing element in an old Chef Auto 600 Oven
Good news!
You probably can do this yourself.
Most appliance parts stores will "demand" you give them a model number, but if you find an appliance store that has a smarter older employee, he or she can probably give you the right one by seeing the old one.
Also know the element may be fine.
Older appliances sometimes have bad wires from old age.
When you take this apart, look carefully at the wires that are connected to the socket that the element plugs in to.
You may find the only thing wrong is a bad wire.
Know also that wire connectors for high heat things like stoves are sometimes made stainless steel, for the high heat.
God bless your efforts.
May 12, 2017 | Ovens
I need to replace a fuse in my KIC oven but I cannot find where the fuses are? Please help. Many thanks Les
Sorry to read about your problem, I hope this helps you out.
most of them do not have a fuse
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Ovens
I need to get 2 slates for y600 pizza ovens do you sale them.
When your looking for this part it is called the "Stone Deck"
36" X 60" for most Y600 Models. FixYa is a "help you" site not a full blown retail outlet.
This is the Y-600-(old style) manual:
http://www.bakerspride.com/pdfs/Y-600%20Parts%20List%20OLD%20STYLE%207-05.pdf
This is the Y-600 manual: http://www.bakerspride.com/pdfs/PartList/Y-600%20Parts%20List%20U6050A%208-08.pdf
This is the Y-600-DSP manual:
http://www.bakerspride.com/pdfs/Y-600%20DSP%20%20Parts%20List%20U6051A%202-07.pdf
Their website went down for maintenance as I was doing this. But their phone number is on the website. http://www.bakerspride.com/
Thier manuals list is here. Note the price list for parts is at the very bottom block top of 3rd row.
http://www.bakerspride.com/manuals.asp
Thanks for choosing FixYa.
Kelly
Sep 14, 2010 | Bakers Pride Y-600 Gas Single Oven
KHO KIC KUCO600B 60cm BLACK Undercounter Oven and Hob set
south africa, or australia? get online to the manufacturers website and inquire!
good luck!
Oct 19, 2009 | Ovens
Can't find the fuse for the oven
I doubt this is a fuse problem. Could be the heating element has failed.
Apr 21, 2009 | Ovens
Timer?for y 600 deck oven
i got the same problem....................no solution so far
May 08, 2008 | Bakers Pride BAK-DS805 Gas Single Oven
Ovens Logo
232 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
